my local dealer handles this make of motor so hopefully it will be readily available .... http://www.jperkinsdistribution.co.u...rs%20-%20E-Pro |
Just shot some on board vid today with my eDVR 5-in-1 (see the pic in post 596). Went well but the Eagle handled like a pig - turbulance over the tail feathers I suppose. Will shoot some more tomorrow and then throw a vid together. KiwiKid |
My Eagle weighs about 22 1/2 ounces or 640 grams RTF with battery, lots of paint, it is quick, to quick with the 480 grams of thrust i have on the 2 cell, that motor weighs about the same as mine, I had to put 14 grams right inside the nose and the battery all the way in front, it was eradic until I put that extra 14 grams in the nose inside againest the motor mount and my battery weighs 3.88 ounces or 110 grams, as far as i could put it and then it flew perfect. |
thinking about ordering another Eagle but modifying the nose to look like this.
really like the eagle but just change it to a diffront bird, leave every thing the same but the nose of it I just ordered another one to paint up like this great horned owl, in the process of making the nose on the eagle I have now, will be a real bear to paint up like the owl but going to whack at it, instead of using foam for the ears I am going to mount 2 feathers for the horns, I did some more carveing on the adaptor of the owl head that I have pictchured below, rounding it and blending it to fit the eagle front, won't look to bad the photo of the owl head is one I glued to a foam block to see how it would fit and look, it will be peeled off and paint in the face with 2 feathers for ears |
I have been thinking along those line too - making an owl or a seagull, but using the existing wing and making a body out of sheet epp or blue foam. The brown backed gull we have in NZ is quite like an Eagle anyway and a rounded body would make it look a bit more scale
KiwiKid |
Joined Dec 2005
I'm really hooked on the videos and the great artwork. I hope to get the Eagle one of these days. Had I discovered this thread earlier, think I would have gotten one; I'm currently building the Easy Star. Has anyone found the Eagle for FMS? Sure like to give that a try. Thanks!
second one is my open battery hatch with a piece of blue foam glued accross to keep the battery from sliding and the blue black blob all the way to the left and is part on side wall and motor mount is 14 grams of clay instead of sticky tape at the servos hot glue would work and hot glue the pink foam block also, I just like to work slow so I used the sticky tape and GWS glue, I would not use epoxy, Hope these photos help, I looked quite a while before I did mine, wished I Had a photo when I did mine, would have saved a lot of looking and time |
Rcminh:What did you use for the eyes on your eagle? Azarr www.ecubedrc.com |
| Thread Tools | |
| Discussion EPP Eagle | fuzzyhead | Foamies (Scratchbuilt) | 2 | Sep 28, 2008 09:54 AM |
