Espritmodel.com Heli Air
Old Jun 15, 2007, 10:05 AM
KJ4IKY Gravity Wins
blade thrasher's Avatar
Georgia
Joined Apr 2007
Very HOT Eagle ESC on new Trex 450
I just got my new 450 XP in today and after getting everything balanced and pitched I fired it up. It has an Eagle 30A speed control running a 3500Kv. After startup on some trials it would make a strange beeping sound then no power was sent to the motor? We could smell the ESC while standing over it. All this was not even half throttle while sitting in the grass.
Trex 450
HS-65HB
Futaba S9650 Tail
3500kv Outrunner
Eagle 30A ESC
2200mAH 20C
Logitec 2100T HH
AR6100
DX7
blade thrasher is offline Find More Posts by blade thrasher
Old Jun 15, 2007, 11:34 AM
KJ4IKY Gravity Wins
Georgia
Joined Apr 2007
Getting hot with just servos connected
I was working on gettng the right swash mix with the DX7 and with the motor unplugged the ESC got hot enough to smell? Is this normal? Im assuming its one or all of the servos dissapating heat in the ESC for some reason?
Old Jun 15, 2007, 11:38 AM
T-REX450SE T-REX600CF
Breckenridge, CO
Joined Nov 2006
Are you running a separate BEC?
MartyWakat is offline Find More Posts by MartyWakat
Old Jun 15, 2007, 11:43 AM
USA, CA, Moreno Valley
Joined Nov 2006
Sounds like your electronics are too much for the internal bec to handle.Time for an external one and I personally think it's a good idea anyway no matter what brand of esc.
Madbob9 is offline Find More Posts by Madbob9
Old Jun 15, 2007, 11:46 AM
Breckenridge, CO
Joined Nov 2006
I am running pretty much a similar setup except the GY401 for the gyro and I definately needed and external BEC.I went with the KoolFlights UBEC. Heavy but awesome.
Old Jun 15, 2007, 12:01 PM
=>] Team Compass [<=
HeliSmith's Avatar
United States, CA, Chico
Joined Feb 2007
SportBEC is also nice. You don't have to cut your ESC power wire either. 29.99 with 1.25 shipping from:
http://www.dimensionengineering.com/SportBEC.htm
I am not afiliateed with them, just when I get a nice product I pass the word.
HS
HeliSmith is offline Find More Posts by HeliSmith
Old Jun 15, 2007, 05:24 PM
KJ4IKY Gravity Wins
Georgia
Joined Apr 2007
Thanks for the info, I just got done ordering a sport BEC. Should I stop trying to get a smooth hover untill it comes in? Basically, will I burn up my ESC flying low tuning?
Old Jun 16, 2007, 08:38 AM
Joined Nov 2004
SmartBec on the way too!
My esc gave up the ghost last week for some reason. So I have ordered another esc and a SportBec. My question is: what setting should I have on the SportBec; 6V or the other setting. Oh by the way, this is for my Trex SE. Thanks guys!
bh95 is offline Find More Posts by bh95
Old Jun 19, 2007, 06:46 AM
Joined Nov 2004
SportBec location?
I just received my SportBec yesterday. Where is the best location for it on my Trex SE? On the side of the frame or up next to the ESC? Or somewhere else? Thanks a bunch!
Old Jun 19, 2007, 07:31 AM
Christchurch, New Zealand
Joined Jun 2006
Anywhere it fits, but away from the gyro.
Andrew McGregor is offline Find More Posts by Andrew McGregor
Old Jun 20, 2007, 05:41 PM
KJ4IKY Gravity Wins
Georgia
Joined Apr 2007
I just did a test hover to check the gyro settings. The motor is getting very hot also, 198 degrees after 1 min. ESC was at 171 degrees. Will the BEC solve both high temp problems?
I dont know what brand the motor is? It just says 3500 with some Chinese writing also. The ESC is Eagle 30A. 2200 mAh battery
Old Jun 20, 2007, 07:02 PM
Joined Jun 2006
The BEC won't help the motor. A smaller pinion will, though, by reducing the headspeed and therefore the power required for hover.
Old Jun 20, 2007, 08:04 PM
ARF Hater Club
tommyeflight89's Avatar
Toronto, Ontario
Joined May 2004
Check your amp draw at full picth. It could be geared wrong.
tommyeflight89 is offline Find More Posts by tommyeflight89
Old Jun 21, 2007, 03:17 PM
KJ4IKY Gravity Wins
Georgia
Joined Apr 2007
HOT motor 198 Degrees / HOT ESC
Here is a close up of the gear mesh. Does this look to tight? As far as the tail goes it does not look streched or twisted. When it spins down it does not come to an abrupt stop but it will not spin as long as my CP2 with a one way gear by any means.
I'll add some photos in case there is a misalignment that I am overlooking.
Old Jun 21, 2007, 06:06 PM
Joined Jun 2006
That's a 15T pinion, you just need a smaller one. Try 11T, if there's not enough headspeed use 13.
Data SMOKIN HOT Eagle 30A ESC on new Trex blade thrasher Power Systems 0 Jun 14, 2007 10:10 PM
Help! Hot Otto ESC on HDX450 Bill Bergman Mini Helis 0 Aug 15, 2006 09:10 PM
Discussion Anyone using a Kontronik ESC on their Trex? kenmalecki Mini Helis 10 Mar 09, 2006 07:08 PM
Question How do you mount HS56 servos on stock TRex 450 XL CDE? hb888 Mini Helis 6 Jan 24, 2006 04:47 PM
Sold New Trex 450 V2: Sale/willing To Trade. nieves50 Aircraft - Electric - Helis (FS/W) 3 Oct 13, 2005 08:42 AM
