Old Jun 22, 2007, 01:12 PM
Skarn is offline
Find More Posts by Skarn
Maryland
Joined Nov 2006
DN Balance charger for a non-balance lead battery?
Hey all,
I have a DN Balance Charger and just got a Thunder Power 720Mah 11.1v battery that does NOT have a balance lead.
Is there a way I can use my Balance charger to charge this non-balance lead battery? I'm hoping I can get an adapter?
Thanks!
Skarn
Skarn is offline Find More Posts by Skarn
Old Jun 22, 2007, 01:34 PM
Merlin1205 is offline
Find More Posts by Merlin1205
USA, FL, Winter Haven
Joined May 2006
You would need to solder a balance connector into the pack.
This is not very easy to do unless you are experienced already.
You would actually have to open the pack up to access the wiring.
A lot of batteries use tabs that do not accept regular solder.
As well you must be very careful NOT to short anything at all times.
I know what I'm doing (Electronices tech) and I still get frustrated every now and then.
Since it did not have taps in place it must be a rather old battery and probably not worth attempting it in my opinion.
Happy Flying,
Tim
Merlin1205 is offline Find More Posts by Merlin1205
Old Jun 22, 2007, 02:08 PM
Skarn is offline
Maryland
Joined Nov 2006
Happy Flying,
Tim
Actually it's a brand new battery....Thunder Power. I ordered it online rather quickly and didn't even think to see if it had a balance lead.....I just assumed it would!
I guess I need to buy a non-balance charger now
Skarn
Old Jun 22, 2007, 04:32 PM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Skarn, maybe not. Did your DN come with some adapters? If so, see if you and modify one to use the first and fourth wires only and adapt these to you discharge connector of you pack. I am not sure about this DN charger but the older CSRC chargers would do this.
On my older style CSRC chargers I used the far left wire (black) and the far right wire (red) of the 3S port to the packs.
I did not know TP made packs without balancer taps. What is the date on it?
I can try this at home tonight on my CSRC DN style charger if you want. That is safer for you anyhow.
Rick
www.CommonSenseRC.com
rampman is offline Find More Posts by rampman
Old Jun 22, 2007, 04:38 PM
PetruSoroaga is offline
Find More Posts by PetruSoroaga
PetruSoroaga's Avatar
Bellevue,WA
Joined Jun 2006
As far as I know the DN charger can charge batteries that do not have balance tabs. You need to use the middle connectors on the charger and conect the battery leads there. Ofcourse it will be charged but not ballanced charged. Which is fine for most uses (not high discharge heavy usage of the battery).
Have fun,
Petru
EDIT: here is the manual (see general charging port): http://rds.yahoo.com/_ylt=A0oGkiawM3...Charger/G2.asp
PetruSoroaga is offline Find More Posts by PetruSoroaga
Old Jun 22, 2007, 04:58 PM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
Originally Posted by Skarn
Hey all,
Thanks!
Skarn
just SLOW charge it ~ 50 ma and never overload it, use a wattmeter to check prop load
hall woo is offline Find More Posts by hall woo
Old Dec 03, 2007, 10:23 AM View Post
carol312
A moderator felt this post violated the following rule: Excessive Advertising (Spam). Show it to me anyway.
Discussion Charging a balance lead battery with a "Normal Charger" CSI Batteries and Chargers 2 Mar 14, 2006 03:26 AM
Best Charger for 3000+ mah NiMh Battery packs? rutat Batteries and Chargers 10 May 16, 2004 12:42 AM
Useing a plug wall charger for slow charging new battery packs?? KOMET 44 Power Systems 3 May 12, 2002 01:06 AM
Transformer as charger for gel cell/lead acid batteries? originaljoe Power Systems 4 May 07, 2002 01:22 PM
