Old Jun 19, 2007, 09:47 AM
Ron Paul - 2008
Joined Jun 2007
maintaining altitude with HB FP
I've been learning to fly a HB FP 3 and while I can hover tail in well, side in OK, front in not at all (lol), and fly circles (as long as I keep the tail pointed roughly in my direction). But I have noticed its kind of difficult to maintain altitude while hovering and much more so while moving the heli around. I'm assuming this is due to slight winds generating lift on the blades, and a loss of lift when tilting the blades to move the heli around.
My question though is does this happen on all the heli's or will the more advanced and slightly larger CP heli's hold altitude better and drift (tail drift especially) less? I've been tempted to buy a Trex 450 and Spectrum DX7 so I guess I'm looking for excuses
bp
bp_968 is offline Find More Posts by bp_968
Old Jun 19, 2007, 10:02 AM
Rave heaven
Chicago surburbanite
Joined Nov 2006
did you get rid of the ratchet on the TX? sometimes that causes some bad throttle control.
Later
Eric
helitaiwan963 is offline Find More Posts by helitaiwan963
Old Jun 19, 2007, 10:03 AM
raz
Too sexy for my shirt
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
Some one correct me if I'm wrong but I believe it happens with all electic helis. When you turn it's taking power away from the main motor.
raz is offline Find More Posts by raz
Old Jun 19, 2007, 10:07 AM
Things go better with joke
Pleasant Valley Modelport
Joined Sep 2006
It happens on all electric helis. The CP models respond much faster to altitude control and that makes the difference. Usually a moderate forward speed keeps my FP flying smoother, and you need to remember to slowly advance the throttle as you slow down to keep from dropping.
CH
Chophop is offline Find More Posts by Chophop
Old Jun 19, 2007, 10:25 AM
www.rctodayshow.com
JustPlaneChris's Avatar
Austin, TX
Joined Sep 2005
Slight wind gusts will definitely cause the FP to climb, and sometimes they will "push" it down as well. Maintaining a constant altitude is more challenging with a FP heli, compared to a CP, because you have to rely on the main rotor to speed up or slow down in response to your throttle changes. This lag makes you basically have to "think ahead" of the heli, where a CP reacts to changes much quicker since you are actually changing the pitch of the main blades, rather than the rotor speed. Banking the heli also requires more pitch/power to maintain altitude, since you've changed the angle of the lift vector from vertical. This is common to all helis, not just electrics.
-Chris
JustPlaneChris is offline Find More Posts by JustPlaneChris
Old Jun 19, 2007, 11:22 AM
Ron Paul - 2008
Joined Jun 2007
Thanks for all the info guys.
Rant Got a HB FP with a 41MHz Tx & Rx... avt Micro Helis 0 Feb 15, 2007 03:31 PM
Question Phoenix-10 with HB FP, CP2 or BCP Heli's Tweekster Castle Creations 4 Jan 07, 2007 07:50 PM
Question Looking for a dealer with the HB FP barebones in stock... jettvolks Micro Helis 0 Dec 24, 2006 09:19 PM
Yippee! HB FP Backwards at last! (with video) Pigs dont fly Micro Helis 11 Aug 26, 2006 07:02 PM
Question Help with HB Elite FP ESC's RoNeRiC Micro Helis 0 Mar 11, 2005 11:30 AM
