Old Jun 18, 2007, 10:53 AM
PeterO_UK is offline
Find More Posts by PeterO_UK
PeterO_UK's Avatar
Joined Aug 2006
Multiplex Gemini
I hope to be picking mine up from LHS on the way home this evening
Peter
PeterO_UK is offline Find More Posts by PeterO_UK
Old Jun 18, 2007, 05:07 PM
samuel s. is offline
Find More Posts by samuel s.
belgium
Joined Aug 2006
and??
any news?
is he already in shops? if i look at the online shops, he aint in stock :P
i cant wait!
samuel s. is offline Find More Posts by samuel s.
Old Jun 19, 2007, 05:12 AM
PeterO_UK's Avatar
Joined Aug 2006
Yes, I got mine yesterday
It's about half built now
I've found a few minor errors in the manual though... Mis-numbered parts on the parts diagram, No mention of having to cut down the cockpit screen to size, but the build quality is up to the normal MPX level.
Assembly is quite straight forward. The only tricky bit (so far) was bending the tail wheel wire into shape. The way it is fixed to the fin looks rather weak so I used some off cut elapour to make it stronger.
I went for the MPX power set as well so no modifications needed to get the motor to fit like I had with my Twinstar II.
I'll add some pictures when I've cropped and resized them.
Peter
Old Jun 19, 2007, 07:05 AM
belgium
Joined Aug 2006
man, i cant wait, going to buy this bird in like a week or two, i rahter prefer big scale looking airplanes, but this one flys just to smooth (as i saw at his movie )
hury up for the pictures will ya?
Old Jun 19, 2007, 02:15 PM
belgium
Joined Aug 2006
any news?
Old Jun 19, 2007, 02:19 PM
!@#$%^&*(!) is offline
Find More Posts by !@#$%^&*(!)
Joined Oct 2006
Photo's
!@#$%^&*(!) is offline Find More Posts by !@#$%^&*(!)
Old Jun 19, 2007, 06:20 PM
PeterO_UK's Avatar
Joined Aug 2006
Here it is Still needs ESC,battery and radio to be fitted, but CofG looks fine with them "placed" in the fuzelarge.
Servo throws and trims still need to be set up as well.
Peter.
Old Jun 20, 2007, 06:51 AM
belgium
Joined Aug 2006
so you are using the multiplex powerset?
and can i asc where you bought it?
i only can see that the gemini is in stock on several internet shops, but the powerset not yet
bummer :P
is it possible to make some detail pics to?
like the tail section and the inside of the plane to see wath space is in it.
btw, thanks a lot for the pic! i think its the firts building pic of the gemini on the whole WWW :P
best regards
ps. i hope you dont mind if i post ure pick on modelbouwforum.nl?
Old Jun 20, 2007, 06:55 AM
belgium
Joined Aug 2006
ohw, can i ask you how you can dismantle the wings?
it has to be a very strange mechanism to do that :P
or is it not possible with the gemini?
grts
Old Jun 20, 2007, 07:04 AM
PeterO_UK's Avatar
Joined Aug 2006
Yes
From Galaxy Models in Ipswich (my local model shop) http://www.galaxymodels.co.uk/new/index.asp
bummer :P
Yes I'll post some more when I've finished putting it together. I've been taking pictures during the build.
best regards
No problem as long as you give me a credit for the picture
Peter
Old Jun 20, 2007, 07:10 AM
PeterO_UK's Avatar
Joined Aug 2006
grts
The top and botom wings are glued together, so the process is to unbolt the wings from the fuzelarge (one bolt for top, one for bottom), gently spread them apart and slide the fuzelarge out backwards. Servos will need to be disconnected.
I've not fitted the radio reciever yet, but one option is to mount it on the top of the bottom wing with in the fuzelarge, in which case the rudder and elevator servos and the throttle lead to the ESC will need to be disconnected when the wings are removed. I think I will make up a little circuuit board like the one in the Twinstar II to make these connections easier.
Peter
Old Jun 20, 2007, 11:10 AM
belgium
Joined Aug 2006
ok, cool, we (modelbouwforum.nl) cant wait to see the other pics
Old Jun 20, 2007, 11:31 AM
PeterO_UK's Avatar
Joined Aug 2006
Check your PMs.
Peter
Old Jun 20, 2007, 01:47 PM
belgium
Joined Aug 2006
@peter: i hosted the pics via imageshack on modelbouwforum with youre credits also.
this is the link from modelbouwforum, with the pics from peterO_UK, so thanks again peter!
http://www.modelbouwforum.nl/phpBB2/...=801984#801984
Old Jun 20, 2007, 02:37 PM
belgium
Joined Aug 2006
new pictures added on the link from modelbouwforum.nl
this time with pics from forum.modelimse.com (thanks allot guys )
grts
Article Multiplex Gemini Biplane Review dawnron1 Parkflyers 68 Dec 16, 2012 10:35 AM
