Go Back   RC Groups > Aircraft - Exotic and Special Interest > UAV - Unmanned Aerial Vehicles
Old Jun 18, 2007, 12:52 PM   #1
Send a message via AIM to rclinks2002 Send a message via MSN to rclinks2002 Send a message via Yahoo to rclinks2002
Looking to buy UAV airframe
Hello all
I am looking to buy a prebuilt UAV airframe if anyone has an extra collecting dust. It needs to have a speed of at least 40mph and have excellent low speed characteristics. (very short runway) Please contact me for more details. Thanks
Ben Mitchell
rclinks2002 is offline Find More Posts by rclinks2002   Reply With Quote
Old Jun 18, 2007, 02:32 PM   #2
Weekend flyer
Munin's Avatar
Hello Ben
Your profile location is very interesting. The Kunar province is bordering
to Pakistan.
Are you looking for noisy gas or silent electro.
IMO buy an of shelf plane/glider and mod it UAV.
Then you got a plane with aspects of your desire and config/mission type.
/Munin
Munin is offline Find More Posts by Munin   Reply With Quote
Old Jun 18, 2007, 09:54 PM   #3
Yep The good old Kunar province.
At Present, an electric plane is in use, but it is simply too slow for safe /effective operation.
Ben M
Old Jun 18, 2007, 11:51 PM   #4
We have a twin boom Zenoah powered airframe. What are your budget constraints?
CenTexFlyer is offline Find More Posts by CenTexFlyer   Reply With Quote
Old Jun 19, 2007, 06:53 AM   #5
CenTex,
I think an airframe with a zenoah engine is too big/loud for my application. I am looking for an airframe that can support an Axi 41 series motor and can take off in 40feet or less (with full power run up of coarse) Additionally, a payload of about 4-5 lbs would be sufficient. (almost overkill)
Ben Mitchell
Old Jun 19, 2007, 09:18 AM   #6
Eyes Overhead
RaptorAP's Avatar
You need a SIG LT-40. The AXI 41 series is recommended for it and I love to fly mine, even autonomously! I moved all servos to the rear and out on the wing and it has plenty of room inside for gear.
  • Name: IMG_0006sm.jpg
  • Name: IMG_0007sm.jpg
  • Name: IMG_0008sm.jpg
  • Name: IMG_0001sm.jpg
RaptorAP is offline Find More Posts by RaptorAP   Reply With Quote
Old Oct 31, 2009, 11:46 AM   #7
F-35 LighningII Jet Airfame for Sale
Originally Posted by rclinks2002 View Post
Hello all
Ben Mitchell
I am a professional RC aircraft builder I have a 1/7 scale F-35 Lightning II airframe for sale it would make a great UAV, it is new and quality asembled with precision. If you are interested contact baby skunk at gregorytodd75@gmail.com or 862-250-9602 after 6:00 pm.
Baby Skunk is offline Find More Posts by Baby Skunk   Reply With Quote
Old Oct 31, 2009, 07:01 PM   #8
Gee, with Skunk in his name and 1 post to his credit this sounds like an offer you'd be crazy to pass up Ben.
Tarro is offline Find More Posts by Tarro   Reply With Quote
Old Nov 01, 2009, 04:47 PM   #9
CenTex,
Ben Mitchell
Check this out:
http://www.rcgroups.com/forums/showthread.php?t=859367
I have flown this beauty two seasons and one month ago crashed it because of RC control loss - i tried to get altitude record. It climbed in thermal raise 4m/s but at 1400 meters flown into cloud and was done.
Since it had really good flying behavior i decided to build it again and make molded negative form for fuse, CAD designed wing CNC milled from 4mm plywood. Profile for wing is still CLARK-Y and it is sufficient for flying, take off and landing of this baby.
One change will be made - V-Tail will be replaced with horizontal elevator and two rudders on booms - setting with some autopilots is not easy with this V-Tail configuration.
I didn't test it with more than 3lbs payload. Unfortunately i don't have recorded any flying video. But it flies really good even at low speeds.
Was powered with AXI 4120/20 + 5s 5000mAh, 70A ESC.
If you like it send me PM.
lospalos is offline Find More Posts by lospalos   Reply With Quote
Old Nov 01, 2009, 10:53 PM   #10
Where are you located lospalos, that's a really impressive airframe, are you going to sell it?
ram0207 is offline Find More Posts by ram0207   Reply With Quote
Old Nov 02, 2009, 04:04 AM   #11
Originally Posted by lospalos View Post
Check this out:
Hi Lospalos, Love your plane and construction. I am looking at similar power train to you but have a question as you have kit in question.
Looks like you have an Aeronaught folding prop with cooling type spinner. I have a AXI 4130 which is bulkhead not radial fitted in pusher config but am looking to get the same spinner as you with folding prop. Do you think there is enough clearence of prop if mounted to motor shaft plus 4.5mm bulkhead? Or if not is there anyway of making clearence with spacer etc?
Many thanks
Denham
DENHAMDULAKE is offline Find More Posts by DENHAMDULAKE   Reply With Quote
Old Nov 02, 2009, 05:29 AM   #12
Many thanks
Denham
Hi Denham,
as i haven't tried it in bulkhead configuration i can't answer your question. But prop is Graupner and is well shaped so i thing there wouldn't be a problem.
Old Nov 02, 2009, 06:26 AM   #13
Sorry, i'm just hobbyist not manufacturer. But when i'll have finished form for fuse, i can make more of them and prepare more CNC-ed wing profiles, perhaps assemble a few kits for persons interested.
I'm from Slovakia.
Old Nov 03, 2009, 03:56 PM   #14
Connexxion's Avatar
I think you'll find more people will be interested in purchasing this bird of you.
I know there are other guys in Europe who build UAV platforms,but they're asking "out-of-our-range" prices.
Connexxion is offline Find More Posts by Connexxion   Reply With Quote
Old Nov 05, 2009, 07:51 PM   #15
wbuttry
a uav can be any design you want it doesnt half to be the same design as anybody else make a uav is any kind of vehicle you can put autopilots sensor packs in and fly to sertin way points via gps or satelite tracking a lt 40 make a awesome uav so does a senior telemaster it float forever doesnt take much motor to fly either one the telemaster will carry 13 lbs of weight that why it uses struts on the wing panels and perfect camoflauge using a model plane anyway no one will suspect anything if they see it in the air they will think some kids are enjoying thyre hobby so do as you want but thats the way i went i use a easy star from multiplex at 75 dollars if lost no problem auto pilots gotten so small u can fly it in about anything .
wbuttry is offline Find More Posts by wbuttry   Reply With Quote
Question Want to buy uav composite airframe wadiprawita UAV - Unmanned Aerial Vehicles 23 Aug 30, 2006 06:56 AM
looking to buy an old car dave morris Life, The Universe, and Politics 16 Aug 17, 2002 12:35 PM
Looking To Buy Tiger Moth charlatan Parkflyers 3 Jun 24, 2002 04:22 PM
Looking to buy mini laser 3d rpsmtihii Electric Plane Talk 4 Dec 13, 2001 08:44 PM
Microsoft Xbox I have Two anyone looking to buy one or both? gbagley Life, The Universe, and Politics 0 Dec 05, 2001 11:24 PM
Bored? Want to fight?
Join the RCGroups clan!
