Joined Jun 2007
Should i get this plane as first one.
This would be my first big one other than my aero aces.
http://cgi.ebay.com/NEW-MODEL-CESSNA...QQcmdZViewItem Or should i go with something else. Tell me what you think. |
Probably not as your first 'proper' model. The Cessna is an aileron model with no, or little, dihedral to help with self correction.
Unless you feel you can fly good enough already to handle it and have built up a lot of experience. If your a regular reader here, you should know what the usual recommended models are for a first timer. Have a serious think before committing to the Cessna if you really want it. |
The Slo-V is a GREAT beginner plane, but if you don't like flying that slow, then I would recommend getting the Multiplex Easystar or the Hobbyzone Supercub. Both of them are about $160 and they are both RTF's. Also, don't waste your money buying planes on Ebay. I would say there is a 90% chance that the planes on Ebay won't work. Unless they are from a well known airplane company. So, even though you have a lot of time on a simulator, I would still suggest getting the two airplanes I recommended above. If you get either one of them, you WILL be happy and you'll enjoy this hobby way better. |
Joined May 2007
How about getting a GWS E-Starter? It's an excellent aileron trainer. Stable flier, cruises at low speeds, and can do loops and rolls whenever you're ready!
Orchard www.insanehobbies.com |
That plane looks (from the video) like it may fly OK, but here's the problem:
After your first crash (95% chance it will be 1:30 into the first flight, 5% chance it will be 2:00), where are you going to get spare parts for anything that can't be hot-glued back together? You can't because you bought the plane off e-bay. And now you're out $80. Trying to save money seems so important when you start (believe me, I did it too), but when it comes down to it, you will be much better off spending 2 or 2 1/2 times the money on: Hobby Zone Super Cub RTF Easy Star RTF GWS E-Starter RTF Package I would not buy that plane. |
For $40 LESS you can get a Wing Dragon. http://www.hobby-lobby.com
sterling, Illinois
Joined Feb 2006
I've just been thru this delema as rusty on flying, only few sailplanes not powered and this was many years ago, fortunately found sites as this one and the Super Cub mentioned fortunately bought this wonderful trainer with 100 per cent success, over 16 flights todate, no problems other than usual pilot errors, and this Super Cub is thrill to fly, 15 to 20 minute flights by lowering the throttle, do lazy loops, takes right off the pavement and still doing grass landings, told you I was rusty. its The Winner...Bar none..<>..
Have the Decathlon 480 and super buy at $109 but does not fly out of the box, less forgiving on the controls, now considering if to replace the motor as plunged it in too hard damage to shaft etc, did manage 4 good flights but will drop a wing quickly on your learning stages, not the trainer...like it for a 2nd plane, considering replacing the motor... The Super Cub climbs quickly when trimmed right, fly in zero winds, I mean zero winds, occurs in evenings and very ealy AM'S, now fly in less than 5 MPH steady, gusty will give you fits.. So get the Super Cub and an accomplised pilot to insure success, my hands were full even with past flights... BEST WARREN Sterling, Illinois..<>. |
| Thread Tools | |
| Discussion Stop telling noobs to get Slow Stick as first plane | Luisfc1972 | Beginner Training Area (Aircraft-Electric) | 852 | Jan 12, 2008 10:07 PM |
| Split 280: Should I retire this plane (brick) ? | temp_oct | Parkflyers | 26 | May 03, 2004 06:18 PM |
| Where can I get this plane in foam ? | livinma1 | Parkflyers | 0 | Jan 05, 2004 07:56 AM |
| Hi,i m a newbie,should i get this transmitter? | nadelect | Beginner Training Area (Aircraft-Electric) | 6 | Jun 03, 2003 09:20 PM |
| Help - Where can I get this Plane? | dave_beardsley | Sport Planes | 4 | Apr 17, 2002 02:41 PM |
