This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Aug 07, 2011, 02:43 AM
jbc
WHO's your DADDY!!!
jbc's Avatar
Australia, SA, Adelaide
Joined Sep 2009
Just about got mine finished today, all I got left is to put the decals on and maiden don't know why it took me so long to build her, she's been in the box under the bed for over 6 months Hopefully maiden tomorrow fingers crossed...
Just wanted to share my experiences with this 2836 1200kv motor from HK. Fantastic little unit (I have 2 of em) for any plane upto about 1.4kg on 3S I'm getting 30A and 350W with a 8x8 prop and it slightly better than a hover for my 950gm GWS-40 the motor only gets warmish (not hot) so there's probably a little more there for anyone who wants to push say 400W or so. Great motor, light weight and good power for any parkflyer size bird, even mates perfect top the GWS stick mount
jbc is offline Find More Posts by jbc
Old Aug 07, 2011, 12:03 PM
Leesburg, VA
Joined Jul 2005
Will it turn an HD 1060/3 propeller?
TopSpin is offline Find More Posts by TopSpin
Reply With Quote  (Disabled)
Old Aug 07, 2011, 06:13 PM
jbc
WHO's your DADDY!!!
jbc's Avatar
Joined Sep 2009
mmmmm....I'd say a 10" 3 blade 'might' be a bit much for it, hard to say, maybe if they're a not very wide/softish blade, 9x6x3 you'll probably get away with it.
Old Aug 09, 2011, 09:28 PM
Leesburg, VA
Joined Jul 2005
The GWS GWEPSQ2815RC power combo will spin an HD 1060X3 balde prop with amazing authority. Also, the additional weight helps to balance the EPO airframe without the need to add any weight.
I highly recommend this power setup for the P-40 if you want it to look authentic and still go faster than your friends.
Old Aug 09, 2011, 10:40 PM
jbc
WHO's your DADDY!!!
jbc's Avatar
Joined Sep 2009
Maiden was successful yesterday had some problems with the gear so just ditched em and went straight for the hand launch. Bit of a butt clincher but off she went, took her nice and high and trimmed her out, bit of left and down and she was fine. Power setup was HEEEEEAPS, was mainly flying at half throttle (10-12amps) and with 2200 3S I got rather long flight times. I am using an 8x8 2 blade prop which still gave me plenty of thrust but the higher pitch gives more speed at a lower throttle setting.
Had to muck around with rates and expo a bit but overall she looks and flies great GWS have done a great job!
Old Aug 09, 2011, 11:59 PM
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
I'm a bit surprised yours flies OK with only an 8 in. prop. I might have a smaller/lower kV motor and use a a GWS HD 10x6. It hand launches easily with a strong toss. I tried two flights with a 9x7 prop to see if I could get a bit more speed, and both times it rolled severely left on launch... first time I just barely recovered before making ground contact, but not so lucky the second time. I went back to a 10x6 and had no more hand launch problems. I attribute the behavior to the large diameter nose blocking too much of the prop wash with the smaller prop and less thrust at low speed, so the motor torque rolled it over before it could get up good flying speed. I'd think the 8x8 prop would be even worse in that regard, but I guess not! Maybe you've got more power. My weight is also much lighter since I fly with 1300 3S lipos.
Tom Frank is offline Find More Posts by Tom Frank
Old Aug 10, 2011, 06:05 PM
jbc
WHO's your DADDY!!!
jbc's Avatar
Joined Sep 2009
Tom my AUW when I had the gear on was around 950gm with a 2200 20C 3S batt. With full throttle I could hold her and she wants to slowly pull up vertically out of my hand so slightly better than 1:1. I had a 9x6 prop ready to go if I needed it but she flies fine with the 8x8 I did remove the gear for the maiden but I just weighed it and they only weigh 20gm so I doubt they'd make much difference.
You can kinda see prop in the pics, the blade itself is not very wide but it is very stiff so doesn't flex during flight.
