Old Jun 22, 2007, 06:26 PM
jlh45 is offline
Find More Posts by jlh45
Joined Oct 2006
Single phase electric motor problem
Although this is not strictly an engineering problem, I hope there is someone who can point me in the right direction to solve a strange problem I have with an electric motor.
For about 25 years I have had an Elektra Beckum table mounted 12 inch circular saw which for several years has been used rarely, maybe only one job in a year. The motor is a 2.2 kw, 2,800 rpm capacitor start single phase induction motor, which is rated at 11.5A.
Recently I needed to use the saw, but when I pressed the start button the motor started in reverse – not what you want with a circular saw!
It has never done this before and there is no reverse option on the no-volt switch.
The next time I attempted to start the saw it was obvious that it didn’t ‘know’ which way to rotate and blew the 13amp fuse – it has blown fuses ever since I’ve had the saw but not often enough to warrant any serious investigation.
At the next start up I spun the saw blade in right direction and then pressed the start button, whereupon the saw ran perfectly.
I have used the saw frequently over the last ten days and have found that I have to spin the blade to ensure the motor starts in the right direction. It has been cutting long lengths of timber with no signs of distress. If I don’t spin the blade the motor will mostly start in the wrong direction, very occasionally in the right direction, and has also blown another fuse.
Before I pull the motor to pieces does anyone have any ideas why this is happening and what to look for when I get inside the motor?
Thanks.
John
jlh45 is offline Find More Posts by jlh45
Old Jun 22, 2007, 09:58 PM
Don Young
Don Young
Guest
n/a Posts
Re: Single phase electric motor problem
"jlh45" <jlh45.2sls4n@rcgroups.com> wrote in message
news:jlh45.2sls4n@rcgroups.com...
> the motor started in reverse - not what you want with a circular saw!
> no-volt switch.
> didn't 'know' which way to rotate and blew the 13amp fuse - it has
> blown fuses ever since I've had the saw but not often enough to warrant
> distress. If I don't spin the blade the motor will mostly start in the
> blown another fuse.
> Thanks.
> John
> jlh45
> jlh45's Profile: http://www.rcgroups.com/forums/member.php?u=119557
> View this thread: http://www.rcgroups.com/forums/showthread.php?t=703339
I would check capacitor, internal starting switch, and start
winding/connections in that order. I suspect a shorted capacitor might
possibly cause reversed starting, all could cause failure to start and
blowing of fuse.
Don Young, Alabama USA
Old Jun 23, 2007, 03:07 AM
Austin Shackles
Austin Shackles
Guest
n/a Posts
On or around Fri, 22 Jun 2007 18:26:30 -0500, jlh45
<jlh45.2sls4n@rcgroups.com> enlightened us thusly:
it sounds like the capacitor's had it. Chances are, for that application,
it's a "constant capacitor" (i.e. low torque) motor, unless you know
otherwise. If so it hasn't got start windings nor an internal starting
switch.
Austin Shackles. www.ddol-las.net my opinions are just that
Travel The Galaxy! Meet Fascinating Life Forms...
>> http://www.schlockmercenary.com/ << \ ...and Kill them.
a webcartoon by Howard Tayler; I like it, maybe you will too!
Old Jun 26, 2007, 05:25 PM
jlh45 is offline
Joined Oct 2006
switch.
Thanks for the advice Austin.
It is a 'constant capacitor' motor. I had a go at testing the capacitor and then had it checked when it appeared to be duff.
Fitted a new capacitor and the motor now works perfectly.
John
Old Jun 27, 2007, 05:53 AM
ChrisQuayle
ChrisQuayle
Guest
n/a Posts
>>application,
>>starting
>>switch.
> John
May be the cap, but it's also worth checking all wiring to the motor,
particularly the wiring to the start winding. If the motor has an
internal centrifical switch (motor clicks on startup and slowdown),
check the contacts and associated wiring for continuity. Use a battery
and lamp for continuity checking and wiggle all the wires while testing.
Wiring and switch contacts left unused for a time can corrode and
oxidise, especially in a damp environment...
Chris
single phase brushless motor? stumax Power Systems 26 Oct 10, 2006 07:30 AM
AXI electric motor problem slowstick4ap Power Systems 3 Oct 15, 2005 05:45 PM
Electric Motor Throttle Problem joeg123 Batteries and Chargers 6 Jul 03, 2005 07:55 PM
