On most of these low $ motors, the wires going into the motor are extremely thin and unsecured. I noticed this while upgrading my Slo-V to brushless. I asked a similar question on how to secure these wires and got good suggestions here. I ended up using Permatex Hi-Temp RTV Silicone Gasket Sealant (black)...basically high-temp silicone. I got it at AutoZone. I used it sparingly (applied with a toothpick) and so far the results are good. Hope the suggestions (and warnings) in the thread help. Rob |
I don't think the motor is underpowered but I could be wrong. The specs follow: (not my tests but Dan at Lazertoyz. The prop was an 8x4. If anything it was underpropped a tiny bit. Motor specs and info. 2 cell 9X4.7 12 oz thrust 6A (45 watts) 2 cell 8X4.3 11 oz thrust 38 watts) 3 cell 9X4.7 20 oz thrust 10A (115 watts) 3 cell 8X4.3 19 oz thrust 7.5A (85 watts) ....... As always I admit to very little knowledge or experience with electric power so what all of you say is probably true and I am wrong. It won't be the first time. I am learning though thanks to responses from you all. |
Update. My friend advised me to tie off the leads with thread for strain relief. He has vast experience in electric power and prefers the stick mounts to the firewall mounts.. He also did some thrust testing: 2-cell--T---A 7060 6.0-4.3 8040 7.5-4.0 8060 7.7-5.0 9050 9.6-5.4 3-cell--T---A 7060 11.5-7.0 8040 13.0-6.0 8060 14.0-8.8 9050 16.0-9.0 Here is a photo of his strain relief for the motor leads. |
Mick,
Thanks foryour praise and sharing. I am looking forward to seeing some of your eagle flying photos or videos!! rbrown3rd, With the following recommended parts, the EPP Eagle should have very good flyping performance and better mobility. 2208~2212 /900~1100kv prop 9050 2~3cell 500~700 thrust max 14A 20A ESC I am also learning new information liike everyone else. If there are questions or suggestions, please feel free to post it for discussion!! Flyparty |
The BlueWonder is capable of all that, but not for very long at all, due to the low weight. Lightweight motors can only take brief bursts of power before they overheat. I've read other cases of Blue Wonders burning out, flying fairly light planes. They're really most suitable as a shock flyer motor, where the current is below 3A a lot of the time, and goes over 6A only in very brief bursts - like a quick aerobatic flourish before the tiny lipo those things use gets drained. The heat created by a motor is I*I*Rm where I is the current and Rm is the armature impedance aka internal resistance of the motor. For a Blue Wonder, the Rm is on the high side. The capacity for a motor to dissipate heat is limited by the weight of metal in the motor. For a BW, that's on the low side. A short of the wires leaving the motor could well destroy your ESC, but would leave the motor relatively undamaged - apart from possilble scarring at the site of the short. Shorter version: As FLYPARTY (the designer of the EPP Eagle) said, that motor really isn't up to the job. Depending on how you propped it, it would burn out sooner or later, just by doing a normal climb to altitude. A motor weighing 70g-100g would not be out of place on a plane as big as the EPP Eagle, though a good quality 45g motor, with low Rm, would do well enough. |
Thanks Andy2NO. I appreciate the advice. As I have said I have been building and flying models for fifty years starting with balsa and tissue but foam and electricity are all pretty new to me. I don't really have a feel for the motor sizes and how to match them appropriately to the plane. I am not a power flyer but prefer to just float around at low throttle settings. I am primarily a glider pilot so my knowledge of motors is begging. Thanks to all for your advice and help. I will eventually get the ship powered appropriately.
What are everyone's recommendations. Remember, I don't like high powered flying but rather floating around lazily. Update. I did find a pretty good glow vs. electric comparison table here. Quote:
I did some quick test flights this morning before the storms started. I flew a number of circuits. Climb, circle for a while. Passes up and down the field and then land. The controller felt warm but not hot The motor was cool to the touch. I found that I could fly around with extremely low throttle settings which I like. I changed to a larger prop too. I used a 9x5 instead of an 8x4. The prop is the black GWS 0947 EP model. Flight is now extremely quiet. I need to restrict full throttle on my transmitter though as the Eagle climbs like a rocket with any thing more than about 15 percent throttle settings.