Old Aug 10, 2011, 06:30 PM
kensp's Avatar
Darwin Australia
Joined May 2002
Its not the weight of the UC that degrades performance it is the extra drag of the legs and wheels hanging below the model.
Ken
kensp is offline Find More Posts by kensp
Old Aug 10, 2011, 07:03 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
I have a little better than 1:1thrust from my motor in a static test on a test stand, but once on the plane with all the fuse blocking the prop wash, it diminished for sure. I get very good climb on a fresh battery, but it peters out in a long vertical climb.
Mine flew OK with the 9x5 prop one it got up to flying speed... but the hand launch was too problematic with it, so I went back to the 10x6.
Glad (but still surprised) yours is flying so well with the small diameter prop! Post up a video!
Old Aug 12, 2011, 10:46 PM
MIGl7's Avatar
www.thunderbolt-gallery.com
Joined Mar 2007
I've been flying mine with a 10/7 , and what I've learned is that I will not fly it on calm days. I launched it for a friend of mine so I could take some pictures, and he plowed right in. Fixed it and flew it the next day and it flew right out of my hand. I went out in the evening when there was no wind, and both take offs were really ugly, (or really exciting!), thats when I realized that it, (mine), needs some wind under it to take off predictably. So the rule with this one is, no wind, no fly.
My bud bought a GoPro camera, so we mounted it on the P-40. Flew like sh*t, but I got some decent pictures
GoPro P40 (6 min 35 sec)
Steve
MIGl7 is offline Find More Posts by MIGl7
Old Aug 13, 2011, 07:59 AM
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
I fly with a generic 450 motor and a 10x8 2 blader prop. Plane has no problem with hand launches at all. Flying for abouot two years now with no mishaps. Maybe the guys that are having problems have cg issues.
Nice plane BTW John
Regards,
Alan
GiusedtoBe is offline Find More Posts by GiusedtoBe
Old Aug 13, 2011, 02:54 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Nice plane BTW John
Regards,
Alan
I have no problem with a 10 in prop, but do with a smaller 9 in prop. My CG is dead on... nice glide with neutral control surfaces and dead stick landings are possible, but the loss of thrust with a smaller prop just doesn't get the plane up to flying speed fast enough like the larger prop does with my power set up.
Old Sep 01, 2011, 05:02 AM
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
Guess that you will be happy to tell us how low the current consumption?
If to be with GWS BL2028 that would even got more thrust!
GWS4CEO is offline Find More Posts by GWS4CEO
Old Sep 01, 2011, 08:50 AM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
I just got to fly my second P40 last week. I added a set of changesun retracts for scale like 90 degree rotating wheels, a larger motor (Suppo 2820/6) and a larger red spinner. Total, I had to add 3 oz to the tail of the EPS frame to hit the c/g. Amp draw on 10*7 APC was 25 for 300 watts. 2# 6oz.
Now it has flown, it will be decorated.
Add magnets to the battery hatch.
Fly well!
JimNM is offline Find More Posts by JimNM
Old Sep 01, 2011, 11:59 AM
Joined Aug 2011
I see the topspin video and his P-40 look to be very fast. I was looking to your web site and see the BL2028 looks like is smaller motor than 2815 motor. How can we get more thrust from smaller motor? I will build my P-40 soon and will try the BL2028 as you say but what gear and propeller is correct for the most thrust?
I can order this motor and gears from Caliber so please tell me which is best.
Thank you.
juanlargo is offline Find More Posts by juanlargo
Discussion ****GWS-40: The Never-Ending Legend of Flying Tigers**** RAY GWS Product Announcements 2 Sep 01, 2007 09:45 AM
NIB GWS 40 EDF units bruff Aircraft - Electric - Airplanes (FS/W) 2 Sep 10, 2004 08:39 PM
hypethetical idea re: a never ending e-flight Dax Parkflyers 7 Feb 20, 2003 04:24 PM
Flying Tigers AVG dottney Scale Electric Planes 2 Feb 13, 2003 09:45 PM
Never ending problems adam_jorgensen Electric Heli Talk 7 May 28, 2002 11:51 AM
