This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Aug 14, 2008, 11:28 AM
trotsky71 is offline
Find More Posts by trotsky71
Point Cook, Melbourne, Australia
Joined Aug 2007
Originally Posted by planelover93
i have a 3s 1500mah and a 25a ESC, what motor whould i get?
is this one ok?
http://www.hobbycity.com/hobbycity/s...less_Outrunner
I think your GWS-40 will feel a tad underpowered with that motor. I personally was only satisfied with the power I got from the motor below paired with a 30A Turnigy ESC and a GWS HD1080 prop ;
http://www.hobbycity.com/hobbycity/s..._(Eq:_AXi_2814
trotsky71 is offline Find More Posts by trotsky71
Old Aug 14, 2008, 04:20 PM
Condre' is offline
Find More Posts by Condre'
Lexington, Ky
Joined Apr 2004
Another spinner idea: could you use cowl snaps placed on the bottom of the spinner and on a base plate so that the cowl could be snapped on and off the base plate?
Condre' is offline Find More Posts by Condre'
Old Aug 18, 2008, 08:21 PM
brati4 is offline
Find More Posts by brati4
brati4's Avatar
Wichita,Ks
Joined Feb 2007
Gws P-40
Here is mine.
Rimfire 35-30-1250kv
40 amp Turnigy ESC
TPS 11.1/2100mah Prolite
10x8 MAS "E" prop
3" GP aluminum backed spinner
brati4 is offline Find More Posts by brati4
Old Aug 18, 2008, 08:27 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
i vote thats the sweetest GWS P-40 yet....makes me want to buy one!
corsair nut is online now Find More Posts by corsair nut
Old Aug 20, 2008, 06:18 AM
rc808 is offline
Find More Posts by rc808
Honolulu, Hawaii
Joined Apr 2007
2 questions.1.what's a good Hobby City motor for the p-40? 2. Anybody have any new p-40 videos? There aren't that many out there. Post em if you got em.
rc808 is offline Find More Posts by rc808
Old Aug 20, 2008, 09:15 AM
brati4 is offline
brati4's Avatar
Wichita,Ks
Joined Feb 2007
Here you go:IMHO
http://www.hobbycity.com/hobbycity/s...r_(Eq_AXi_2808)
http://www.hobbycity.com/hobbycity/s..._(Eq:_AXi_2814)
http://www.hobbycity.com/hobbycity/s..._1100Kv_/_345w
The last one is a combination of both above. More powerful than the first mentioned above and more efficient, but a little heavier. The 35-36C is a good powerful motor but maybe to heavy for this application. Plan on building a motor mount on the firewall, at least that what I did for mine. I use a 10x8 E prop from MAS
Old Aug 20, 2008, 09:39 AM
planekiller is offline
Find More Posts by planekiller
Midnight Maniac
planekiller's Avatar
USA, NE, Lincoln
Joined Dec 2006
Took this pic at the air show last weekend.
Enjoy
planekiller is offline Find More Posts by planekiller
Old Aug 20, 2008, 10:22 AM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
Roger Lombard reports good results using the Hextronic DT750 with the GWS 10 x 6 x 3 blade propeller. His report is No 9 in the customer ratings.
I have received my Hextronic DT750 but have not had a chance to test it yet because I did not have a spare 20 Amp ESC.
Edit:- I borrowed a 25 Amp ESC and got some preliminary figures.
Hextronic DT750 with a GWS 10 x 6x 3 blade propeller and 2200n Mah 20 C three cell battery.
!!.34 Volts
12.7 Amps
!44.06 Watts
970 Grams thrust (34.6 oz)
7,220 RPM
41.0 MPH pitch speed
Ken
kensp is offline Find More Posts by kensp
Old Aug 20, 2008, 11:57 AM
Tom Frank is offline
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
I build light... this one has this HC outrunner in it. GWS 10x6 prop and 1300 mAH 20C 3S lipo. A 9 in. prop could get a little more speed, but I prefer more thrust for the nice vertical climbs (not unlimited, more scale-like). Here's a link to some recent video This video was mostly to catch some low passes with some rolls and a hammerhead thrown in.
