Old Jun 28, 2007, 06:46 AM
tbroeski is offline
Find More Posts by tbroeski
Afton VA
Joined Sep 2002
Originally Posted by Spaceship13
ill have mine done by this weekend ready to run. but theres one question.? as a new cnc operator who or where do i get a newbies cnc soft? forget the big bucks one . easiest to operate is best. thanks
For cutting foam cores, this seems to be the one:
http://www.foamwork.net/
tbroeski is offline Find More Posts by tbroeski
Old Jun 28, 2007, 11:54 AM
Ricardo RW is offline
Find More Posts by Ricardo RW
.: Looking for Thermals :.
Ricardo RW's Avatar
Chile, Quinta Región de Valparaíso, Los Andes
Joined Jun 2002
Hey bgriggs,
Keep it coming. I'd like to see how do you interface this board with your computer and do some jobs.
Regards,
Ricardo RW is offline Find More Posts by Ricardo RW
Old Jun 29, 2007, 07:00 PM
bgriggs is offline
Find More Posts by bgriggs
Make something. Anything!
bgriggs's Avatar
Syracuse Hancock, New York, United States
Joined Jul 2003
BS250P Mosfets Q1-Q8
Next I added the BS250P Mosfets to the board at Q1 - Q8. These Mosfets are shaped just like the silkscreen spot on the board so they will be easy to identify. The Mosfets case is orientated to align with the board image. Trim the leads.
bgriggs is offline Find More Posts by bgriggs
Old Jun 29, 2007, 07:09 PM
bgriggs is offline
bgriggs's Avatar
Joined Jul 2003
10uF 50V Capacitors C8-C11
Next came the 10uF 50V Capacitors C8-C11. The can of the capacitors has a negative sign "-" printed on the side. The shorter lead leg of the capacitor corresponds with the negative side of the capacitor. Place the capacitor on the board with the longer leg in the hole marked with a plus sign "+" and the negative leg in the other hole. After you have double checked the polarity, solder the capacitor in place and then trim the leads.
Old Jun 29, 2007, 07:53 PM
bgriggs is offline
bgriggs's Avatar
Joined Jul 2003
100uF 16V Capcitors C15-C18
Next came the larger 100uF 16V Capacitors C15-C18. The orientation is the same as C8-C11. Long lead in the "+" hole.
Old Jun 30, 2007, 12:29 PM
Jose E Bruzual is offline
Find More Posts by Jose E Bruzual
Flying IS the hobby
Upstate, NY
Joined Feb 2002
Originally Posted by bgriggs
The next step in the construction was to install resistors R9-R12 and solder them in place. These are 100K resistors and they are color banded Brown, Black, Yellow, Gold. After each step in the build I checked the solder joints under a magnifying glass. It is easier to find a cold solder joint as you add parts to the board, rather than checking the entire board in one session.
Bill, do you have any Macro pictures of the soldering joint? are you adding flux to the joint before you solder and if so, how are you applying it?
Thank you again
Jose
Jose E Bruzual is offline Find More Posts by Jose E Bruzual
Old Jun 30, 2007, 09:22 PM
bgriggs is offline
bgriggs's Avatar
Joined Jul 2003
Thank you again
Jose
Good question. I will take some macro photos of the solder joints and post them.
I use a Rosin core solder I get from Radio there is no real reason to add flux (rosin) to the joint since a small amount is already in the solder. I have already assembled the board so ther is'nt really any opportunity todo a solder demo on the board. I will try to work something up though.
Bill
Old Jul 01, 2007, 08:12 PM
bgriggs is offline
bgriggs's Avatar
Joined Jul 2003
Potentiometers VR1 - VR4
The potentiometer VR1-VR4 are installed next. The legs of the Pot are curved and may require finesse to slip them in the holes. After they are soldered in place make sure to trim the leads.
Old Jul 01, 2007, 08:22 PM
bgriggs is offline
bgriggs's Avatar
Joined Jul 2003
Jumper Header Pins J1-J4
Soldering the 2x4 Header pins to the board takes a little thought. Dave Rigotti recomends you install the jumper/shunts to the long side of the header first. If you do this and lay the board upside down, flat on the shunts they are easier to solder.
Old Jul 01, 2007, 08:30 PM
bgriggs is offline
bgriggs's Avatar
Joined Jul 2003
DB25 connector P1
Possibly the hardest part to solder onto the board is the DB25 connector. The pin spacing is very close together and requires a steady hand and a good set of eyes to accomplish. I perfer to alternate solder joints from one end of the top row to the opposite end of the bottom row working in from the outside. This prevents heat from building up on one area of the board, possibly warping it or worse, lifting a pad. I also find that using this method reduces the chance of bridging a solder joint because the joint has already colled by the time you get back to it.
Old Jul 02, 2007, 08:20 AM
will_newton is offline
Find More Posts by will_newton
wishes this caption was longe
will_newton's Avatar
wilson, nc, usa
Joined Dec 2005
Bill, I hope you continue past board assembly and go into the actual mechanics of hooking this system up to a CNC foam cutter or router.
Thanks for this thread, I've been considering getting one of these setups from you, bu was intimidated by the work involved in making it work! It doesn't look so bad now!
will_newton is offline Find More Posts by will_newton
Old Jul 02, 2007, 11:10 AM
bgriggs is offline
bgriggs's Avatar
Joined Jul 2003
I intend to show it all the way to motors spinning and mounted.
Bill
Old Jul 02, 2007, 02:18 PM
wilson, nc, usa
Joined Dec 2005
hmmm..just realized that you aren't the guy selling them after rereading the first post. ooops!
I still say YAY!
Old Jul 02, 2007, 06:22 PM
bgriggs is offline
bgriggs's Avatar
Joined Jul 2003
I still say YAY!
Nah, I'm not the guy who makes them. If I were designing electric circuits they wouldn't work . It takes a real pro to develope a product like this.
Bill
Old Jul 02, 2007, 06:37 PM
Flying IS the hobby
Upstate, NY
Joined Feb 2002
Will Newton stumbles into the room and glad to see you here Will
Jose
Build Log Hobby CNC 4 axis CNC Chopper driver board build. bgriggs The Builders Workshop 39 Jul 23, 2007 08:54 PM
Sold HobbyCNC 4 axis CNC controller with power supply bgriggs Aircraft - General - Miscellaneous (FS/W) 2 Apr 07, 2006 06:50 AM
how much $$$ for a homebuilt 4 axis cnc router new flyer The Builders Workshop 8 Nov 18, 2005 11:05 PM
Yak/Edge combo build, step-by-step rpvpilot 3D Flying 5 Mar 13, 2005 08:16 AM
Mountain Motors Cessna 180 Build Step by Step dulcelife Parkflyers 254 May 27, 2004 11:41 AM
