Joined Oct 2009
Quick change tail wheel
![]() Quote:
Wouldn't hurt to get some "driving around" experience. All I need now is, the wind to be something less than gale force, and a little less liquid sunshine. RUD |
Joined Oct 2009
Unreliable
![]() Quote:
All I was able to do, weather, life, etc, was "drive" it around a bit on the drive way. I ended up bending in a little "right wheel", so it would track to the right a liitle bit to help me for my 1st take off. Don't even know if that is smart. I will report as soon as I have some thing. RUD |
I jumped back into the GWS P-40 owner club with an purchase from a member here. I can't remember how thick the wing is over the l/g area. I have a set of CHANGESUN electric retracts that can be made to rotate. Has anyone done this? Mine should ship this week, so I have a few more days before I can see first hand.
Be well, JimNM |
![]() Alan |
33 flights like new pnp epo p-40
LIKE new EPO p-40 for sale.
http://www.rcgroups.com/forums/showt...9#post18315075 |
Leesburg, VA
Joined Jul 2005
My only problem with the EPO P-40 and FW-190 is that they are heavy for their size. In order to get sport plane performance out of them you need at least a .10 sized motor. The problem then becomes one of battery and motor weight.
The power to weight ratio is just all wrong for a plane of this size so if you just want something that barely flys scale this is it. If you want a plane with unlimited vertical you need to look elsewhere. |
Leesburg, VA
Joined Jul 2005
I settled on a GWEPSQ2815R with a B gear and 1006HD/3 blade prop. It works OK but is pushed to it's limit and still is not what I would like. If you put the same motor in the EPP foam version it would be a rocket ship. The EPO is just heavy and is well suited for larger airplanes. |
| Thread Tools | |
| Discussion ****GWS-40: The Never-Ending Legend of Flying Tigers**** | RAY GWS | Product Announcements | 2 | Sep 01, 2007 09:45 AM |
| NIB GWS 40 EDF units | bruff | Aircraft - Electric - Airplanes (FS/W) | 2 | Sep 10, 2004 08:39 PM |
| hypethetical idea re: a never ending e-flight | Dax | Parkflyers | 7 | Feb 20, 2003 04:24 PM |
| Flying Tigers AVG | dottney | Scale Electric Planes | 2 | Feb 13, 2003 09:45 PM |
| Never ending problems | adam_jorgensen | Electric Heli Talk | 7 | May 28, 2002 11:51 AM |