Tom Frank is offline Find More Posts by Tom Frank
Old Aug 21, 2008, 03:32 AM
rc808 is offline
Honolulu, Hawaii
Joined Apr 2007
Thanks everyone. Looks like a lot of good motor options. Nice video Tom. It really showed the area it needs to fly.
Is the epo version better somehow? It looks more difficult for paint to adhere? I'm leaning towards no landing gear due to the noseover tendency. Does the bottom get beat up quickly?
Old Aug 21, 2008, 08:41 AM
brati4 is offline
brati4's Avatar
Wichita,Ks
Joined Feb 2007
Yes, the bottom will take a little beating. I reinforced the lower fuselage with a couple layers of 3/4 ounce fiberglass.
Old Aug 21, 2008, 10:40 AM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
...Is the epo version better somehow? It looks more difficult for paint to adhere? I'm leaning towards no landing gear due to the noseover tendency. Does the bottom get beat up quickly?
For me EPO is NOT better. For one thing, it's about 10% heavier, which doesn't sound like much. But that's about 2 oz. more weight with a plane this size, and that can mean the difference between a nice vertical climb and not much climb at all, unless you add a bigger motor (more weight) which consumes more power and usually needs a larger battery to get the same flight times (even more weight). This plane already has a high wing loading... keep it light for easier landings and nimble performance.
If you land on a nice grass field like in my vid, a strip of packing tape down the belly will protect the EPS foam. Mine has sustained no damage from bellying landings.
You've read about the paint issues. There's also glue issues. It CAN use regular CA glue if you consider that a plus. I don't use much CA glue at all on my GWS foamies, so that's no concern. But other glues I DO use don't adhere as well to EPO foam.
Bottom line is if you crash a lot or fly in high winds, the EPO foam is probably your friend. If you don't, build light and it will fly right.
Old Aug 22, 2008, 05:05 AM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
For flying in the early morning when there is little or no wind the EPS is superior. But here in Darwin, in the middle of the day, we have winds up to 20 KPH and under these conditions the heavier EPO model is superior. As well the EPO Model survives crashes a lot better.
Ken
Old Sep 03, 2008, 09:44 AM
R/C Dallas is offline
Find More Posts by R/C Dallas
R/C Dallas's Avatar
Italy, Friuli-Venezia Giulia, Fontanafredda
Joined Apr 2005
Here are a couple of shots of my P-40. It has drawn a lot of attention at the airfield and has prompted a bunch of the guys to get these or the FW-190 to have a little combat and racing. Mine's done as a 325thFS Checkered Tail nicknamed Trixie. Unfortunately I cant find any picture of the Trixie pinup nose art to add to the front...still searching. It runs on the GWS 2215-12 with 3S and 4S 1320 batteries. I really like the power on 4S but the motor gets pretty hot with the 10x6 three blade. I will be going to the Turnagy 35-30C-1100 once it arrives which should be quite nice. Last item to get is the pilot of which I'm still looking for. Trying to find something nice and scale. Other than that I'm having a great time doing scale looking maneuvers and making mock straffing runs on the other planes in the air. Let the games begin!
Randy
R/C Dallas is offline Find More Posts by R/C Dallas
Old Sep 07, 2008, 12:51 AM
Fly Or Die is offline
Find More Posts by Fly Or Die
Foam flies better
Fly Or Die's Avatar
From Canadia and proud of it!
Joined Jan 2006
Where can I get the epo version of this? I was thinking towerhobbies or bphobbies?
Fly Or Die is offline Find More Posts by Fly Or Die
Discussion ****GWS-40: The Never-Ending Legend of Flying Tigers**** RAY GWS Product Announcements 2 Sep 01, 2007 10:45 AM
NIB GWS 40 EDF units bruff Aircraft - Electric - Airplanes (FS/W) 2 Sep 10, 2004 09:39 PM
hypethetical idea re: a never ending e-flight Dax Parkflyers 7 Feb 20, 2003 05:24 PM
Flying Tigers AVG dottney Scale Kit/Scratch Built 2 Feb 13, 2003 10:45 PM
Never ending problems adam_jorgensen Electric Heli Talk 7 May 28, 2002 12:51 PM
