| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
Thread Tools |
| This thread is privately moderated by leadfeather, who may elect to delete unwanted replies. |
#16 |
EPP hot glue accelerator Component Cooler from Radio Shack. I use this to spot glue.
http://www.radioshack.com/product/in...entPage=search I use a 1/8 ball cutter on my Dremel to route in my 1/8 carbon fiber tubes, the tubes will snap in place. I than cover with a layer of hot glue and spread with a putty knife. Also hinge with hot glue like above, the only way to hinge EPP Carry a hot glue stick and BIC lighter for field repairs. Tony |
#17 |
D'oh.. Dumb Left Thumb
Blenderm works for Hinges if you seal the surface with UHU, 3m77 or similar.
Get a 12v to 110 (or 240) invertor and use a proper low temp glue gun for repairs |
#18 |
Foamie Guy
Sloper Steve's SPECIAL filiment tape is the STICKIEST, we have ever used... and we've tried em' all ... it is the BEST for EPP and makes all my building quick and painless... no pre-gluing, nada... great for hinging and tape spars ... and that's all you need...
#19 | |
There's no place like foam...
I'm looking forward to trying it "over/under" as a stiffener. Quicker and easier than tunneling and gluing in tubes and rods. Might belighter too. |
#20 |
Look outside the Square
Hey Leadfeather found this a while back. Has a bit of info working with EPP.
http://www.eflightwiki.com/eflightwi...rking_with_EPP Boxhead
#21 |
Lead I am using Home depots 3mm dremel. The pack is saved just to share the # hopefully it is still in the box. If needed let me know and I will look.
There is a black attachment that allows the dremel to adjust height. A line is drawn 21mm? from the line that needs to be cut and away you go. Thank you for everyones efforts to consolidate EPP building info!!! |
#22 | |
#23 | |
#24 |
videos
Build videos; like the one on the Flopsalot thread and in the RCSuperPowers web site; are excellent teaching tools.
Looking for volunteers to to make short videos of your favorite building techniques and tricks for working with epp to post on this thread. If some links to similar build videos already exist please post!
#25 |
Mandatory for males and Womandatory for females to use the straight edge.
Attachment photo: http://www.goblinville.com/bootique/...tting-tool.gif Bit Dre194 (almost sure need to check) http://www.hobbyplace.com/tools/drebits.php left column They have a round bit which should use less glue from its rounded cup slot. It also hides it. |
#26 |
You can sand EPP with sandpaper or power tools such as a belt sander, but often times will be left with a peach fuzzy surface. I use a sealing iron (like the ones used for covering models with Monokote and such) to gently remove the fuzz. I start out at a low temperature and slowly raise it until the fuzz starts to disappear. If the EPP beads begin to swell, I just press them down and smooth them out with a cold, flat piece of metal.
#27 |
Plans
Hey guys, I need help filling out the plans section in post #4. There has got to be a lot of good epp build plans out there. Help build a realy good list!!
#28 |
I did not see a link to the Infinieon http://www.rcgroups.com/forums/showthread.php?t=606425 did I?
- Allen |
#29 |
Build 2 Bounce!
Plans :
Silent Mite - http://www.rcgroups.com/forums/showthread.php?t=618057 Ultimate - http://www.rcgroups.com/forums/showt...94#post6175094 Puff the Magic Dragon - http://www.flyelectric.ukgateway.net/puff.htm Bounce 3D - http://www.flyelectric.ukgateway.net/bounce.htm Yak 54 - http://www.rcgroups.com/forums/showthread.php?t=420980 FF540 - http://www.rcgroups.com/forums/showt...50#post6418650 If I remember any more i'll let you know. |
#30 |
Rab , Firetrappe Thanks for the links to the plans. I'll add these to the list.
For each plan, could you indicate which category it fits in? Thanks again, Dan |
| Thread Tools | |
| The Great 'Links to Free Plans' Thread! | tim hooper | Foamies (Kits) | 190 | Dec 05, 2008 11:12 PM |
| Yippee! Helicopter building tips and tricks - class 101 | Happymcc | Micro Helis | 25 | Oct 29, 2008 01:40 AM |
| Yippee! Please post your links to free plans HERE! | CactusJackSlade | 3D Flying | 12 | Oct 08, 2004 02:30 PM |
| The Great 'Links to Free Plans' Thread! (split by moderator) | Zachary | Foamies (Kits) | 6 | Oct 01, 2004 10:46 AM |
| EPP Building Tips Wanted | jolive | Foamies (Kits) | 6 | Jun 12, 2002 06:56 AM |
