This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Sep 02, 2011, 01:47 AM
twn Chen is offline
Find More Posts by twn Chen
Taiwan, 北市
Joined Dec 2010
Hi Juanlago,
Topspin applied the C gear one of the EPS power systems listed on this link, http://www.gwsus.com/english/product...eps28-bl15.htm probably you have to contact service@gws.com.tw if Caliber does not carry it. Better to add the 28mm heat sink to the motor for the best performance. GW/EHS-400 http://www.gwsus.com/english/product...eps28-bl15.htm or GWACS021 http://www.gwsus.com/english/product/other/gwacsxxx.htm But you have to work on the heat sink further for fitting the motor better.
Chen
twn Chen is offline Find More Posts by twn Chen
Old Sep 02, 2011, 01:17 PM
juanlargo is offline
Find More Posts by juanlargo
Joined Aug 2011
Thanks to you twn Chen. I have the Caliber website and will look for the power system you suggest. I think maybe I can get the same system but I use the heatsink on the EPS-400C for my Estarter and I know what you are saying about the modification.
I will send a Email to the Caliber and ask if they have this power system or they can get one.
Thank you for your help.
juanlargo is offline Find More Posts by juanlargo
Reply With Quote  (Disabled)
Old Sep 04, 2011, 06:44 PM
twn Chen is offline
Taiwan, 北市
Joined Dec 2010
It's my pleasure.
Chen
Old Nov 18, 2011, 05:09 AM
sparky210 is offline
Find More Posts by sparky210
United States, NY, Buffalo
Joined Jul 2009
electric retracts
can someone please help me with my p40
i would like to put electric retracts in my gws p40
but what size ??? and where would be the best place to buy them
sparky210 is offline Find More Posts by sparky210
Old Nov 18, 2011, 08:21 AM
GiusedtoBe is offline
Find More Posts by GiusedtoBe
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
Look on hobby king's site and they have Changesun rotating retracts that are about the right size. I've been meaning to do the same to mine but its been backburnered for awhile.
Alan
GiusedtoBe is offline Find More Posts by GiusedtoBe
Old Nov 18, 2011, 08:54 AM
JimNM is offline
Find More Posts by JimNM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
I got a pair from Ming over at Windrider.com.hk. these are the new version with metal trunions. I can post some pictures later. The work well with the axles from Eflight.
JimNM is offline Find More Posts by JimNM
Old Nov 18, 2011, 10:06 AM
Joined Jul 2009
retracts
thanks ill take a look at hk
Old Nov 18, 2011, 12:04 PM
JimNM is offline
WAA-08 THANK FRANK!
JimNM's Avatar
Joined Jun 2002
Ah, yes I used changesun... Rated to 2.5 kilos.
Old Jan 05, 2012, 02:30 AM
lord chris is offline
Find More Posts by lord chris
RAFMAA
United Kingdom, Marham Airfield
Joined Jun 2005
i got a p40 3years ago for my birthday. only just managed to get it home (it was in sweden)
think it should be built in a few weeks. going to the aluminium look using foil tape. got one question though...... does it affect the signal for 2.4ghz when the airframe is cladded in this stuff?
lord chris is offline Find More Posts by lord chris
Old Jan 05, 2012, 03:04 AM
twn Chen is offline
Taiwan, 北市
Joined Dec 2010
It might be affected by the aluminum foil tape. It's better to have a ground test and a range check to see how far that the Rx antenna(s) need to be kept away from the foil, and do not leave them at inside of fuselage, as the wave might not be able to penetrate the foil. Just my two cents.
Chen
Old Jan 05, 2012, 08:14 AM
57sailplane is offline
Find More Posts by 57sailplane
57sailplane's Avatar
United States, NE, Hebron
Joined Nov 2008
totally agree. antennas need to be on the outside of foil.
57sailplane is offline Find More Posts by 57sailplane
Old Jan 08, 2012, 01:49 PM
RAFMAA
Joined Jun 2005
maybe il fly this 35mhz and trail the antenna. think 2.4ghz will struggle with a huge mass of aluminium in its way.
Old Jan 08, 2012, 07:36 PM
ryramZ is online now
Find More Posts by ryramZ
Your Pilot Ryan
ryramZ's Avatar
United States, IN, South Bend
Joined Nov 2008
It will add to the weight, why not go for aluminum colored paint? This bird is a great flyer, quite a little hotrod really. IMO keeping it as light ad possible would be beneficial.
ryramZ is online now Find More Posts by ryramZ
Old Feb 11, 2012, 04:24 PM
MPS86 is online now
Find More Posts by MPS86
MPS86's Avatar
United States, NY, Fairport
Joined Jan 2011
What does everyone use for a spinner? I tried a dubro one but the back plate was huge and the prop would not fit. Plus the spinner was out of balance right out of the package.
Matt
MPS86 is online now Find More Posts by MPS86
Old Feb 11, 2012, 04:40 PM
JimNM is offline
WAA-08 THANK FRANK!
JimNM's Avatar
Joined Jun 2002
Tower has a light weight 3" spinner in red, black and yellow. The back plate is aluminium and not quite the right size. The back plate is an odball size, I had to do a lot of sanding to the prop ring to fit right. Not perfect, but it works. The du bro 3" spinner is massive and caused me a lot of torque issues, yes torque, not p-factor.
http://www3.towerhobbies.com/cgi-bin...?&I=LXEBE6&P=7
Discussion ****GWS-40: The Never-Ending Legend of Flying Tigers**** RAY GWS Product Announcements 2 Sep 01, 2007 09:45 AM
NIB GWS 40 EDF units bruff Aircraft - Electric - Airplanes (FS/W) 2 Sep 10, 2004 08:39 PM
hypethetical idea re: a never ending e-flight Dax Parkflyers 7 Feb 20, 2003 04:24 PM
Flying Tigers AVG dottney Scale Kit/Scratch Built 2 Feb 13, 2003 09:45 PM
Never ending problems adam_jorgensen Electric Heli Talk 7 May 28, 2002 11:51 AM
