Old May 24, 2001, 04:23 PM
jhudak7 is offline
Find More Posts by jhudak7
marietta, GA, USA
Joined Feb 2001
Ok, I got my brushless setup, I have some questions:
Info:
Ikarus ECO-8
HAcker B40-9L heli
Kontronik Smile 40-6-12
7 Sanyo 2400 mAh cells
I know that a lot of you don't run 7 cells, but with (X) cells, what pinion(s) do you use?
Also, does the governor mode really require a separite "slider" channel like the instructions say?
I am now using the "motor-plane" mode with a totally linear throttle/pitch curve.
Thanks all
PS. Just with the 10 tooth pinion I got almost 2 minutes extra run time... yeah.
jhudak7 is offline Find More Posts by jhudak7
Old May 24, 2001, 04:57 PM
Steph280 is offline
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
Don't know about pinion on Eco since I am running Voyager. But I did notice I have to increase tooth count when I switch to brushless. I am running 17 right now, will try even higher count.
the slider channel is not required. You can have you throttle curve set to 0,50,50,50,50 which is like turning the knob/slider to 50%. Problem with that is you have to make sure you don't back down your throttle all the way while flying. If your motor stops, it takes few seconds to get back up to speed.
I haven't tried the regular mode on my Smile yet. Supposedly the governor mode consumes more amp.
Steph280 is offline Find More Posts by Steph280
Old May 24, 2001, 09:32 PM
Tohru Shimizu is offline
Find More Posts by Tohru Shimizu
Matsuyama city, Japan.
Joined Feb 2000
The gear ratio is X(cells)*1.1(Volt)*3333(KV)*0.9/(rpm). The rpm is for the main rotor at the appropriate max pitch (9-13deg). The "0.9" is roughly the safe load rate for Neodyum magnet motor.
Therefore, if you assume 1300rpm for 7cells, the gear ratio becomes 17.7:1. The pinion gear becomes 180/17.7=10T.
For 8cells, it becomes less than 10T but the gear is not available in ECO8. With 10T,the rpm increases to around 1400-1450rpm. The flight becomes powerful and short duration.
10cells evidently results in overload. Cannot be recommended. Or, short duration (1-2min) only will be OK.
Inversely, 6cells3000mAh will result in longer duration flight with 10T (,if it can lift off).
[This message has been edited by Tohru Shimizu (edited 05-24-2001).]
Tohru Shimizu is offline Find More Posts by Tohru Shimizu
Old May 25, 2001, 08:35 PM
ShakyHands is offline
Find More Posts by ShakyHands
Marietta, GA
Joined Mar 2001
Thank you, Tohru, I read ALL of your information on your site several times. I did the same calculation and came to the same conclusion. This hacker motor has a lot in the torque department. With the 10 tooth and 7 cells, the head speed is a little slow. With a 15 tooth, this heli is a ROCKET! But, the speed controller does get too hot. I think I will try something in the 12-14 tooth area.
My question on the modes will be in a separite post.
ShakyHands is offline Find More Posts by ShakyHands
Discussion Got my SE V2 today :) Have some questions Neil_J Mini Helis 12 Aug 19, 2007 08:37 PM
Discussion I got my first HB FP and have some questions.. Discusman Micro Helis 13 Jul 28, 2006 06:22 PM
Discussion My First Lipo and have some questions please muscleflex Batteries and Chargers 20 Jul 02, 2006 04:20 PM
Building my 5th Tigermoth and have some questions. 1987tc Parkflyers 22 Sep 12, 2003 11:59 PM
Putting together my first thl and have some questions: thor4944 Foamies (Kits) 1 Nov 05, 2002 09:24 PM
