This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Oct 06, 2008, 09:58 PM
brati4 is offline
Find More Posts by brati4
brati4's Avatar
Wichita,Ks
Joined Feb 2007
Originally Posted by JimNM
I have not done it yet - what I will do is loosen the left edge of the motor mount and slip a shim between the motor mount and the firewall, then re-tighten the screws. That will point the motor a little to the right. I will post again after I make the mod and give it a test flight. I need to grab some video and post it as well. Mine is NOT pretty and I'm not a great pilot - so no promises!
PS - the landing gear problem was solved with wire cutters - SNIP! - no more landing gear!
Jim
I had to change the thrust angles after that my problems where solved
brati4 is offline Find More Posts by brati4
Old Oct 08, 2008, 05:31 AM
JohnAsaPrice is offline
Find More Posts by JohnAsaPrice
JohnAsaPrice's Avatar
Joined Sep 2006
Need Help with Spinner
I purchased the Epyaya combo package with a Neodym motor:
http://epyaya.com/product_info.php?c...oducts_id=2522
http://epyaya.com/product_info.php?products_id=2566
Can someone explain, in detail, how you attach the GWS or Dubro 3" spinner to this motor? To me, the shaft seems too short to work in either configuration.
I'm probably missing something simple.
Thanks in advance.
JohnAsa
JohnAsaPrice is offline Find More Posts by JohnAsaPrice
Old Oct 08, 2008, 07:17 AM
brati4 is offline
brati4's Avatar
Wichita,Ks
Joined Feb 2007
Do you mean that the prop adapter is to short? If so this is what I used:
http://www.allerc.com/product_info.php?products_id=1664
Regarding spinners, I used a 3" GP aluminum backed spinner
Thanks in advance.
JohnAsa
Old Oct 08, 2008, 08:29 PM
gws shaqchang is offline
Find More Posts by gws shaqchang
FAA Commercial Pilot
Taiwan
Joined Sep 2008
Thanks in advance.
JohnAsa
http://www.caliberhobby.com/motors.html
http://www.gws.com.tw/chinese/produc...ve%20shaft.htm
Drop it by! Just for ur reference....
gws shaqchang is offline Find More Posts by gws shaqchang
Old Oct 09, 2008, 05:23 AM
Joined Sep 2006
Brati4,
Yes, I meant that the shaft was too short.
I ordered that part yesterday. I'll have to re-configure my motor installation, as my current mount is attached to the motor casing, not the shaft.
Any reason why using Aluminum backed spinner versus plastic backed?
thanks,
JohnAsa
Old Oct 09, 2008, 07:09 AM
brati4 is offline
brati4's Avatar
Wichita,Ks
Joined Feb 2007
Brati4,
thanks,
JohnAsa
It runs truer and is lighter than a full plastic one. This is the part number I used.
GPMQ4776 3" (76 mm) Red, 1 pc.
http://www.greatplanes.com/accys/gpmq4500.html
Old Oct 13, 2008, 07:31 AM
Joined Sep 2006
Thanks for the recommendation on the aluminum-backed spinner. I incorrectly ordered the DuBro all-plastic model before, and found that it was not only poorly balanced, but out-of-round. The tip visibly orbited the center point by about 1/8".
Since I had to make the propellor holes bigger, and take it out of the package, Tower Hobbies will not accept a return, which makes it a very expensive piece of useless plastic.
To to be clear for other P-40 fliers, avoid the DuBro 3" all-plastic 3-blade spinner.
Old Oct 27, 2008, 05:32 AM
Joined Sep 2006
Has anyone installed retracts on the GWS-40? Can you point me to instructions?
Old Nov 02, 2008, 12:10 AM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
Scale retracts would require 90 degree rotating gear. There are none in this size.
kahloq is offline Find More Posts by kahloq
Old Nov 02, 2008, 07:03 AM
Lancer31 is offline
Find More Posts by Lancer31
Joined Jun 2005
Not sure about the size, but poster Zbrubaker, on these forums, was offering a kit for making 90 deg. retracts. I'm pretty sure they would fit.
Lancer31 is offline Find More Posts by Lancer31
Old Nov 05, 2008, 05:38 PM
MERLIN V16 is offline
Find More Posts by MERLIN V16
Never Trade Luck for Skill
MERLIN V16's Avatar
United States, FL, North Port
Joined Jan 2005
Now there are 90 degree Roating retracts for this size plane!
http://www.rcgroups.com/forums/showthread.php?t=948598
Info at the end of the video!
MERLIN
MERLIN V16 is offline Find More Posts by MERLIN V16
Old Nov 06, 2008, 04:20 PM
jismail is offline
Find More Posts by jismail
Joined Jun 2007
Added flaps...
So after having numerous hard landings due to my inability to properly hit the small runway I have at the increased speed this plan tends to need to land correctly... I decided to add the flaps to this bird.
It was acutally very easy to do and only took about an hour from start to finish. I havent tried flying with them yet as my weather is a bit windy right now, but perhaps this weekend.....
Any tips on when/how to best make use of them? I have it set for auto deploy (if enabled by switch first) from 30% power or less and have about 3/8 to 1/2 in movment...
jismail is offline Find More Posts by jismail
Old Nov 06, 2008, 04:40 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
jismail,
Let us know how it goes. I may do mine with flaps soon.
MERLIN,
I will be ordering a set of those retracts soon for this bird. I'll let everyone know how it goes.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Nov 06, 2008, 05:25 PM
Joined Sep 2006
I put flaps on my mustang, and deployed 1/2 flaps during landing.
Try it at altitude first, you will find that your plane will really balloon, so you will likely need to put in some down elevator to offset. I set it up via switch on my transmitter.
It really does help reduce the stall tendencies on landing.
Old Nov 06, 2008, 05:26 PM
Joined Sep 2006
by the way, how did you actuate your flaps? got a picture of the wing without the fuse?
Discussion ****GWS-40: The Never-Ending Legend of Flying Tigers**** RAY GWS Product Announcements 2 Sep 01, 2007 09:45 AM
NIB GWS 40 EDF units bruff Aircraft - Electric - Airplanes (FS/W) 2 Sep 10, 2004 08:39 PM
hypethetical idea re: a never ending e-flight Dax Parkflyers 7 Feb 20, 2003 04:24 PM
Flying Tigers AVG dottney Scale Kit/Scratch Built 2 Feb 13, 2003 09:45 PM
Never ending problems adam_jorgensen Electric Heli Talk 7 May 28, 2002 11:51 AM
