This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Jul 16, 2009, 10:39 PM
haiduk is offline
Find More Posts by haiduk
Pronounced "High Duck"
haiduk's Avatar
Marysville, WA
Joined Oct 2008
Just saw this ESC on Hobby King:
TowerPro H40A Brushless Speed Controller
Doesn't look like a bad deal for $10 bucks. The onboard BEC looks like it might be a bit wimpy but I tend to use external BEC's anyway. I like the idea of the external heat sink.
Even if you use an external BEC the cost is still under $20 bucks.
TURNIGY 3A UBEC w/ Noise Reduction
haiduk is offline Find More Posts by haiduk
Old Jul 17, 2009, 08:48 AM
skywarp1 is offline
Find More Posts by skywarp1
Long live the Nuge!!!
skywarp1's Avatar
South Central......Kansas
Joined Oct 2007
Originally Posted by ryramZ
hey, skywarp....have you had a chance to maiden your p 40!!!
Not yet, the weather keeps ruining my plans . Just when the winds are low enough, it starts thunderstorming. When the storms stop, it gets windy. That's Kansas for ya.
skywarp1 is offline Find More Posts by skywarp1
Old Jul 17, 2009, 05:25 PM
ryramZ is online now
Find More Posts by ryramZ
Your Pilot Ryan
ryramZ's Avatar
United States, IN, South Bend
Joined Nov 2008
Ahhh man!
ryramZ is online now Find More Posts by ryramZ
Old Jul 17, 2009, 05:39 PM
skywarp1 is offline
skywarp1's Avatar
Joined Oct 2007
Ahhh man!
Worry not, today I believe is the day. It's 75 degrees out, clear skies, and wind 3-5 mph. I will be leaving for the "field" within the hour. (Taking my EDF F-15 also). I don't know if my wife will take any pictures but I will post flight report tonight.
Old Jul 17, 2009, 09:13 PM
skywarp1 is offline
skywarp1's Avatar
Joined Oct 2007
The good, the bad, and the ugly...
I maidened the GWS P-40 today and I have to say that once this baby gets its airspeed up it likes to go. The stock motor really performed better than I expected and man does it look big in the air. My Scorpio FW-190 has the same wingspan and does not seem to have anywhere near the presence this plane does. I had a bit of time getting down on the deck to land because it just wanted to stay in the air. It took a few clicks of right aileron and a few clicks of down trim for level flight and it cruised just fine. Like I said, I needed to set up my landing a ways out as even with power nearly off it just chewed up a lot of ground to settle in to the ground. First flight was only about 5 minutes. That was the good.
The Bad: After flying my F-15 around the patch I decided to throw a second battery in the P-40 and give it another go. I was feeling good and even though deep down I felt I was pushing my luck I thought might as well, I didn't come out here to look at it. After a successful range and flight control check, I lined up on the runway, throttled forward, steered straight, ever so slowly eased in the elevator and the plane's nose popped striaght up, then subsequent nose over with enough altitude to level out, but no airspeed then came the tip stall but I recover. Damed if I did. So mad because I leveled it out and reduced power for an emergency ditch in the grass. The worst that would have happened is a nose over in about ankle high grass. That's when it hit a !!! PVC pipe sticking about a foot and half out of the ground!
The Ugly:...the pictures say it all. It doesn't look too bad to me. It should be repairable right guys? Please someone say yes, because the wife was there when it happend and delcared I can't buy a replacement and need to find a cheaper hobby. I suggested beer drinking and shooting pool, but I think you all know how that must have went over .
Old Jul 17, 2009, 10:30 PM
57sailplane is offline
Find More Posts by 57sailplane
57sailplane's Avatar
United States, NE, Hebron
Joined Nov 2008
looks like she should fix up just fine if you have most of the pieces and if you dont go find a cooler or some packing foam to fit in. i prefer an old gws plane that is beyond fixing as this foam is a lot better. anyways i have fixed worse and she flew just fine. good luck. andrew k....
57sailplane is offline Find More Posts by 57sailplane
Old Jul 17, 2009, 10:55 PM
denial15 is offline
Find More Posts by denial15
swede
denial15's Avatar
United States, CA, Anaheim
Joined Aug 2005
YES!!
