This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old May 13, 2008, 11:11 PM
stacker is offline
Find More Posts by stacker
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
Here is my P40 with FW190D9
P40 is a great flyer.
All in all a good kit. Cowl needs to be stronger plastic, and I'm not a fan of the water transfer decals. They won't hold up, esp if you are a bit rough on the plane. I think for a plane this size the adheasive decals are better, but they need to improve the stick on these.
Mine is flying on about 160 watts and does fine. I did'nt think the foam spinner would stay on but so far it has.
Cheers--Stacker
stacker is offline Find More Posts by stacker
Old May 19, 2008, 09:15 PM
trotsky71 is offline
Find More Posts by trotsky71
Point Cook, Melbourne, Australia
Joined Aug 2007
Flew and landed the P-40 sucessfully over the weekend with a Dualsky XM2834CA-7, 1250kV motor spinning an APC 10x5E prop. This is a nice and powerful 28mm BL motor that is easily stick mounted using a GWS BL motor mount. Control throws were Elevator: 7mm, Ailerons: 11 mm (as recommended by ken in this forum). CG was set at 48 mm from the leading edge. This set-up was a major improvement from my maiden.
trotsky71 is offline Find More Posts by trotsky71
Old May 20, 2008, 02:58 AM
ysl3369 is offline
Find More Posts by ysl3369
trotsky71
Thank you for sounding and fly happily
ysl3369 is offline Find More Posts by ysl3369
Old May 23, 2008, 04:43 PM
glaros is offline
Find More Posts by glaros
glaros's Avatar
Greece
Joined Apr 2004
Originally Posted by kensp
Are you guys aware that the APC Slowfly propellers have a "Recommended RPM Limit". The RPM Limits are detailed in this APC Safety Limits web page.
Ken
Thanks Ken I didn't know that
Actually at WOT the propeller made a not so healthy sound but I thought something was not properly balanced. Any way I mostly flew at half throttle so maybe I got lucky.
If I replace the prop with the APC 9x4.7 thin electric what should I expect regarding performance. You see I was very happy with the 9x4.7 SF...
glaros is offline Find More Posts by glaros
Old May 23, 2008, 05:40 PM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
I use an APC 9 x 6 Thin Electric on my EPO GWS-40 and the perfomance is good, but not in the unlimited vertical class. I find that the APC Thin Electrics have similar performance to the APC Slowflys of the same dimentions, but because they are stiffer they run better at high power levels.
Ken
kensp is offline Find More Posts by kensp
Old May 29, 2008, 08:52 PM
Cub Fan is offline
Find More Posts by Cub Fan
Balsa just crashes better
Cub Fan's Avatar
Bradenton, FL
Joined Nov 2004
My flew great but is really low on power with the stock motor- I guess I will try a different motor - any one tried a Grayson hobby BL-2212/13 in this bird?
I also have a eflight 450 available - not sure which to try ?
any suggestions? I am using 3/s 1350 pack pushed all the way back due to balance because of the aftermarket spinner.
Cub fan
Cub Fan is offline Find More Posts by Cub Fan
Old Jun 19, 2008, 08:55 AM
Pete2 is offline
Find More Posts by Pete2
Pete2's Avatar
Mission Viejo, CA
Joined Dec 2004
Paint match for the stock paint job -- ???
Can anyone tell me the brand/paint name for a good match with the stock paint job provided by GWS ??
I have been very pleased with my P-40 using a Tower Pro 2409-12T motor and a GWS 9X5 prop. The motor was drawing too much current when using the provided three blade prop.
Thanks all,
Pete2
Pete2 is offline Find More Posts by Pete2
Old Jun 19, 2008, 09:04 AM
Joined Aug 2007
The Tamiya Acrylic Paint, XF-62 - Olive Drab, was the best I could get to match the fuselage for touch up work.
Old Jun 19, 2008, 09:06 AM
crxmanpat is online now
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I used Americana water based craft paint from Jo-Ann's. Light Avocado and Desert Sand.
Pat
crxmanpat is online now Find More Posts by crxmanpat
Old Jun 19, 2008, 10:06 AM
stacker is offline
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
Pat,
P40 looks great! Could you tell which plastic spinner you used for the 3 blader? Think I may upgade mine from the foam because of ballance issues.
Cheers--Satcker
Old Jun 19, 2008, 12:55 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Stacker,
Thanks for the compliment! I wish it still looked the same though. A while back it had a head on collision with a light pole. I hit the actual light cover dead on.
The spinner was a standard DuBro 3" 3-blader. I used the GWS 10X6X3 prop, and I had to trim the openings slightly to get the prop to fit correctly.
Pat
Old Jun 19, 2008, 01:21 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
stack, the great planes makes a electric spinner, its pointier, and a little more P-40 like, but crx's does look great. ive been thinking about getting one. walways been a sucker for the 40.
corsair nut is online now Find More Posts by corsair nut
Old Jun 19, 2008, 01:28 PM
jamesdr is offline
Find More Posts by jamesdr
Unrepentant Carnivore
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Originally Posted by Pete2
I have been very pleased with my P-40 using a Tower Pro 2409-12T motor and a GWS 9X5 prop. Pete2
Pete The 2409-12 is my all time favorite motor for the 1st gen GWS birds and used them in my GWS P-38. I considdered using one in my FW190 (same size as your P-40) but didn't think it would have the grunt needed. You say "pleased" - can you elaborate?
Jim
jamesdr is offline Find More Posts by jamesdr
Old Jun 19, 2008, 02:35 PM
Pete2 is offline
Pete2's Avatar
Mission Viejo, CA
Joined Dec 2004
Jim -- Pleased -- ?? --- Well, I GUESS SO !!!
I have used the Tower Pro 2409-12T on 4 ea. GWS P-38's, (I love the sound the P-38 makes when using GWS 8X4 props on a diving WOT low pass) 2 ea. GWS Corsairs, the GWS P-40, and the GWS AT-6 Texan. They wear lilke iron. I have not burnt one up yet, and I have really punished them! I buy them at "http://www.headsuprc.com". I stick-mount them as shown in the diagram after drilling 4 holes which are tapped with a 4-40 thread.
--- Don't know what more to say except that I LOVE THEM !!! (--I have about eight of 'em.)
I just finished my longest flight yet on the P-40 this A.M.: (I am slowly inching up on my flight time until I find out where I am.) The flight time was 7 min and 42 seconds with a ThunderPower 2200 mah (30C rating). I only used 1350 mah and my amp average was 10.41 amps. (I am using a GWS 9X5 prop.)
Old Jun 19, 2008, 03:34 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
CN,
The only reason I went with the DuBro is that was all I could find at the time. If I had found a 3" 3-blade electric spinner, I would have used it. But I can't see ordering just a spinner from an online supplier (support your LHS and all that).
The DuBro looks fine, but you're right, it needs to be a little more pointed.
Pat
Discussion ****GWS-40: The Never-Ending Legend of Flying Tigers**** RAY GWS Product Announcements 2 Sep 01, 2007 09:45 AM
NIB GWS 40 EDF units bruff Aircraft - Electric - Airplanes (FS/W) 2 Sep 10, 2004 08:39 PM
hypethetical idea re: a never ending e-flight Dax Parkflyers 7 Feb 20, 2003 04:24 PM
Flying Tigers AVG dottney Scale Kit/Scratch Built 2 Feb 13, 2003 09:45 PM
Never ending problems adam_jorgensen Electric Heli Talk 7 May 28, 2002 11:51 AM
