Transformer
Well, my transformer arrived today. I am a little concerned about posting picture on how it should be wired though because I am not an electrician and 115VAC is involved......... Playing with electricity can get you killed if you don't know what you are doing. If you have any doubts about your electrical skills please seek professional help. The life you save is well worth the time you may lose.
I chose a different transformer than Hobbycnc recommends for the power supply. I purchase a 24V 10A transformer from http://www.mpja.com. The part number is 7846. The price was $17.99. I was trying to save a few dollars over the $35 transformer recommended. I hope this was not a mistake in the long run..... I have heard of several people using this transformer but I have never seen a wiring diagram..... The forth picture shows how I think the wiring may go. Anyone here able to verify this? Bill |
Dayton, Oh. area Moraine
Joined Apr 2007
Do the input wires go together like this?????
Take a look here http://www.cnczone.com/forums/showthread.php?p=219798 . Parallel 120V, series 240V. |
There is a link to my machine on http://ampedworld.com/. The plan is to then use the Routezilla to build my next router, a Joes 4'x4' Hybrid http://www.cnczone.com/forums/showthread.php?t=38220. I Think this is about the largest Router my garage can support. Bill |
Bill |
Back in the game
Well it has been a long busy summer..... When I last posted my Transformer had just arrived. I was uncertain how wire up the transformer since it is not the one that Dave Rigotti recommends on his website...... Well, thanks to some friends we were able to solve this mystery.
I began by searching in vain for a complete wiring diagram for the MPJA transformer. Apparently no one has posted one because they thought it was too simple.... Basically, what I found out was that the transformer had two sides, and input side and an output side. The input side is where the 120V is connected. In the case of the transformer I had the input side had four wires (Red, Black, Red, Black). The output side has three wires (Blue, Yellow, Blue). To get 120V into the input side of the transformer, I joined the two Red wires together and the two Black wires together. |
Power Supply Case
I was too cheap to spring for the recommended case for the power supply/driver board at $35 so I came up with an alternative. I went to Walmart and bought a Rubbermaid Keepsake photo and media box ($7.99). The box has a removable top and is large enough to hold all the components. It is easy to cut with hand tools and also see through.
The case I used is a Rubbermaid Keepsake box Part #4487. It is designed for DVD, CD 's and photo sotorage. It comes with a series of blue dividers that are useful in this build.
I start off by removing the top and taking out all the dividers and putting them aside. I used a dremel tool with a 1/8" drill bit to drill most of my starter holes. For big holes I used a Drill Master step drill set from Harbor Freight. http://www.harborfreight.com. |
The kit contains two fuse holders and a switch. The fuse holders hold two different sized fuses a 4amp and a 10 amp. The 4 amp fuse is used in the incoming AC (120V) line. The 10 amp fuse is on the other side of the transformer and protects the Bridge rectifier, capacitor and driver board.
I used a Dremel tool with a 1/8" drill bit to make the pilot holes for the switch, and fuse holders. I then used a step drill to get the perfect fit for each component. The step drills are nice because they fit an electric screw driver.
I positioned the fuse holders nearest to the part that they would protect. The 4 amp is mear the AC power line and the 10 amp is near the bridge rectifier. |
| Thread Tools | |
| Build Log Hobby CNC 4 axis CNC Chopper driver board build. | bgriggs | The Builders Workshop | 39 | Jul 23, 2007 08:54 PM |
| Sold HobbyCNC 4 axis CNC controller with power supply | bgriggs | Aircraft - General - Miscellaneous (FS/W) | 2 | Apr 07, 2006 06:50 AM |
| how much $$$ for a homebuilt 4 axis cnc router | new flyer | The Builders Workshop | 8 | Nov 18, 2005 11:05 PM |
| Yak/Edge combo build, step-by-step | rpvpilot | 3D Flying | 5 | Mar 13, 2005 08:16 AM |
| Mountain Motors Cessna 180 Build Step by Step | dulcelife | Parkflyers | 254 | May 27, 2004 11:41 AM |