I think I built in about the right amount of down thrust but maybe too much right thrust. But, to clarify that, at the very low throttle settings necessary to sustain level flight the ship flies about neutral. Higher power settings create a turn tendency. Nice ship. Flies really smoothly with some throttle. Gliding requires a lot of control movement unless you keep the speed up. I am having fun with it. |
I've never really worked out whether the thrust angle correction can make it perfect at every throttle setting, or whether it's just to correct for an average. A lot of i.c. pilots I know only ever seem to use full throttle so they'd never notice. Incidentally, I started learning about motor selection by using Motocalc from http://motocalc.com. Once I got the basics from that, I took to using the free PeakEff graphing system.. Here's an example, using the manufacturers data for the motor I fitted to my EasyStar: http://www.peakeff.com/GraphKIR.aspx...&title=2212-06 I gave that example because it's one of the few cases where the manufacturers data actually came close to my own measurements I settled on a 6x3 with a 3s lipo. A 6x4 with a 2s lipo woud probably have done quite well enough (change the voltage box to 7V or 6.5V to see the difference, then press Update Graph).The problem is, they tend to exagerrate how good their motors are by claiming a lower Rm than they really have. A lot of them don't even give the figures you need. There are just four figures needed to describe any brushless motor: weight Io (idle current) Rm (armature winding impedance aka internal resistance) Kv (rpm per volt, unloaded) If manufacturers all gave us those figures, accurately, choosing motors would be an exact science. As it stands, recommendations are probably better, provided they're from people who've taken the time to measure the WOT current and rpm with the prop they're recommending to go with it. I have a little box full of motors I've chosen for things based on the manufacturers spec, but had to put aside for other projects once I'd measured how they really perform. Incidentally, balsa and tissue is still largely a mystery to me. It was the way things were built when I was a kid but I never really got to learn how it was done. I'm more comfortable with foam now. The weight saving seems well worth putting up with the shortcomings (like rigidity or fragility). Also, crashing even a polystyrene plane doesn't necessarily mean the end of it. Provided you get most of the big pieces, you can usually fix it with gorilla glue. |
No problem, rbrown3rd.
Although I no longer use Motocalc I really do recommend it for the educational value. I used it longer than the trial so I paid the license fee. I don't regret it. It was a good investment. Some of its recommendations should probably be taken with a pinch of salt but it definitely helps you get a feel for the subject. The most basic bit of electric flight equipment is the Watt meter (aka power meter). A good one gives you readings of voltage and current at the same time, and they usually show the watts (V*A) and mAh used so far. That lets you make sure you're operating everything within safe limits. The next most useful bit of equipment is a tachometer. These days you can get a handheld one very cheaply, which gives you the rpm. That lets you work out the pitch speed (theoretical limiting speed for level powered flight) and gives you an idea whether the plane will be fast enough with that prop, or so fast you won't use full throttle much, or very effectively. With a few sets of readings from a watt meter and tachometer, you can work out motor constants for yourself (Rm and Kv are the easiest), which helps with prop and motor selection since the manufacturers figures are usually way off. You can also use them to just keep trying different props and measuring the current and rpm til you get it about right, without understanding the theory behind it. The third bit of kit is a set of digital kitchen scales to get some idea of thrust. It's actually quite hard to measure thrust without good equipment, but a set of scales gives you some idea - you can usually assume you'll get more thrust than you can measure on the bench. One thing I learned from Motocalc is that props can be stalled if they are too high pitched, which means the static thrust (e.g. measured in a bench test) is quite low. The prop only gives full thrust when it's moving forwards, above a certain airspeed. Props like that are useful for fast planes, but not so useful for powered gliders and slow flyers. There's a simple rule. If the ratio of the diameter to the pitch is outside the range 3:2 to 2:1, the prop won't work as efficiently or won't give full thrust from a standstill, which makes taking off harder - also makes recovering from a stall by using full power harder. E.g. a 9x6 never stalls but a 9x9 stalls below a certain airspeed. An 8x4 never stalls. I don't think a 9x4 does either, but it's less efficient. The non-stalling props are now my props of choice, so that affects my choice of motor. When I build something like a small pusher jet, I'll consider using a speed prop, but I won't be able to measure the thrust - the static thrust will be quite low, which is why they're usually such a sod to get airborne from a hand launch. |
| Thread Tools | |
| Discussion EPP Eagle | fuzzyhead | Foamies (Scratchbuilt) | 2 | Sep 28, 2008 09:54 AM |
