Old Sep 18, 2007, 11:22 PM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
The 'how to' is awesome thank you. Now the big question is how much for a hand drawn template on vellum so I can cut templates? You are very talented at that. I can only draw mechanical drawings on a cad system. When it comes to free hand like that I get a big fat "F"!
Don
The Don is offline Find More Posts by The Don
Old Sep 18, 2007, 11:34 PM
IPFlyer is offline
Find More Posts by IPFlyer
Joined Nov 2005
We have a winner folks!! AMAZING!!!! You know, someone needs to make a shaped fuselage for that bird...
IPFlyer is offline Find More Posts by IPFlyer
Old Sep 18, 2007, 11:44 PM
Maybz is offline
Find More Posts by Maybz
medium-sized Lewbowski
USA, CO, Denver
Joined Jan 2005
Agreed. A molded EPP fuse would be awesome. Someone tell Multiplex to get busy!
Maybz is offline Find More Posts by Maybz
Old Sep 18, 2007, 11:56 PM
Andy2No is offline
Find More Posts by Andy2No
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
Thanks for the how-to, Maybz. It's very well written.
I think I'd have to do something much simpler but seeing the techniques you used helps a lot.
Maybe I'll go for something more stylised than realistic, because I don't have that sort of skill. I've been noticing lately how easy it is to see the orientation of magpies in flight. I thought of painting a plane to look a bit like one, but an EPP Eagle would be better.
European Magpie (Wikipedia entry)
Andy2No is offline Find More Posts by Andy2No
Old Sep 19, 2007, 01:00 AM
diver don is offline
Find More Posts by diver don
"Each Day Is A Lesson"
diver don's Avatar
Goldsboro, NC
Joined May 2004
Placed my order tonight.
Just moved to NC so this should shake up the local wildlife.
DD
diver don is offline Find More Posts by diver don
Old Sep 19, 2007, 03:21 AM
deadduck is offline
Find More Posts by deadduck
Manila Ninoy Intl, Philippines
Joined Nov 2001
Just got mine ( 2 ! ) a few minutes ago.
Maybz - wonderful tutorial on painting.
Andy2No - the magpie scheme looks good.
I am going to work on the front end to try to get a folding prop to fit.
I'm thinking a Blue Wonder 1100KV with a 9 x 5 folder on 3S?
This taiwanese EPP is interesting, it has a different texture to the european epp and chinese molded epp that I have seen. Maybe as a result of how they make or cut the sheets?
The beads in the foam look smaller and feels more grainy. I'll be using my favorite chinese foam goop to assemble this.
deadduck is offline Find More Posts by deadduck
Old Sep 19, 2007, 04:58 AM
deadduck is offline
Joined Nov 2001
Quick test for folding prop
I laid out the bottom of the fuselage.
Placed a piece of masking tape to match the position of the firewall.
Using the HXT motor mount with the Blue Wonder 1100kv.
That's an MPJet Super Cool Spinner with a 40mm pitch (the distance between the blade pins), 3mm collet (matches BW shaft) and 9 x 5 folding blades.
Looks like it will fit and the blades will fold ok in the horizontal plane which is the widest part of the beak.
Update
Ok here's a partially assembled beak. This is STOCK, no modifications to the foam.
It really looks as if a 40mm pitch folder will fit okay.
Old Sep 19, 2007, 05:06 AM
tdearth is offline
Find More Posts by tdearth
USA, IN, Nineveh
Joined Apr 2002
Great job Maybz, thanks for the tutorial.
Tim
tdearth is offline Find More Posts by tdearth
Old Sep 19, 2007, 05:22 AM
rcminh is offline
Find More Posts by rcminh
United States, CT, Torrington
Joined Jun 2006
Maybz,
You're a true Leonardo DiVinci. Your paint job is one of the kind.
Rcminh
rcminh is offline Find More Posts by rcminh
Old Sep 19, 2007, 06:11 AM
scatcat1 is offline
Find More Posts by scatcat1
If it flys I can crash it!!!
scatcat1's Avatar
Townsville, Australia.
Joined Jan 2007
Deadduck,
Shape is looking good, will be interesting to see if you can keep the eagle beak shape. Would be great if it works!
cheers, Paul.
scatcat1 is offline Find More Posts by scatcat1
Old Sep 19, 2007, 10:57 AM
diver don's Avatar
Goldsboro, NC
Joined May 2004
Right now I'm finishing up a 12' Telemaster so this should come in at the right time.
Question:
This is my first foamy so what type of glue do you use on this type material?
DD
Old Sep 19, 2007, 11:02 AM
IPFlyer is offline
Joined Nov 2005
EPP can be glued with regular CA and kicker. But I like UHU Por (prolly the same stuff as in the can shown above!). Epoxy is too heavy.
Old Sep 19, 2007, 11:53 AM
diver don's Avatar
Goldsboro, NC
Joined May 2004
Thanks for the reply.
Does anyone in the US carry this product , and if not, is there a available alternative?
DD
Old Sep 19, 2007, 03:22 PM
gentle ben is offline
Find More Posts by gentle ben
semper mitis
gentle ben's Avatar
Paducah, Kentucky
Joined Nov 2004
I use Michael's to get my UHU Creativ which works well on my LiteFlite Bug EPP.
gb
gentle ben is offline Find More Posts by gentle ben
Old Sep 19, 2007, 03:27 PM
Steve_A_Reno is offline
Find More Posts by Steve_A_Reno
Planes, Guitars and Cigars
Steve_A_Reno's Avatar
Joined May 2002
There is also a white breasted sea eagle
Black on back - Would stand out nice in the sky and easy orientation
Steve_A_Reno is offline Find More Posts by Steve_A_Reno
Discussion EPP Eagle fuzzyhead Foamies (Scratchbuilt) 2 Sep 28, 2008 09:54 AM
