Go Back   RC Groups > Aircraft - Electric - Airplanes > Foamies (Scratchbuilt)
This thread is privately moderated by leadfeather, who may elect to delete unwanted replies.
Old Nov 02, 2009, 12:09 PM   #541
Proud to eat Kraut ;-)
Julez's Avatar
Yeah, ok, I should have written "control surface". All control surfaces are called "ruder" in german.
Julez is offline Find More Posts by Julez   Reply With Quote
Old Nov 02, 2009, 01:28 PM   #542
Go ahead... Build it to crash!
Fuegodeth's Avatar
Yeah. I just couldn't resist. I learned something new at least.
Fuegodeth is offline Find More Posts by Fuegodeth   Reply With Quote
Old Nov 06, 2009, 12:24 AM   #543
Try mixing up a solution Durham's water putty and lightweight spackle. Mix it with water so it will brush on with a foam brush. Consistency should be like thick cream, let dry and block sand to fill in the pores of the foam A couple of coats and you get a pretty good finish.
Here is Sapac F22 that was prepped with this technique.
  • Name: PA150006.jpg
  • Name: PA150008.jpg
Prof100 is online now Find More Posts by Prof100   Reply With Quote
Old Nov 18, 2009, 05:55 AM   #544
sky_surfer_fra's Avatar
Send a message via Yahoo to sky_surfer_fra
wing with dihedral and Jedelsky like airfoil
Hi EPP specialists,
I follow this thread since its start and it helps me very much to build my own EPP indoor and outdoor flyers .
But for two questions I still haven't found a solution I would like to implement (perhaps I have overseen it in this thread).
For my son (6 3/4yrs) I build a very light and slow indoor flyer.
To make flying as easy as possible for him I would like to control the plane only with elevator and rudder (and engine speed).
Therefore I need ~ 8° dihedral and a bit more airfoil like wing with some camber(?) to get more lift.
Do you have any ideas how to build the wing to get dihedral and more lift (Jedelsky like construction with ribs )to get a really slow flying indoor flyer...?
Thanks for your help!
Regards,
Tom
sky_surfer_fra is offline Find More Posts by sky_surfer_fra   Reply With Quote
Old Nov 18, 2009, 08:33 AM   #545
There's no place like foam...
leadfeather's Avatar
Originally Posted by sky_surfer_fra View Post
Hi EPP specialists,
Regards,
Tom
Tom, The EPP Piper by Gener Bond might be a good choice for you and your son.
leadfeather is offline Find More Posts by leadfeather   Reply With Quote
Old Nov 18, 2009, 11:22 AM   #546
Prop Buster Extraordinaire
philba's Avatar
Hi EPP specialists,
Regards,
Tom
You might consider a 24" blue baby (approx 61cm wing span). http://www.rcgroups.com/forums/showthread.php?t=681556
easy construction, very tough slow flyer. undercamber wings are quite easy to make. the thread is insanely long but the first post has the plans. make it from any 5 or 6mm sheet foam. maybe thinner for the 24. dihedral is in the plans though somewhat less that 8 degrees (that is a lot).
philba is offline Find More Posts by philba   Reply With Quote
Old Nov 19, 2009, 02:10 AM   #547
I builded a Blu Dart for my son two years ago when he was 8.
Really easy to fly and very easy to build.
Wery stable but also easy to have fun with, loops aroud its own axis.
I could not get hold of EPP so I had to use 6mm Depron that is much more frigile, BUT it still flyes.
If the chanse is that the plane will crash into peaces now and then, do not put to many work hours on it. Keep it cheap and simple and build a couple of them instead.
All depends on how good pilot your son is.
petrik is offline Find More Posts by petrik   Reply With Quote
The Great 'Links to Free Plans' Thread! tim hooper Foamies (Kits) 190 Dec 05, 2008 11:12 PM
Yippee! Helicopter building tips and tricks - class 101 Happymcc Micro Helis 25 Oct 29, 2008 01:40 AM
Yippee! Please post your links to free plans HERE! CactusJackSlade 3D Flying 12 Oct 08, 2004 02:30 PM
The Great 'Links to Free Plans' Thread! (split by moderator) Zachary Foamies (Kits) 6 Oct 01, 2004 10:46 AM
EPP Building Tips Wanted jolive Foamies (Kits) 6 Jun 12, 2002 06:56 AM
Bored? Want to fight?
Join the RCGroups clan!
