Old Nov 03, 2002, 05:50 PM
McGrrr is offline
Find More Posts by McGrrr
McGrrr's Avatar
Cedar Park, Texas, United States
Joined Jul 2002
Best Glue for assembling a balsa model
It has been around 15 years since I have built a balsa model, and I can't remember what I used.
I'll be going to the store in an hour or so.
All help apprecitated.
McGrrr is offline Find More Posts by McGrrr
Old Nov 03, 2002, 06:04 PM
DaveSawers is offline
Find More Posts by DaveSawers
Canada, NS, Lunenburg
Joined Oct 1999
In the past 15 years, glues have improved dramatically.
The closest to the glue you used to use would be an aliphatic resin. It's a little like PVA to use but the results are much better.
Most of us now use cyanoacrylates for balsa though. Thin for good fitting parts and thick where some gap filling is required. Drop on some baking soda to make strong (but rough) fillets.
DaveSawers is offline Find More Posts by DaveSawers
Old Nov 03, 2002, 06:11 PM
McGrrr is offline
McGrrr's Avatar
Joined Jul 2002
So I should go with CA then? Baking Soda? You lost me.
Old Nov 04, 2002, 08:20 PM
brimann77 is offline
Find More Posts by brimann77
Long Island, NY
Joined Sep 2002
Just like he said. get both thin and "thick" CA, thin bonds in 2 seconds, thick it depends (same for fingers).
brimann77 is offline Find More Posts by brimann77
Old Nov 05, 2002, 02:02 AM
McGrrr is offline
McGrrr's Avatar
Joined Jul 2002
Thanks all.
BTW, CA is nasty, nasty stuff. My finger tips are covered in the crap.
Old Nov 05, 2002, 08:13 AM
Joined Oct 1999
It'll peel off in a day or so. Don't worry about it. After a while, you get more skilled at not attaching yourself to the workpiece or to other parts of yourself.
Old Nov 05, 2002, 09:03 AM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Originally posted by SD-Flyer
Thanks all.
Way to go, Tony.
Just pick your fingers, not your nose or any other body parts whilst using CA.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Nov 05, 2002, 09:07 AM
Long Island, NY
Joined Sep 2002
when you are done using it, i reccomend wiping it off with a paper towel orsometing so the excess doesnt harden. Otherwise you will have to get replacement caps.
Old Nov 05, 2002, 07:39 PM
Jim Finn is offline
Find More Posts by Jim Finn
Damascus Md
Joined Oct 2002
I use Sigment glue and titebond glue along with ca. Sigment is the 1950's model airplane glue and titebond is yellow carpenters glue. Ca is super glue. Sigment is best if you have to sand it. It bonds in about an hour and attains full strength overnight. It sands just like balsa. Titebond is cheapest but slowest and stronger than balsa. 24 hours to cure I put these two glue types in a syringe made by "Sig" Epoxy glue is very strong and heavy. I use very little of it. Elmers white glue is used on any foam you may use. Jim Finn
Jim Finn is offline Find More Posts by Jim Finn
Old Nov 09, 2002, 02:19 PM
KillerWatt is offline
Find More Posts by KillerWatt
Colonial Heights, Virginia, USA
Joined Mar 2001
watch out for CA glued joints when first using the stuff....it Always sticks to everything you don't want glued (esp fingers) but doesn't always stick firmly to intended joint material...it can look real neat with no buildup or ooze out but one good "test " pull & the parts come loose again.... i still don't 100 % trust CA as much as the other glues except for sticking body parts together every time....... kw
KillerWatt is offline Find More Posts by KillerWatt
Old Nov 11, 2002, 09:23 AM
GForceStress is offline
Find More Posts by GForceStress
Oxymoron: Rap Music
GForceStress's Avatar
Upstate NY
Joined Sep 2002
I sand more glue off my fingers than my model...
GForce
GForceStress is offline Find More Posts by GForceStress
Old Nov 12, 2002, 08:54 AM
PaulF is offline
Find More Posts by PaulF
PaulF's Avatar
Twin Cities, MN
Joined Aug 2001
If you use CA, get the tips as they really help in applying the adhesive. You will also use far less CA with the tips as little gets wasted.
Something like this:
http://www2.towerhobbies.com/cgi-bin...1&I=LXK295&P=7
Unfortunately, I've found that I'm slightly allergic to CA, which I hear is common (damn shame as I enjoy building nearly as much as I do tinkering and flying). Anyone found a workaround for allergic reactions to CA?
PaulF is offline Find More Posts by PaulF
Old Nov 12, 2002, 09:53 AM
loading is offline
Find More Posts by loading
loading's Avatar
Washington
Joined Sep 2002
My 2 cents
Acetone will disolve CA. This is nice if you glue something togather that you don't want. Fingers to fingers, fingers to balsa, ect. You can buy fingernail polish that is 100% acetone. One more thing, acetone and most CA glues will eat foam.
loading is offline Find More Posts by loading
Old Mar 22, 2013, 12:27 AM
Brent85 is offline
Find More Posts by Brent85
Canada, ON, Brantford
Joined Mar 2013
I have a strange number of allergies to adhesives I've found over the years, the best solution is a box of Nitrile gloves from your local drug store, they're super thin, just make sure to get the size that fits you best, nothings worse than dropping a part with glue on it because your glove's loose. I find the best way for fitting is just like golf gloves, they should feel very tight with no floppy finger tips.
Brent85 is offline Find More Posts by Brent85
Old Jun 13, 2014, 02:49 AM
Prune Tang is offline
Find More Posts by Prune Tang
Joined Apr 2014
I am about to go to the hobby store and buy a Great Planes p-51 .40 size kit and I would like to know the best glue for this plane. I do HATE CA, I just got done building a P-40 Warhawk with CA and it's all over my hands. I want something stronger than CA and I don't mind a little bit of dry time but not too long because I do still want to get it done in a little less than a year... Lol
Prune Tang is offline Find More Posts by Prune Tang
Question Best glue for balsa kit? temp_oct Parkflyers 23 Oct 31, 2003 04:37 PM
Best glue for balsa? MSB Beginner Training Area (Aircraft-Electric) 4 Jul 11, 2002 07:18 AM
Best glue for Depron ZAGIZAGI Parkflyers 2 Feb 17, 2002 01:25 AM
Best glue for blue foam D-VII? Erinair Power Systems 7 Nov 10, 2001 09:26 PM
Best glue for Terry repairs? rob barham Foamies (Kits) 8 Aug 08, 2001 03:05 AM
