How does the stock GWS BL Outrunner fly her? I am thinking my EFlite 450 outrunner is going to add a lot of nose weight so I may go with the stock motor... anyone sand the outside to remove the mold marks and such? I did it on my F-15 and it looked good...especially after it was painted.
ATIS,
I tried it with a GWS 2215-12 and the 1060X3 prop. It flew OK, but definitely not a barn-burner. I'm much happier with the Scorpion 2215-18 that's in there now. Pat |
Latest blog entry: Nico Hobbies
Ken |
You can refer back to my post #690 to see how my plane performed on the maiden flight (unpainted) with my power system. The GWS outrunner would give you something less for the same $ investment, but would give you that long threaded shaft the stock spinner is designed for.
ATIS,
Check out the video in this post. This was the maiden flight of mine with the stcok GWS motor and the 1060X3 prop. I'd say 30-35 level flight. Pat |
Tom,
I picked up the White P-40 with the GWS BL outrunner for $60 and 4 HS-55 servos for $45... so for $105 shipped (epyaya) I got almost everything I needed to get her in the air...I keep looking at my EFlite 450 from my ME-109 (and I am using a 40 amp ESC in the P-40 so I can change if I want)...but I want to keep the weight down... but I do like my P-47 on the 480... so I am stuck between wanting power and speed but also wanting the ability for nice easy landings with no tip stalls from all the weight up front... Pat How in the bloody heck did you keep orientation?? Nice flyin... if you bend the LG forward a little it helps prevent the nose overs on landings. On my P-47 I did that and went with slightly larger foam wheels... never ends up on her nose anymore. My speed should be a little higher then yours since I am belly floppin and using the 2 blade so my weight will be a little less... I am still kicking around rudder/no rudder... |
ATIS,
That camera is old and the head needs a good cleaning, so the quality was not that great. I had actually kept it pretty close in on the maiden. And the only reason it flopped over on landing was becaues I actually landed on a hillside, and it was going down the slope (hard to tell in the video). If I had managed to land on the flat surface at the top of the hill, it would have been fine. So far that's the only nose over I've had. Pat |
Pat, happy to hear she dont nose over...
so far the wing is together, fuse halves together, and elevator cut off (should have the directions on that part.. I cut before adding the wire... what a PITA that became), sanded everything down to get rid of the mold marks, and have added all the CF rods.... now to go to the LHS... ran out of pin hinges and 6 min epoxy... plus I need some deans, paint and a RX... always seem to run out of stuff in the middle of a build...
FWIW, I have always had good luck with the supplied GWS hinges when used with the supplied GWS glue. I always cut my slits wide enough so that the hinge slides in easily without binding. Then, I apply a light coat of glue to the hinge, let it set up for about 5 minutes, then insert into the surface. I make sure I work in the glue real well. Once it sets up, a little may bubble out of the slit, so make sure you remove an excess.
I crashed my AT-6 once when I launched with the wrong model selected. I wound up breaking off both wingtips, along with ripping out both ailerons. The GWS glue held so well that the hinges brought foam with them from the trailing edges. All I had to do was epoxy the foam back in place. GWS glue is great stuff if used correctly. Pat |
I like the micro pin hinges... no idea why... I used to use the GWS ones but once I was introduced to the pin hing I havent looked back...I am too impatient for the GWS glue... I like to keep moving and building.... started this morning and I am in paint at the moment... bottom grey is drying and then it will time to camo the top.
I did a little mod... I add a couple of little "skid plates" to the bottom of the nose to keep it off the deck and give me another 1/4 inch clearance for the 3 bladed prop... I am going to give it a try despite being a belly flopper... if it checks out... I left the prop and spinner off for paint. canopy is taped and mounted so I can carry the camo theme over the canopy to make it flow... we'll see how it turns out. |
| Thread Tools | |
| Discussion ****GWS-40: The Never-Ending Legend of Flying Tigers**** | RAY GWS | Product Announcements | 2 | Sep 01, 2007 09:45 AM |
| NIB GWS 40 EDF units | bruff | Aircraft - Electric - Airplanes (FS/W) | 2 | Sep 10, 2004 08:39 PM |
| hypethetical idea re: a never ending e-flight | Dax | Parkflyers | 7 | Feb 20, 2003 04:24 PM |
| Flying Tigers AVG | dottney | Scale Electric Planes | 2 | Feb 13, 2003 09:45 PM |
| Never ending problems | adam_jorgensen | Electric Heli Talk | 7 | May 28, 2002 11:51 AM |
