This thread is privately moderated by leadfeather, who may elect to delete unwanted replies.
Old Feb 24, 2011, 04:04 PM
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
Great Idea ! any vibration issues ? Rich
rcrich is offline Find More Posts by rcrich
Old Feb 24, 2011, 04:21 PM
Winging it Ò>
leadfeather's Avatar
Joined May 2006
Originally Posted by jonesj26 View Post
Here's a (partial) video of the maiden flight. Ran out of camera battery.
http://www.youtube.com/watch?v=ooKgS4Y7Iqw
Overall it flew very well. Needed to shift the battery back a tiny bit for better CoG. Gonna be a fun one!
Nice! I think your A-10 needs a thread and some plans.
leadfeather is offline Find More Posts by leadfeather
Latest blog entry: Quick Stick
Old Feb 24, 2011, 04:25 PM
Joined Feb 2011
Not now. The first few versions had some problems with the CF rod bowing outward at lower RPMs, which shook things up pretty good and contributed to shaft/motor separation. Once you hit a certain rpm though, the CF rod centered itself and smoothed out. Keeping the shaft under about 9 inches and/or having a piece of EPP foam placed halfway between the motor and the foam at the back of the aircraft seems to eliminate this problem and lets it run smooth. I haven't noticed additional motor heat or wear and tear, but then I've only been doing this for about a month.
jonesj26 is offline Find More Posts by jonesj26
Old Feb 24, 2011, 04:37 PM
Joined Feb 2011
Thanks leadfeather! I'd be happy to do that. I'll begin putting together a more complete/useful set of plan documents and then will start a thread.
Cheers,
Jack
Old Feb 25, 2011, 06:24 PM
Joined Feb 2011
Update regarding coupling a carbon fiber shaft extension to a mid-mounted motor. I've found that both the fuel line coupling and (to a lesser extent) the tape coupling are more prone to separate if you have longer (or hotter) flight times. I found a 1/8 inch rigid shaft coupler online that appears to not have this problem. A picture of the coupler is shown below. I got these at http://www.servocity.com/html/rigid_shaft_couplers.html
It may, of course, introduce its own set of challenges...
Hope this helps.
Old Feb 25, 2011, 06:54 PM
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
Challenges is what keeps us inventing.... Great idea hope it works out
rich
Old Feb 26, 2011, 08:47 PM
Joined Feb 2011
Has anybody tried the clear Krylon Short Cuts to coat their bird? If not Krylon, what might be another option to provide a (light weight) clear coat?
Jack
Old Mar 06, 2011, 06:09 AM
just call me ditch!!!
UK, Eastleigh, Eastleigh
Joined Jul 2010
hey guys, i thought i might post my question here, as it is for tip
i am building a pusher uav type scratch built. i am still desigining it atm. what do i need to do that is different from a normal configuration.
like motor alignment
and incidence?
my previous build, well lets just say it looked good, but it didnt exactly take off. (i prob built it too small for my equipment as i had massive p-torque roll which was uncorrectable)
the motor was pointing up. (what about sidewys direction? and i had a few degrees of incidence, (approx 5deg, do i need more? )
cheers guys. any help would be really greatful.
also, when mounting the wings, whats a good idea, (as the wings are going to be approx middle of the fuse, is it a good idea to abuild the wings into the fuse, or can they be glued onto the sides what do you recommend?)
insomaniac45 is offline Find More Posts by insomaniac45
Old Mar 06, 2011, 08:45 AM
Winging it Ò>
Joined May 2006
and incidence?
sleepless,
I think you'll get more help if you can start a new thread and post some pictures of what you built and especially sketches of what you'd like to build.
The answers to some of your some of the questions you asked will depend on the overall design.
Old Mar 06, 2011, 09:20 AM
Joined Jul 2010
cheers lead feather.
will do.
Old Mar 20, 2011, 05:52 PM
Joined Mar 2011
WINGSTAYS will hold batteries, wings, ESC to foamies
Just go to www.wingstays.com and you will enjoy what they can do for your foamies!
stevenwicking is offline Find More Posts by stevenwicking
Old Mar 21, 2011, 06:24 PM
In the 20' glider range
anti-gravity's Avatar
Boise, Idaho
Joined Jul 2009
Cross posting and spamming isn't welcome here...
anti-gravity is offline Find More Posts by anti-gravity
Old Mar 21, 2011, 07:00 PM
Austin, TX
Joined Jan 2009
Marking on black epp
What do you use to mark cut lines on balck epp foam...I've tried a white fabric pencil and it doesn't work....
Found nothing at Officemax either....
thanks
Atx_Heli is offline Find More Posts by Atx_Heli
Old Mar 21, 2011, 08:07 PM
Winging it Ò>
Joined May 2006
thanks
Sharpie "Metallic Silver" works great on black epp.
Old Mar 21, 2011, 09:36 PM
flyin' fool
goldguy's Avatar
Vancouver Island, Canada
Joined Jul 2003
What do you use to mark cut lines on balck epp foam...I've tried a white fabric pencil and it doesn't work....Found nothing at Officemax either....thanks
straight pins or silver marker
goldguy is offline Find More Posts by goldguy
The Great 'Links to Free Plans' Thread! tim hooper Foamies (Kits) 194 Jun 08, 2011 12:59 AM
Yippee! Helicopter building tips and tricks - class 101 Happymcc Micro Helis 25 Oct 29, 2008 12:40 AM
Yippee! Please post your links to free plans HERE! CactusJackSlade 3D Flying 12 Oct 08, 2004 01:30 PM
The Great 'Links to Free Plans' Thread! (split by moderator) Zachary Foamies (Kits) 6 Oct 01, 2004 09:46 AM
EPP Building Tips Wanted jolive Foamies (Kits) 6 Jun 12, 2002 05:56 AM
