This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Aug 07, 2007, 06:07 AM
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
Originally Posted by UH-1H
Need some advice. I thought of flying without the landing gears, so i glued the smooth undercarriage housing instead. But as im assembling the props now, it seems the blade will touch the ground if i do a belly landing
If your only going to use a 2 blade prop and you belly land just remember if you cut throttle right before you hit the ground, the blade will move out of the way under its own as it hits the ground. Also make sure that your ESC has been set to break off! so that under zero throttle your ESC will free spin. (read your owners manual for more information on how to set this up)
tallflyer is offline Find More Posts by tallflyer
Old Aug 07, 2007, 06:29 AM
Sky shepherd
UH-1H's Avatar
Singapore
Joined Dec 2005
How about it i want to use the 3 blade? I have to install the landing gears?
UH-1H is offline Find More Posts by UH-1H
Old Aug 07, 2007, 07:14 AM
UK - in the middle somewhere
Joined May 2002
Glad you brought that up UH. I too have to belly land and has not thought of the implications of this on a 3 blade prop. I suppose I will have to stick to a 9 x 7.5 two blader. Belly landing on a 3 blade prop is bound to lead to broken blades even with a prop saver.
Hangar Rat is offline Find More Posts by Hangar Rat
Old Aug 07, 2007, 09:02 AM
Hooper, full throttle!
Tommy D's Avatar
USA, NY, East Islip
Joined Feb 2004
If you must belly land AND have a 3 blade prop, look into the FSK prop. They have proven to work just fine on belly landers. Just dont try and use them on very high RPM or watt motors.
Tommy D
Tommy D is offline Find More Posts by Tommy D
Old Aug 07, 2007, 10:00 AM
Sky shepherd
UH-1H's Avatar
Singapore
Joined Dec 2005
At the field that i fly, there are a mix number of belly lander and wheel landings. Mostly those with large wheels large electric and nitro will use their landing gears. But for small GWS warbirds and pusher jets i saw mostly are belly landing. But recently from the new GWS series, i saw 2 Texan (yes im not alone anymore in Singapore with a texan, there are already 4 here.) ROG and land with the stock wheels.
Since the P-40 wheels are larger than the Texan, and there are "shock absorbers" i m gonna try to do a ROG and wheel landing.
Damn, i had to dig out the previous foam undercarriage well, it was a b*t&h. Trying to sort out the electroncis now.
Again the only P-40 in Singapore....
Old Aug 07, 2007, 10:39 AM
Joined May 2002
UH - you are lucky that you have the choice of whether to use undercarrage or not! I unfortunately don't - the field I use is too rough and the grass is generally 300mm high.
Besides which - why are you not sleeping???
Old Aug 07, 2007, 10:51 AM
tallflyer's Avatar
Joined Jul 2002
Well great question as long as the blades can move enough to get out of the way you should be ok!
I don't have any planes that use a 3 bladed prop that I Belly!
Maybe some one can chime in here and offer advice.!
Old Aug 07, 2007, 10:53 AM
MN WATTS Master
Vintauri's Avatar
United States, MN, Mankato
Joined Jul 2003
We've had good luck with the Flying Styro 3 blades and belly landing. They move out of the way enough and they are flexible enough that so far we have not bent or broken anything on the motor or mounts.
Now I have not seen the new gws 3 blade props so I don't know how they compare.
Steve
Vintauri is online now Find More Posts by Vintauri
Latest blog entry: WATTS over Owatonna
Old Aug 07, 2007, 11:00 AM
Sky shepherd
UH-1H's Avatar
Singapore
Joined Dec 2005
Grandpa telling me to go to bed...it just turn 12 midnight here. I m not working tomorrow
Old Aug 07, 2007, 11:02 AM
Sky shepherd
UH-1H's Avatar
Singapore
Joined Dec 2005
Steve
Those flying styro 3 blader retail at $5.50 here, i guess i will look at them tomorrow.
Old Aug 07, 2007, 03:28 PM
Joined May 2002
LOL! It's more jealousy... MANY years ago, I was able to stay awake till the middle of the night modelling but now that I approach Grandpa age (but not status or maturity) I seem to be - like 'Uncle Roger' - morning person.
Good Night Young Man, I'm going to bed!
Ratty
Old Aug 11, 2007, 12:50 AM
Sky shepherd
UH-1H's Avatar
Singapore
Joined Dec 2005
Brought the P-40 to the field today, but the wind was so so strong only manage to do a range check with my XPS system on the P-40. Also add in a fail safe. It receive so much attention from other fliers. I got a few dogfight challenge too.
The texan did outrun and out turn a Formosa before, but it had a larger motor compared to the P-40.
Old Aug 16, 2007, 09:14 PM
Seeing the Farside.
Blaze.45's Avatar
Seattle WA, USA
Joined Aug 2005
Comon chicken, bawk bawk bawk. Dooo it. Dooo it. Dooo it.
And did that X-31 ever fly? What about the Flycat?
-Chris
Blaze.45 is offline Find More Posts by Blaze.45
Old Aug 16, 2007, 11:02 PM
Sky shepherd
UH-1H's Avatar
Singapore
Joined Dec 2005
-Chris
The X-31 and flycat needs a bigger esc. I should be able to maiden the P-40 tomorrow if the weather permits.
Old Aug 18, 2007, 09:00 AM
Tommy D's Avatar
USA, NY, East Islip
Joined Feb 2004
FWIW
Things have changed for me on the homefront. I ordered 2 GWS P-40 slope kits and will only finish 1. That said I put the other one up for sale in the Electric Planes for sale forum. Hope that helps out someone who missed the early bird sale.
Tommy D
Discussion ****GWS-40: The Never-Ending Legend of Flying Tigers**** RAY GWS Product Announcements 2 Sep 01, 2007 09:45 AM
NIB GWS 40 EDF units bruff Aircraft - Electric - Airplanes (FS/W) 2 Sep 10, 2004 08:39 PM
hypethetical idea re: a never ending e-flight Dax Parkflyers 7 Feb 20, 2003 04:24 PM
Flying Tigers AVG dottney Scale Electric Planes 2 Feb 13, 2003 09:45 PM
Never ending problems adam_jorgensen Electric Heli Talk 7 May 28, 2002 11:51 AM
