Old Jun 15, 2007, 06:54 PM
apt.1 is offline
Find More Posts by apt.1
Joined Nov 2006
How are the DX7s working with the Trex?
I have been reading about all kinds of problems with the Sprectrum DX7 systems. It seems that most of the issues are coming from plankers. How about you heli pilots. Is the DX7 working for the standard Trex setup. How many crash and burns? No problems? Love em? Hate em? Let us hear.
apt.1 is offline Find More Posts by apt.1
Old Jun 15, 2007, 06:57 PM
ukgroucho is offline
Find More Posts by ukgroucho
ukgroucho's Avatar
Stratford upon Avon
Joined Jul 2004
No problems.. what problems do you believe you are reading abot - LINKS?
ukgroucho is offline Find More Posts by ukgroucho
Old Jun 15, 2007, 07:06 PM
apt.1 is offline
Joined Nov 2006
I have heard issues with under voltage cutouts. Receiver loosing sync with radio. Uncommanded servo moves. However this may all be attributed to the DX7 system, but a problem may lay elsewhere in the electronics.
Old Jun 15, 2007, 08:56 PM
HeliSmith is offline
Find More Posts by HeliSmith
=>] Smack 3D Head [<=
HeliSmith's Avatar
United States, CA, Chico
Joined Feb 2007
I have had mine setup for only a week. But before that I have had my 36 setup on the DX7 / AR7000 for over 2 months now I guess. I have had no issues and I am very happy.
P.S. That's one week and about 80 flights. I am a have addict!
HeliSmith is offline Find More Posts by HeliSmith
Old Jun 15, 2007, 09:11 PM
moosemanty is offline
Find More Posts by moosemanty
Rcer field rep.
yucca valley, CA/// RCG
Joined May 2006
haven't heard of any problems with the radio itself... only with the older ar6100 receivers.
moosemanty is offline Find More Posts by moosemanty
Old Jun 15, 2007, 09:18 PM
Andrew McGregor is offline
Find More Posts by Andrew McGregor
Christchurch, New Zealand
Joined Jun 2006
Under voltage is real, but easy to fix (uprate your BEC). Early AR6100s had an uncommanded servo move problem, now fixed in firmware. There is a way the transmitter can fail that results in uncommanded movements, that's faulty equipment, which of course can do anything.
A heli pilot is never going to have range issues, but bigger (read 500 and 600 class) helis might have shadowing issues; this is fixed by using an AR6200 at least in that class of heli.
Other than those things, all of which are fairly easily fixed or very rare, it's a great heli radio, probably only exceeded by other 2.4GHz systems that aren't out yet.
Andrew McGregor is offline Find More Posts by Andrew McGregor
Old Jun 15, 2007, 09:20 PM
quickster47 is offline
Find More Posts by quickster47
Everyone crashes sometime
quickster47's Avatar
Orlando, FL and Washington D.C.
Joined May 2006
I run the DX-7 on my Hurricane EP550, TRex 450SE V2, Falcon 3D and several other helis and have absolutely no problems whatsoever. And I pretty much have most all configurations covered and nothing in the radio or receivers has given me any problems. Great system with great support.
Perhaps you have been fed bad info by someone who is anti 2.4GHz and anti Spektrum.
Carl
quickster47 is offline Find More Posts by quickster47
Old Jun 15, 2007, 09:33 PM
apt.1 is offline
Joined Nov 2006
I was just surfing around the various forums looking at all the info out there. The problem is, those that are having no problems normally dont post. I have a Futaba CH7 now. I also put a dimension engineering BEC into my setup which consist of the stock Align ESC and 430L. Both of which I have had no problems in one year of use, and one hard crash. I would think the BEC should protect against any under voltage problems.
Old Jun 15, 2007, 09:52 PM
ZagiMan is offline
Find More Posts by ZagiMan
Trexazoid
Joined May 2001
Have you heard that 1 unsatisfied customer will tell on average 11 people of their bad experience and 1 customer that had a good experience will tell only 1 or possibly 2 people?
Did you find any of the posts where the question was asked what is the best tx? Or should I get a DX6 or DX7? A lot of those posts have plenty of responses about how people love them. Even the posts that have bad experiences have posts in them saying how to fix it once it was determined if it was a known problem (e.g. the firmware issue).
ZagiMan is offline Find More Posts by ZagiMan
Old Jun 15, 2007, 10:13 PM
HeliSmith's Avatar
Joined Feb 2007
I looked at the Futaba system and the DX7 system very long and hard. I went with the DX7 because of the amount of good press behind it. The AR6100 did have a problem which was rememdied.
I run a Dimension Engineering SportBEC as well. Great BEC!
HS
Old Jun 15, 2007, 10:30 PM
whyfly is offline
Find More Posts by whyfly
San Diego
Joined Mar 2006
I had about 100 flights with no issue and yes my 6100 is updated look at my heli now I will never use 6100 ever I lost servo control or a lockout only 2mins in flight all my heli will only have 7000
whyfly is offline Find More Posts by whyfly
Old Jun 15, 2007, 10:52 PM
fadetoblack is offline
Find More Posts by fadetoblack
#include <crashkit.h>
fadetoblack's Avatar
Joined Feb 2006
whats this issue you mentioned? i have ar6100s from dec 06 and early this year so im assuming those are early ones. do i have to send them in to get the firmware upgraded?
fadetoblack is offline Find More Posts by fadetoblack
Old Jun 15, 2007, 10:57 PM
whyfly is offline
San Diego
Joined Mar 2006
Why would you need to update your bec under voltage would mean your pass your cut off point .
vic20owner is offline
Find More Posts by vic20owner
LOAD "FLIP-FPV",8,1
vic20owner's Avatar
Joined Sep 2006
ar7000 no problems so far... love my dx7 !!
vic20owner is offline Find More Posts by vic20owner
Old Jun 15, 2007, 11:00 PM
whyfly is offline
San Diego
Joined Mar 2006
yup but there alot of issues with AR6100 All my helis will now have AR7100...
Discussion How to play with a Trex catahuladave Mini Helis 0 Jul 02, 2007 07:17 PM
Discussion Why are all my joysticks not working with Reflex Xtr cobrapilot Simulators 6 Jan 03, 2006 11:37 PM
How I got my XRB SR working with my new Hitec Optic 6 transmitter. rc_lurker Coaxial Helicopters 12 May 24, 2005 02:29 PM
How are Orbit Pro charges doing with LiPos? mikeb33 Batteries and Chargers 14 Feb 08, 2004 07:12 AM
