Don't know whether it's your ESC or not since you've tried changing the timing. Sounds like the previous mishap has caused the shaft/bearings/aligment to throw the magnets out of whack. If your motor is toast you may want to give the Scorpion motors a look. They are reasonably priced and from the reports coming in they look like they're going to give the big motor makers a run for the money. I know someone who just got a motor and ESC for $130. That's a 750 watt system too on 4s! The best part is someone at Innov8tive Designs has done their homework on the motors and ESCs. High temp wire and better cooling arrangment. They're supposed to be fielding some larger motors and ESC's soon too. Oh, and they send them in a cool black tin with a yellow Scorpion logo on it.
I'll be considering one for my next project. My 2 centsQuote:
Latest blog entry: Central Florida FPV Event
I don't think I mentioned that it's not a glider, not what it's intended to do,it just flies on the prop. You'll notice a little better glide ratio with the SFG's on. That being said it does the nicest elevators of anything I've flown. That's what this plane is for- hanging on the prop and powering thru pattern moves (and harriering down with no power, nice!) It will glide you just have to nose down pick up some speed and it will glide in. If you cut the throttle in level flight,it will settle in. That's why I've got 500 watts on mine, foamies this big use nothing but power to fly around, there's no airfoil really to support lift. Come to think of it, I've never really had a flat foamie that would glide well, they all pretty much did the same thing. You have to keep in mind the original design is for indoor pattern, that's all power flying. But I like the fact that it will do both 3D and pattern if you want it to.
This plane flies differently than other flatties I've flown, it doesn't take long to get used to it. Unfortunately I've had some airfoiled balsa planes that wouldn't fly this well and they were supposed to be great flyers if you believe advertising. Check out the inverted elevator near the end of this video: http://rcuvideos.com/item/MNWYQGZQDXHCK9RY |
What's your AUW? I thought mine was too heavy, but it's just about right. I quess the cubic wing loading comes more into play there. Especially when there's some wind. Haven't tried it without the SFG's, so you're going into the unknown there. Those leading edge extensions probably are key too.Helps delay the wing stall. And it is a power hog, but I generally find about 175-200 watts/lb. usually does the trick. I think I'm about 185+ right now. I've also got the vortex generators to drag around too so that eats up extra watts, but they seem to improve the slow speed control. I'll be putting back on some smaller VG's too, the larger ones work good but I think the overall flight envelope was better with lots of smaller ones.
Yeah go figure. All those wonderful airfoil sections to choose from and a flat plate works great
Someone thought I was filming in slo-mo but nothings' slowed down, it's all real time. It seems to just lock in and sit there nice and pretty in hovers and it's one of the easiest to harrier planes I've done. There is going to be some more development work on this planform , it's too much fun to ignore. David K. really nailed this one on the head. You'll love the F3P version, it's amazing how precise it is considering it's just some 3mm foam glued together. You've got the F3P version so just blow up the parts and viola! [/Quote] Looks like it hovers and harriers effortlesly. I got a Click last winter and haven't touched it yet, but I wan't to build a big one. I know what you mean about some airfoiled planes not flying as well as some flatties. It doesn't make sense, but the proof is in the flying.[/QUOTE] |
| Thread Tools | |
| Discussion Magnum XL .52 FS on a 96oz warbird? | jhamm | Engines | 7 | Feb 02, 2007 10:17 PM |
| Ebay - Magnum XL-52 4-stroke only a few minutes left! | neilo | Aircraft - Fuel - Airplanes (FS/W) | 0 | Feb 19, 2004 09:45 PM |
| Magnum XL .52 4 stroke | emartin | Engines | 2 | Jan 23, 2003 10:32 PM |
