Tidy up the wires.
After hooking up all those wires, the machine was a little sloppy, soooo.... I took a trip to the local Radio Shack to gather some items to help control the cabling. I bought some flexible black tubing designed just for this. The tubing came in 10' lengths which is plany for this design. I slipped the motor wires from the Z axis into the tubing along with the limit switch wires. I was concerned that this might not be susceptible to electronic noise but this has not been the case so far. I secured the end of the cable tube using a hose clamp also from Radio Shack.
Routezilla II
It is probably about time I told you about my machine. I built a Routezilla II from plans I got at http://www.kleinbauer.com. John Kleinbauer is one of the first people to offer plans for build it yourself CNC Projects. He currently offers 15 different plans which range from CNC mills, router, 4th axis and driver boards. All the CNC plans in John's collection cost $36 (money order or check only. US and Canada).
The Routezilla II was designed to meet peoples desire for a larger Router. The Routezilla has a 18" X 40" bed with a 12" X 26" X 2" cutting area. The machine was designed to cut out Doll House parts, Lawn Art and other craft parts at a faster rate than John's other machines. This design is for the experienced builders only because John left several details to the builder that he normally details in his plans. I didn't find this to be a short coming for my build. John developed this project online and showed details of the completed project before he had completed the plans. Several people copied the design so John released the plans as is....... I like many things about the Routezilla II. The only thing I wish for is more Z travel. I toyed with expanding the Z axis but after looking it over for a while, I realized that this would involve several design changes. Besides, most router bits are 2" cut length or less. |
I have determined through testing that the problem is in a software setting, I am getting closer to solving. The switches now work but need tweaking. I also need to read more of the manual. As soon as I get it perfect I will detail the problem, step to investigate and solution. Thanks for the kind words. Bill |
Moving on
I am going to ignore the limit switch settings for now and move on
The basic controller box has been completed and the router is up and running. So now it is time to talk about the software needed to make a CNC machine tick. CNC machines generally need three pieces of software to get the job done. 1. A drawing program - can be a CAD package or in some cases a Drawing program like Corel Draw or Adobe Illustrator. 2. A Cam package - to generate the tool path that the cutter will follow. 3. A motor driving program - post processes the tool path to generate step and direction commands to the motors. There are many choices for these three pieces of software. Everyone has their own favorites. In fact, several of the programs available to hobbyist can perform more than one of these functions. For a drawing program I use an older product that is no longer available, called Drawingboard. I use this program because it draws quickly and accurately. When I need something with a complex, organic shape I use Rhino3d or Alibre Design, both of which are still available. There is nothing special about my choices so I will move on. For a Cam package I chose VCarve Pro 4.6 from Vectric.com. I have been watching the development of this program from it's inception and can safely say it is easy to use , powerful and worth every penny. I will do an in depth discussion of VCarve Pro shortly. I chose Mach3 for my motor driver software. Mach3 is in my opinion one of the most versatile driver packages out there. You can drive a router, mill, laser, plasma cutter, lathe, edm, foam cutter, hexapod and robots all from Mach3. I will be covering Mach3 next. Here are links to the software mentioned. http://vectric.com/ http://ashlar.com/ http://www.corel.com/international.html http://www.adobe.com/products/illustrator/ http://alibre.com/ http://www.artsoftcontrols.com/artsoft/index/index.htm |
| Thread Tools | |
| Build Log Hobby CNC 4 axis CNC Chopper driver board build. | bgriggs | The Builders Workshop | 39 | Jul 23, 2007 08:54 PM |
| Sold HobbyCNC 4 axis CNC controller with power supply | bgriggs | Aircraft - General - Miscellaneous (FS/W) | 2 | Apr 07, 2006 06:50 AM |
| how much $$$ for a homebuilt 4 axis cnc router | new flyer | The Builders Workshop | 8 | Nov 18, 2005 11:05 PM |
| Yak/Edge combo build, step-by-step | rpvpilot | 3D Flying | 5 | Mar 13, 2005 08:16 AM |
| Mountain Motors Cessna 180 Build Step by Step | dulcelife | Parkflyers | 254 | May 27, 2004 11:41 AM |
