This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Aug 18, 2009, 10:37 PM
iscozky is offline
Find More Posts by iscozky
Los Angeles, CA
Joined Aug 2008
I think it's too much torque. When I test it the first time I tried to gain speed gradually during take off but it always turn to the left, the second time same thing happened, so I pulled the motor out push it more to the right and a bit down to adjust my thrust angle and got better result.
Allan
iscozky is offline Find More Posts by iscozky
Old Aug 19, 2009, 11:23 PM
ashleymatthew is offline
Find More Posts by ashleymatthew
ashleymatthew's Avatar
Los Angeles, Ca.
Joined Nov 2008
gws p40 epo maiden
P40 GWS RPV (3 min 29 sec)
ok take off
bad landing
ashleymatthew is offline Find More Posts by ashleymatthew
Old Aug 20, 2009, 09:11 AM
skywarp1 is offline
Find More Posts by skywarp1
Long live the Nuge!!!
skywarp1's Avatar
South Central......Kansas
Joined Oct 2007
Allan
Are you using the stock motor? The reason I ask is I noticed my P-40 does the same thing on take off, wants to pull left. At first I thought it was the tail wheel so I checked alignment and even bent in a little right turn. That helped a little along with almost full right rudder on take off it would stay straight enough until I got in the air.
skywarp1 is offline Find More Posts by skywarp1
Old Aug 20, 2009, 05:01 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Same here. I was using a GWS 3-blade prop on mine and it really wanted to go left on takeoff. Had to feed in lots of right rudder to keep her tracking straight until airborne.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Aug 20, 2009, 11:35 PM
ryramZ is offline
Find More Posts by ryramZ
Your Pilot Ryan
ryramZ's Avatar
United States, IN, South Bend
Joined Nov 2008
Pat
I think that it is all of the above mentioned things. Torque along with the tail wheel assembly. Are you able to lessen the rudder input as the plane picks up speed or do you hold your input constant untill you are in the air?
ryramZ is offline Find More Posts by ryramZ
Old Aug 21, 2009, 02:10 AM
iscozky is offline
Los Angeles, CA
Joined Aug 2008
[QUOTE=skywarp1]Are you using the stock motor? The reason I ask is I noticed my P-40 does the same thing on take off, wants to pull left.
Nope, I'm using this kind of motor http://www.hobbycity.com/hobbycity/s...idproduct=4916
Same thing happened to my brother in law's plane, it tends to go to the left as shown in the video above. But now everything works well, I'll try to post video again coz the take off right now is very controllable. Btw I didn't use any of the stock wheel and wires, I use P38 wheel from phase 3 for the front and dubro for the tail, the dubro has great ground control, I also did the same thing with my FW 190 for the tail wheel.
Old Aug 21, 2009, 05:44 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
ryamZ,
As soon as the tailwheel leaves the ground, you can lessen rudder input.
Pat
Old Aug 22, 2009, 12:56 AM
GiusedtoBe is offline
Find More Posts by GiusedtoBe
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
Originally Posted by ryramZ
Hey thanks guys, I'm using a dubro a spinner with a backplate and my shaft is fine, you should see the cowl though it is split and taped up, and to be honest my tape job isn't the best. I think that is what makes the noise. Thanks for the advice guys, my new one is ready for paint very excited, i haven't been able to fly my p40 that is in the video because i broke my motor mount it was the eflite type that is no longer manufactured, so i'm grounded on that one until i find time to do serious modification {ie} add firewall..unfortunately i drilled out the lower stick position to allow air flow around my esc so i can't use the gws motor mount like i am on my new one,
BUMMER, good thing is my new one is almost ready..been flying my gws t6 a lot, also the PT 17 except i have taken off the top wing and fly it like a PT 19, i miss my P 40..
Mine is louder now too with the "modded" cowl! Same Dubro spinner. I have two new cowls but haven't taken the time to paint them yet. Nice vid. My P-40 is probably my favorite flyer right now.
Regards,
Alan
GiusedtoBe is offline Find More Posts by GiusedtoBe
Old Aug 24, 2009, 11:11 PM
ryramZ is offline
Your Pilot Ryan
ryramZ's Avatar
Joined Nov 2008
Regards,
Alan
My P 40 is my only flyer right now, my T6 had a fatal crash yesterday i was in an inverted loop and half my wing flew off. Foam shrapnel everywhere. EPO T6 on the way. Anyhow having lots of fun flying my P 40 again after finding the mount I needed.
Old Aug 27, 2009, 01:40 PM
Condre' is offline
Find More Posts by Condre'
Lexington, Ky
Joined Apr 2004
I asked this question a while back but got no answers. What is an appropriate sized stearable tailwheel assembly that is suitable for use on a GWS 40?
Condre' is offline Find More Posts by Condre'
Old Aug 27, 2009, 03:21 PM
sebsoupe is offline
Find More Posts by sebsoupe
sebsoupe's Avatar
Bourg-en-Bresse, FRANCE
Joined Mar 2005
cyano + EPO = OK???
Hello!
Iwould like to know if it's possible to glue the EPO P40 (or T6/FW190) with cyano (instead of GWS glue) ???
sebsoupe
sebsoupe is offline Find More Posts by sebsoupe
Old Aug 27, 2009, 06:38 PM
ryramZ is offline
Your Pilot Ryan
ryramZ's Avatar
Joined Nov 2008
Originally Posted by sebsoupe
Hello!
sebsoupe
I use ca on my epo and it works just fine. i also use the gws glue at first to glue things together and then the ca to hold it in place.
Old Aug 27, 2009, 09:45 PM
iscozky is offline
Los Angeles, CA
Joined Aug 2008
I used dubro tail wheel assembly like an inch long and 1/2 in. wheels.
Old Sep 04, 2009, 09:31 PM
smoothb10 is offline
Find More Posts by smoothb10
United States, CO, Colorado Springs
Joined Jul 2004
here is my russian p40 flys great. I made mine nice and light with an 860 mah 3 cell flys for 7 min. It flys better with a standard gws 3 blade prop instead of the one the kit came with.
smoothb10 is offline Find More Posts by smoothb10
Old Sep 10, 2009, 05:05 PM
chris03 is offline
Find More Posts by chris03
chris03's Avatar
Germany
Joined Dec 2006
hallo together,
I would like to introduce my Warhawk of GWS to you with pleasure.
I have selected to me the model flying tiger. The model weighs approx. 690gr.
I have hardened the surface with parquet varnish and silk paper
As an impulse I use a GWS 3008/16 with 2200 3s zippy's and HXT Servo's.
The cockpit must be still built, then follows maiden
Once again I am very contented with the quality of GWS and surprises how simply build his is able
I hope, she likes you
Greetings from germany
chris03 is offline Find More Posts by chris03
Discussion ****GWS-40: The Never-Ending Legend of Flying Tigers**** RAY GWS Product Announcements 2 Sep 01, 2007 10:45 AM
NIB GWS 40 EDF units bruff Aircraft - Electric - Airplanes (FS/W) 2 Sep 10, 2004 09:39 PM
hypethetical idea re: a never ending e-flight Dax Parkflyers 7 Feb 20, 2003 05:24 PM
Flying Tigers AVG dottney Scale Kit/Scratch Built 2 Feb 13, 2003 10:45 PM
Never ending problems adam_jorgensen Electric Heli Talk 7 May 28, 2002 12:51 PM
