Thanks guys,its just a rough sloppy job on this one to test it out. Next one will look cooler. Flew it today about 4 times and WOW!!! Really controllable, no white knuckle stuff here. Still ESC is getting to 134deg hanging in the breeze. That was with a 13 x 6.5 on 4s. Didn't fly as nice on 3s and the 14 x 7. Of couse it's only 95deg out and 100% humidity. the heat sink is smokin'! Have to try it out in cooler conditions. I can't wait to make the big one now!
Latest blog entry: Central Florida FPV Event
Hurry, someone fire up the CNC cutter! Mmmm...swiss cheese sandwich...
Clik XL video
Wouldn't you know as soon as the flight started the wind started really gusting to over 20mph by the end of the flight.
The Clik XL handled it very well(thank to Blakes' thumbs). Sorry there's not as much 3D on the vid the wind sort of took the fun out of that. Promise to get some vid of the Clik in better conditions. I'm having a blast with the way the Clik slowflies and it presents well in close. Also tested out the turbulators by taping them on. Good thing=there needs to be more of them,more of a toe in(45 deg) and they need to be larger. Also tested out 13 x 4 prop as the 13 x 6.5 was doing a number on the ESC. Seems to give a more constant speed now and doesn't tax the controller. Also moved the motor and pack forward 1-1/4" to help tracking. Also probably could benefit from some larger servos. More testing and better 3D video soon....enjoy! http://www.rcgroups.com/forums/showa...mentid=1365181 |
Fair warning - I'm about to go into a rather lengthy discussion of these things:
Actually, those are vortex generators, not turbulators. The idea is still the same, though - energize the boundary layer to make it stay attached better, and add drag while you're at it. A turbulator is usually a piece of wire or tape glued to the surface - the edge trips the flow turbulent. These things are little delta wings making leading-edge vortices (see more on this later in the post) If you're trying to add drag, they're just fine where they are. If you're trying to increase the control surface authority by making the flow stay attached better, you can move them back to just ahead of the hinge line, and they'll still do just as good a job (maybe better). Also, to make them more effective, both at energizing the boundary layer, and at generating drag, make them pure triangles. Basically, a vortex generator should be a small delta wing at a high angle of attack. Delta wings generate a leading edge vortex - basically one large vortex that follows the entire leading edge of the delta: This vortex likes to stay attached, and it's why the F/A/18 has a strake ahead of the wing - to generate a bound shoulder vortex that will stay attached at high angles of attack. (A cool discussion of this effect and the problem of "breakdown" ) You can get the same effect with these if they're triangular. Right now, you're going to be getting a vortex that is bound to the wing from the tapered part of the generator, but the flat part will either generate a separation region, or a vortex that isn't attached to the wing - neither one does you as much good as an bound vortex. The vortex generators can be the same height - just taper them more steeply, and you'll get nice big fat bound vortices that should wake up your control surfaces and add skin friction drag to the plane. On full scale aircraft, vortex generators are almost always used to make flow stay attached where it might otherwise separate - usually either just ahead of the max thickness of the airfoil, or just ahead of the hingeline. Like this: I'm not being critical in the least - just trying to help with tuning. |
Thanks for the tips Jeremy. I can use some help in the aerodynamics dept! That's my online motto"Aerodynamically challenged"! Just trying to slow the downlines and provide constant speed. This is an area I haven't delved into before. Airfoils and wingshapes I've played around with but surface devices are a whole 'nother ballgame. Anyone got a wind tunnel?
| Thread Tools | |
| Discussion Magnum XL .52 FS on a 96oz warbird? | jhamm | Engines | 7 | Feb 02, 2007 10:17 PM |
| Ebay - Magnum XL-52 4-stroke only a few minutes left! | neilo | Aircraft - Fuel - Airplanes (FS/W) | 0 | Feb 19, 2004 09:45 PM |
| Magnum XL .52 4 stroke | emartin | Engines | 2 | Jan 23, 2003 10:32 PM |
