This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Oct 14, 2007, 05:19 PM
Tom Frank is online now
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
ATIS, If you refer back to Kensp's motor test chart, switching from the 3-blade to the 2-blade GWS 10x6 DD prop will gain you about 5 mph in pitch speed while saving about 1.5 amps at WOT. You do lose thrust in the process, but I think will be a better motor/prop combo in the air.
Do you happen to have a pic of your cowl damage you could post? I'm curious where the cowl split. I did not cut out any of the center lower air scoop, and drilled holes in the other two on the side just above. I have an idea for beefing up this lower front with minimal weight, but knowing the failure points would help.
I was careful not to land without being under low power, so I was able to just barely fly in parallel to the ground, then cut power and add a bit of up elevator to flare just before touchdown. I've only flown the two initial flights, but both times I had enough airspeed such that the flare actually caused me to gain about a foot of altitude and then drop in. Neither time resulted in any cowl damage, though. Sooner or later I'll bump the nose cowl, I'm sure, so want to beef it up a little.
p.s. That's wierd about your spinner... mine has the same OD as the circular part of the cowl, and I got mine from Epyaya, too (one of the very first they received).
Tom Frank is online now Find More Posts by Tom Frank
Old Oct 14, 2007, 05:50 PM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
Tom
It appears that the three blade 10 x 6 propeller unloads a lot more in the air and so the top flying speed of the two and three blade props is very similar.
Ken
kensp is offline Find More Posts by kensp
Old Oct 14, 2007, 06:23 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Originally Posted by kensp
Tom
Ken
That's interesting... with identical blade size and shape, I'd have guessed the 2 blader would spin faster producing a noticeably greater amount of pitch speed. Which do you prefer? Which pulls the best in large vertical uplines?
Old Oct 14, 2007, 06:56 PM
brati4 is offline
Find More Posts by brati4
brati4's Avatar
Wichita,Ks
Joined Feb 2007
Originally Posted by brati4
Roger that and watch the cowling.... Winds are dead... so I guess this is it.
Got to the field.... Kids are playing and then the wind started blowing.. Not meant to be today..
Tom: What is your fix for the cowling? How do you plan to reinforce it???
brati4 is offline Find More Posts by brati4
Old Oct 14, 2007, 07:03 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
I'm waiting to more infor from ATIS on where the cowl split, but my first thought is to put a 1/16 balsa or ply bulkhead horizontally across the bottom of thw cowl just above the bottom air scoop indentation. The fill the void below the bulkhead either with highly foamed Gorilla glue or inject some of that foam used for filling gaps around doors/windows, etc. That would give a solid impact area if the remaining cowl can take the load. Might also require gluing some stiffeners inside the cowl where the snap pins protrude through since much of the impact load will be transferred to thes pins. May not help that much in a major header, but if it can prevent indentation and splitting on some routine less-than-perfect grass landings it will have met my intent. Needs to be kept light, though.
Old Oct 14, 2007, 07:10 PM
brati4 is offline
brati4's Avatar
Wichita,Ks
Joined Feb 2007
Tom: copy that on keeping it light.. What's your feel on thin fiberglass cloth???
Old Oct 14, 2007, 07:35 PM
ATIS is offline
Find More Posts by ATIS
Member 120mph Club
ATIS's Avatar
New Bern, North Carolina, United States
Tom,
Sorry no picts as I taped it up already...
it broke/cracked along the bottom center and spidered up the left side; the right side just below the lower cowling clip going down and to the front; and of course, the entire cowling moved up (popped off the clips) destroying the shark teeth... a little tip would be to cut the decal along the cowlings edge so when you do bump it it wont destroy the entire decal... I also only cut out a little of the lower center and a very small area on the two side but it didnt help... well maybe it did I guess it could have been worse.
ATIS is offline Find More Posts by ATIS
Old Oct 14, 2007, 08:11 PM
cmpang is offline
Find More Posts by cmpang
香港
Joined Sep 2004
Some suggestions here:
ATIS don't throw the damaged cowling away. Buy a new one. Cut out the front part of the damaged one about 1 inch from the front. Never mind the crack. Push the damaged ring into the new one at the back and glue them together with PU glue. That makes the front part of the new one much stronger and more importantly, with the filled PU glue, not so bittle. Don't forget to rough up the contact surface before applying the glue.
Optionally, you may also like to apply a glass of 2 Oz fibre glass cloth on the outside. Don't do it on the inside. I tried that and it doesn't work.
It works for my F4U. Hope it work (or least improve) for the P40
cmpang is offline Find More Posts by cmpang
Old Oct 14, 2007, 08:15 PM
brati4 is offline
brati4's Avatar
Wichita,Ks
Joined Feb 2007
cmpang: What's your suggestion for those of us who have'nt cracked a cowl yet?? What's PU glue??
Old Oct 14, 2007, 08:56 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
I've never used fiberglas, but know some folks who have. They claim it's very strong, but I don't know about the weight.
Old Oct 14, 2007, 09:00 PM
brati4 is offline
brati4's Avatar
Wichita,Ks
Joined Feb 2007
Tom:cmpang has got something there regarding using an old cowl to shore up the weak spots. I have an old PZ Spitfire cowl that I can trim to fit the bottom of the GWS cowl. Only thing is: What is PU glue?
Old Oct 15, 2007, 06:16 AM
ATIS is offline
Member 120mph Club
ATIS's Avatar
Ok Gents,
Video posted of the maiden... nothing special but it does show the hard left turn on take off (even with a hand launch) and the tip stall on landing...
www.myspace.com/rcihcc
also a video of a ME 262 with duel pusher props
Old Oct 15, 2007, 08:02 AM
brati4 is offline
brati4's Avatar
Wichita,Ks
Joined Feb 2007
Looks to me as if it's just underpowered. A stronger motor would have pulled her on t/o and it would be able to keep speed up on landing. IMHO. Atis: I take it with the Park 480, I shouldn't have a problem.
Old Oct 15, 2007, 08:08 AM
ATIS is offline
Member 120mph Club
ATIS's Avatar
just remember your nose is going to be heavier.... by about 20 grams....
Old Oct 15, 2007, 08:36 AM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Originally Posted by ATIS
Ok Gents,
Video posted of the maiden... nothing special but it does some the hard left turn on take off (even with a hand launch) and the tip stall on landing...
Ouch! That was a pretty steep nose dig!
Discussion ****GWS-40: The Never-Ending Legend of Flying Tigers**** RAY GWS Product Announcements 2 Sep 01, 2007 09:45 AM
NIB GWS 40 EDF units bruff Aircraft - Electric - Airplanes (FS/W) 2 Sep 10, 2004 08:39 PM
hypethetical idea re: a never ending e-flight Dax Parkflyers 7 Feb 20, 2003 04:24 PM
Flying Tigers AVG dottney Scale Kit/Scratch Built 2 Feb 13, 2003 09:45 PM
Never ending problems adam_jorgensen Electric Heli Talk 7 May 28, 2002 11:51 AM
