Wish you had that one on video! The most exciting wrong-prop-for-the-motor experience I've had was putting a GWS 1080 prop with a PowerUp 450 Speed motor (1200 kV) on my P-40.
Very fast, but then on one pass I noticed the spinner was pointing down at a strange angle... Got it on the ground quickly and found that I had melted the motor mount! Motor and ESC lived, thankfully. Until I knuckle under and put the 480 in it, that'll definitely be the fastest that plane will ever go! Much more exciting than simply testing with a wattmeter, I say! Jeff |
Beefier Struts
Did a little messing around with "scale-looking" rolling takeoffs the other day, but had a real problem with the flimsy gear struts bending during the takeoff roll.
I'd get a nice, straight, slowly accelerating roll going, then one of the struts would bend and it would zip off to the left or right (I thought it was simply left torque affecting me at first, but then noticed it was going off to the right, too). Anyway, stiffer struts like on the Art-Tech P-51 or Corsair seem like they'd be nice to have, but I'm not sure how to mount them. I probably ought to just go with the retract option, but I'd rather save the coin... Jeff |
Peoria, Arizona
Joined Feb 2009
Jeff |
i did the same thing made my own gear for another gws bird, mine are .074 thick music wire you get at the Lhs. bent them with a vise and hammer and linmans pliers. the thicker and stronger wire is much better. you have to have a compromise with weight and stiffness to your liking so ya i would say a trial and error thing.
later andrew k. |
Peoria, Arizona
Joined Feb 2009
I'll measure the wire tonight. One tip I can give is make them as short as possible which will save weight. The legs I made for my Zero were too long, and I flipped the nose over on landing most of the time. I cut them so the prop had maybe 3/4" ground clearance when the tail was up and now I rarely flip it.
The original GWS wire is 2mm and 3/32 wire is 2.38 MM. I have found the 3/32 wire to be quite adequate and now use it on all my larger GWS Warbirds. Ken |
let's see the difference between the 28mm and the 38mm motor mount... it's clear that the motor axle can't be in the same position if you use one or the other... and the P40 slot for the square bamboo is made for a 28mm motor mount that can't be used with a 30xx GWS motor (but only with a 22xx GWS motor) Bye sebsoupe |
It was suggested to GWS last year that they REALLY should make their own and include them in their kits. It's the ONLY simple way to stick mount a conventional outrunner on most all of their planes, and outrunners are the name of the game now. Geared inrunners, and especially brushed ones, are obsolete! GWS listens, but they don't hear very well. |
The Tiger Moth 400 is one of their "antiques" I will always want to have. I've consider stashing away 2-3 of them just so I will still have one for the foreseeable future. Nothing else GWS had managed to squeeze out the door or talk about producing now interest me at all (i.e. digital servos, beginner 2.4 radio systems, EDFs, RTFS, etc.).
Since this is the P-40 thread, that's one I like as well, but not like the TM400. |
| Thread Tools | |
| Discussion ****GWS-40: The Never-Ending Legend of Flying Tigers**** | RAY GWS | Product Announcements | 2 | Sep 01, 2007 09:45 AM |
| NIB GWS 40 EDF units | bruff | Aircraft - Electric - Airplanes (FS/W) | 2 | Sep 10, 2004 08:39 PM |
| hypethetical idea re: a never ending e-flight | Dax | Parkflyers | 7 | Feb 20, 2003 04:24 PM |
| Flying Tigers AVG | dottney | Scale Electric Planes | 2 | Feb 13, 2003 09:45 PM |
| Never ending problems | adam_jorgensen | Electric Heli Talk | 7 | May 28, 2002 11:51 AM |
