This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Sep 14, 2008, 10:15 AM
Pete2 is offline
Find More Posts by Pete2
Pete2's Avatar
Mission Viejo, CA
Joined Dec 2004
Try the 2409-12:; you will thank me forever !!!
The motors coast less than $20, wears like iron and goes like hell ! (On the P-40).
In this case, the motor is shown on a Corsair. Modifications to the mounting stick must be made for the P-40.
A speed controller of 25 amps (Minimum) should be used.
[B]Warning !! -- Do not cut the motor shaft off --[B]
[IMG]
Pete2 is offline Find More Posts by Pete2
Old Sep 14, 2008, 10:51 AM
brati4 is offline
Find More Posts by brati4
brati4's Avatar
Wichita,Ks
Joined Feb 2007
Pete: Will the motor be able to perform on the P-40? The P-40s wingspan is 5" more and weighs at least 10 ozs more than the smaller Corsair. Traditional GWS powertrains may not be applicable with the new larger GWS planes.
brati4 is offline Find More Posts by brati4
Old Sep 14, 2008, 10:56 AM
Pete2 is offline
Pete2's Avatar
Mission Viejo, CA
Joined Dec 2004
Brati4 -- I presently have the motor on the P-40 now. -- I am very satisfied with it. --- Straight up !!!
Old Sep 14, 2008, 11:01 AM
brati4 is offline
brati4's Avatar
Wichita,Ks
Joined Feb 2007
Well then, I guess it works . What prop and battery are you running?
Old Sep 14, 2008, 11:05 AM
Pete2 is offline
Pete2's Avatar
Mission Viejo, CA
Joined Dec 2004
GWS 9 X 5 Black. I use a 2200 mah 11.1 volt battery.
Old Sep 14, 2008, 11:08 AM
brati4 is offline
brati4's Avatar
Wichita,Ks
Joined Feb 2007
Sweet, mine is smoking with a 1250kv Rimfire, 10x8 MAS"E" and a TPS 2100mah 3s I really need to find someone to vid my planes.
Old Sep 14, 2008, 11:32 AM
Pete2 is offline
Pete2's Avatar
Mission Viejo, CA
Joined Dec 2004
I am 78 years old. Have been flying RC since the beginning. I have a beautiful VCR: My wife can't get the VCR focused and I am having trouble finding someone to take the P-40 video smokin' across the field five feet off the ground whilst upside - down.
What, oh what does one do ????[IMG]
Old Sep 14, 2008, 11:33 AM
brati4 is offline
brati4's Avatar
Wichita,Ks
Joined Feb 2007
mmm pretty. Looks like heaven
Old Sep 14, 2008, 11:36 AM
Pete2 is offline
Pete2's Avatar
Mission Viejo, CA
Joined Dec 2004
When I am there, that is exactly where I think I am !!
Have a nice day !!
Pete
Old Sep 15, 2008, 03:13 AM
GWS CHEN is offline
Find More Posts by GWS CHEN
Taipei, Taiwan
Joined Oct 2005
Hi Pete,
It's a very good field ! Have more nice flights !
Chen
GWS CHEN is offline Find More Posts by GWS CHEN
Old Sep 23, 2008, 08:33 PM
PuddleJumper is offline
Find More Posts by PuddleJumper
PuddleJumper's Avatar
RCDad,
Here is a photo of my P 40 that I have not gotten the nerve to maiden yet
It is really pretty sad. This plane has been on my table completed since the end of May.
The P 40 ended up being pretty nose heavy with the Himax 3510 motor and 3" spinner. I had to hack the plane a bit and push the 3 cell battery back to the pilot's seat. I also added retracts (something I never did before, but always wanted to try). I really like this P 40, I hope GWS reproduces all of the older warbirds in this size of a plane.
I am currently working on a second P 40 to keep in my trunk for quick flights after work. It will be built from salvaged parts from other less fortunate GWS planes.
PuddleJumper is offline Find More Posts by PuddleJumper
Old Sep 24, 2008, 01:22 AM
glaros is offline
Find More Posts by glaros
glaros's Avatar
Greece
Joined Apr 2004
PuddleJumper,
mine also ended up nose heavy, even without the dubro spinner (only took some photos and removed it before flight) and I had to put some weight at the tail.
Have did you hack the battery compartment? Is it a clean job? Can you post any pictures?
You see the cockpit in mine is occupied
glaros is offline Find More Posts by glaros
Old Sep 26, 2008, 03:19 PM
Glaros,
I was fortunate enough that a friend of mine built his P 40 with a very similar setup first. He warned me not to put the canopy on until the battery was moved back far enough to get the C.G. right. I used a utility knife to cut a hole (just large enought for the battery to fit through) from the cockpit forward to the battery compartment. The battery pack is laying on the pilot's seat and pushed back all the way to the back of the seat. I also used a Dubro 3" spinner. It is too heavy.
On my second P 40 I used a Great Planes 3" spinner with the aluminum back plate. The second P 40 still ended up nose heavy and I had to push the battery back again. This time I used a dremel tool instead of the utility knife to remove the foam.
If I ever build another P 40, I will cut the battery compartment out before I glue the two halves together.
Old Sep 26, 2008, 03:39 PM
crxmanpat is online now
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
This is weird guys. I used a DuBro 3" spinner on a Scorpion 2215 outrunner, and 3S 2200 lipo. My CG was at 48mm and it flew great. I did not have to mod the battery compartment at all. In fact, I had later moved the CG back to the recommended 55mm, and it flew worse so I moved it back. I'm surprised to hear you are having CG problems. How big are your packs?
Pat
crxmanpat is online now Find More Posts by crxmanpat
Old Sep 26, 2008, 05:16 PM
glaros is offline
glaros's Avatar
Greece
Joined Apr 2004
Pat
Mine is a 1700mAh 3cell lipo pack. Would like to use 2200mAh but it would make it even worse...
Discussion ****GWS-40: The Never-Ending Legend of Flying Tigers**** RAY GWS Product Announcements 2 Sep 01, 2007 09:45 AM
NIB GWS 40 EDF units bruff Aircraft - Electric - Airplanes (FS/W) 2 Sep 10, 2004 08:39 PM
hypethetical idea re: a never ending e-flight Dax Parkflyers 7 Feb 20, 2003 04:24 PM
Flying Tigers AVG dottney Scale Kit/Scratch Built 2 Feb 13, 2003 09:45 PM
Never ending problems adam_jorgensen Electric Heli Talk 7 May 28, 2002 11:51 AM
