Espritmodel.com Heli Air
Old Jun 20, 2007, 08:01 PM
cytochrom's Avatar
Phoenix Deer Vally, Arizona, United States
Joined Sep 2004
Build This! ( My First Forward swept wing)
Yep. Another F/S wing. But this one is a little different ,flies and glides great!
so I decided to post some pictures.
Here are some specs.
WS 28.5" motor Eflight park250
length 17. 0" prop gws 4 x 4
AUW 6.4 Oz battery TP 350-480 3S
It is not a speeder (est.45mph). Its got dual elevons and handles well .
I WANT TO ADD THIS TO THE SHOW US YOUR WINGS THREAD
Hope you like it
Ed
videos here:
http://www.rcgroups.com/forums/showt...51#post7692006
RC Eds Forward Swept (3 min 46 sec)
cytochrom is offline Find More Posts by cytochrom
Old Jun 21, 2007, 12:10 AM
Mum is the word!
Joined Jun 2003
That is sweet ,I made one a while back that looks verry simular to that.I called the flyin W.
I love the way the fs handle.
I Have ben working on a design that is so close to that it is erie to see what you built.
Elevators on he back and ailerons on the outboard fs.
I have to say verry cool.
Thnx for sharing.
ck
klique is offline Find More Posts by klique
Old Jun 21, 2007, 01:54 AM
cytochrom's Avatar
Joined Sep 2004
Thank you Chris.(I hope you werent to bothered by that guy going through your trash that night)
I looked at every F/S wing thread that I could find as I built this so there is no way that there isnt some of your influenceand that of many others in this.
The choice of the 250 instead of a medusa 12mm gained 3gms at the expense of at least 25mph prop speed and a little more than 1/2 ounce of thrust. Guess I know what the next one will be powered by(the 4000kv medusa)
chris how about a sneak preview peek of yours. Im sure that Its a performance beast!
Old Jun 25, 2007, 09:03 AM
cytochrom's Avatar
Joined Sep 2004
video
Click here to see video !!!
Old Jun 28, 2007, 04:30 PM
cytochrom's Avatar
Joined Sep 2004
Im glad people have looked. I will start the build part in 7 days when I get back from vacation.
Ed M.
Old Jul 06, 2007, 06:39 AM
dougmontgomery's Avatar
Glendale,Az.
Nice work Ed, looks 10 times more stable then my forward swept. Videos make it look like it goes wherever you point it. Looks Racey!
Doug
dougmontgomery is offline Find More Posts by dougmontgomery
Old Jul 09, 2007, 03:48 AM
cytochrom's Avatar
Joined Sep 2004
doug thanks
I wanted to try to give some better idea of the dimensions of this palne but I have only low tech hand drawn plan. hope that you can make out some detail.
I will add pictures soon and this build could use any input towards simplification in building.
Ed
Old Jul 09, 2007, 09:09 AM
flyingwings's Avatar
Joined Feb 2004
Originally Posted by cytochrom
doug thanks
Ed
Ed
That is a great design.
Your looping video didn't appear to work.
Thank you for posting the plan view.
Paul
flyingwings is offline Find More Posts by flyingwings
Old Oct 07, 2007, 01:17 AM
Glendale,Az.
Thanks Ed, Here is my rendition in the works
Fully hot wire cut eps-
painted with design masters yellow,orange, and red and black
i will be consulting when I get the fiberglass completed.
Wish me luck, maiden in a week with an arc 80
Doug
Old Oct 07, 2007, 08:23 PM
AMA 24317
bobthenuke's Avatar
United States, AZ, Peoria
Joined Feb 2005
Hey, guys
Doug dropped by for a visit and brought his rendition of Ed's wing with him for a show and tell. All I can say is that it's a whole lot nicer in real life than the pictures let on. Between Ed's great design and Doug's skill with a foam cutter this is turning into a *very* interesting and cool wing. I think I may want one (hint hint to Doug).
...bob
bobthenuke is offline Find More Posts by bobthenuke
Old Oct 07, 2007, 10:40 PM
cytochrom's Avatar
Joined Sep 2004
I Agree with Bob
Doug can make some awesome craft. See his creations. The Tearadon, Slo Wyte are two of my favorites. Cant wait to see more
Here are 2 variations from the show us your wings thread
Old Oct 09, 2007, 12:29 AM
Glendale,Az.
Ready for motor mount and motor
3 cell kokam 740mah
castle 25 esc
arc 80 preliminary motor
2 dymond 60 servos
will attach poly tubing to body for pushrod support
cg balance is close @ 8.5" from nose
fg with 1.5 ounce fg and mgs epoxy
kevlar live hinge elevons
Old Oct 09, 2007, 06:40 PM
Glendale,Az.
Complete
I am trying a new prop attach method- Gavin in Ohio told me about using a 10 pinion spur gear, I heated it up with soldering gun, pressed the prop onto it and then dunked in water.
I will try to maiden tonight?
Doug
Old Oct 09, 2007, 09:43 PM
Glendale,Az.
First couple of throws consisted of a nice level fast glide,
a nose heavy elevon flyer, it would not not turn. I gently backed off on throttle and brought it down.
After removing some nose weight,(twice)
then we went of the grassy side of the field)
Ed threw perfect level throws every time, powered up and at 1/2 throttle it was traveling between 50-60mph. WHEW...I had the shakes slightly trying to still bring the nose up I ran out of throw with the single ouboard elevons. A change from Eds original design having inboard elevons also.
I will re- adjust the battery and esc to move the weight towards the back a little.
This forward swept was very stable at high speeds, and I will be changing the 4025 gws prop out for a apc non-flexing prop. 1/2 to full throttle did not have a significant speed change, it was just FAST at 1/2 throttle.
Please reply if interested in seeing a Video, stay tuned.
Thanks Ed for the magnificent design. Is there a name yet???
Doug
Old Oct 10, 2007, 12:28 AM
cytochrom's Avatar
Joined Sep 2004
WoW
It was so cool to see Dougs wing fly at least 2 x the speed of mine and that was 1/2 TO 3/4 THROTTLE ! I had more fun cause all I did was toss and watch. When doug gets video You'll Like it
I hope Someone else makes a .............. (I guess I will have to give it a name) and posts it. The foward wing makes an extremely stable plane. The 20 and 22 inch planes prove its no fluke.
My build tech is not so hi tech I use some wood foam and reynolds plastic wrap but if someone wants Ill post pix
Doug made hot wire foam combo and thats a lot faster .
Cool Anhedral Forward Swept Wing Build Mythical D3 Flying Wings 12 Jun 03, 2008 02:30 PM
Forward swept wing. Any interest? birdofprey Slope 19 Dec 27, 2007 05:32 PM
Overlord Build Thread - My first wing. Bernoulli~Bros Flying Wings 79 Aug 15, 2004 05:50 PM
All EPP forward swept wing birdofprey Foamies (Kits) 29 Mar 30, 2003 03:11 AM
Need some advice on a Forward Swept Wing ke6guj Slope 16 Dec 22, 2002 11:13 PM