GWS planes are very repairable.
denial15 is offline Find More Posts by denial15
Old Jul 17, 2009, 11:51 PM
MrBen. is offline
Find More Posts by MrBen.
Great Britain
MrBen.'s Avatar
Joined Dec 2008
hi guys, I bought myself a p40 a few days ago ... this is my second plane my first is a 1300w funjet
After reading the last 20 pages or so of this thread I decided to buy the Tower Pro 2409-12t motor but I have been scratching my head over this one as it seems the shaft is sticking out the wrong way. It comes out of the same side where I need to mount the motor! I have tried loosening the grub screws to see if I could slide the shaft through so it comes out the other side but it wont move easily. Do I need to mount this motor the other way or should the shaft be turned around/slid though?
Thanks guys!
MrBen. is offline Find More Posts by MrBen.
Old Jul 18, 2009, 12:40 PM
denial15 is offline
swede
denial15's Avatar
Joined Aug 2005
Are there holes on the other side of the motor too? You may need to buy a different motor mount that screws directly onto the bell.
Old Jul 18, 2009, 12:46 PM
denial15 is offline
swede
denial15's Avatar
Joined Aug 2005
Here is one of mine that has the motor mount coming out of the same side as yours. There are screws to mount a prop shaft to.
Old Jul 18, 2009, 01:16 PM
MrBen. is offline
Great Britain
MrBen.'s Avatar
Joined Dec 2008
no there are only screws on the side shown, also if I did mount itfrom the other side then wouldnt that mean that all the cables are spinning round and round?
Looking now there is more than one version of this motor and I think I should have gotton this one that has the same model number!
Old Jul 18, 2009, 02:14 PM
Tom Frank is offline
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Thanks guys!
You just need to get the GWS outrunner stick mount, shown in the following picture. It's much easier to mount this way on the P-40 than with a firewall mount. To get the correct prop clearance from the cowl, just trim off the front of the stick if necessary. Then get a collet-style prop adaptor that fits your shaft... probably a 3mm or 3.17 (1/8 in.) collet. That will give you a 5mm shaft diameter on the prop end, so you will need to use an APC prop with the different hub inserts to fit different shaft sizes, or drill out a GW DD/HD prop to 5mm. Here's the pic:
Tom Frank is offline Find More Posts by Tom Frank
Old Jul 18, 2009, 03:00 PM
denial15 is offline
swede
denial15's Avatar
Joined Aug 2005
no there are only screws on the side shown, ...
Then what he said.
Old Jul 19, 2009, 02:21 AM
nickthefarrow is offline
Find More Posts by nickthefarrow
UK
Joined Dec 2002
Hi est1976
I have one of these 2409/12 (not for the p40) and it can be configured in pusher or tractor mode, by changing the prop shart orientation. So carry on with what you started doing and you should be fine, it will reverse.
nick
nickthefarrow is offline Find More Posts by nickthefarrow
Old Jul 19, 2009, 11:09 PM
Joined Nov 2008
i have this motor in another configuration. i remove the alan screws one on the front and back. then i pull by hand the outer case off, its a little tuff because of the magnets. then i take the outercase with shaft to the drill press. i put a hole punch in the drill press that has a smaller dia. and press the shat out with the punch.. i then reinsert the shaft backwards and line up the flats for the set screws and walla.. they fly all the same out the front or back.
Discussion ****GWS-40: The Never-Ending Legend of Flying Tigers**** RAY GWS Product Announcements 2 Sep 01, 2007 09:45 AM
NIB GWS 40 EDF units bruff Aircraft - Electric - Airplanes (FS/W) 2 Sep 10, 2004 08:39 PM
hypethetical idea re: a never ending e-flight Dax Parkflyers 7 Feb 20, 2003 04:24 PM
Flying Tigers AVG dottney Scale Kit/Scratch Built 2 Feb 13, 2003 09:45 PM
Never ending problems adam_jorgensen Electric Heli Talk 7 May 28, 2002 11:51 AM
