ahh man sorry to hear that..i bought another one after a bad crash the other day.. it is still in the box, i keep repairing my old one.. the epo is tough stuff.. i wsh they would send a spare cowl in the box, i'm on my third one from caliber hobby... hey how much throttle with what prop on your hand launch? |
Ken |
What the..@#$%
there is a guy that bought the parkzone P51, flew it the first day, no problem, nice plane...the next day flew it into a tree....Looks Ok now, but has some battle damage on it.... Sorry to hear it amigo, Mike |
Here's a cheap tip for those with nice cowlings still. Get some packing tape and line the inside of the cowl with it the best you can. This will give you some added strength in the case of a "bad" landing.
A little more expensive tip is to add a layer of .5oz fiberglass to the inside. Pat |
Latest blog entry: Nico Hobbies
Joined Sep 2006
I just ordered the last remaining P40 Cowls from GWS I have 25 available. THese were hard to get and GWS keeps backordering everything like they sell stock and never produce more. I'd like to know if they plan on supplying parts?
gwsprops.com http://gwsprops.com/gws_p40.htm |
You're a life saver. I'll be making an order today.
Lexington, Ky
Joined Apr 2004
When the original cowl on my GWS 190 finally died, I made a new one with pink foam and fiberglassed (minwax) it. I painted a thick layer of epoxy on the chin of the cowl where it scrapes in a nose-over. If you are frustrated with the GWS 40 cowl, that's what you should do. It would only take a couple of evenings. What people may not realize about the flimsy stock cowls is that they will break without damaging the rest of the plane. If the cowl is very strong, it may damage the front of the plane in a rough landing.
Nose Problems?
Here's another idea, take that flimsy plastic cowling, coat the inside with some oil, pour some concrete inside and incert an oil coated smaller cowling as a form to hold the concrete against the outersell, this will leave a hollow inside area for the motor, let it cure for a few days, strip off the plastic and forming material and put that piece of concrete on the nose of your plane. Might be a little nose heavy, but it should last....
;-) Mike |
I think an even more novel concept would be to use quality material in the first place, rather than having customers consider a concrete cowl as a viable alternative.
Might not be such a crazy idea afterall...
That is so true, why use flimsy plastic for a cowling?
you know, the idea of using the cowling as a form may not be such a terrible idea, only fill it with some other material that is more durable and light enough? Maybe fill it with some of that ultra light spackling. An inside form could be used and then any material that needs to be removed from the inside to make room for things and provid ventilation could be cut/routered out. That would make a stronger nose, but not too much stronger and multiple noses could be made using the plastic cowl as a form... Mike |
got my order in
Mike |
| Thread Tools | |
| Discussion ****GWS-40: The Never-Ending Legend of Flying Tigers**** | RAY GWS | Product Announcements | 2 | Sep 01, 2007 09:45 AM |
| NIB GWS 40 EDF units | bruff | Aircraft - Electric - Airplanes (FS/W) | 2 | Sep 10, 2004 08:39 PM |
| hypethetical idea re: a never ending e-flight | Dax | Parkflyers | 7 | Feb 20, 2003 04:24 PM |
| Flying Tigers AVG | dottney | Scale Electric Planes | 2 | Feb 13, 2003 09:45 PM |
| Never ending problems | adam_jorgensen | Electric Heli Talk | 7 | May 28, 2002 11:51 AM |
