Old Jun 14, 2007, 10:21 PM
WarpTrooper is offline
Find More Posts by WarpTrooper
Joined May 2007
F-22 with weapon bays and landing gear
Hi. I want to build an F-22 model. I was looking at the RBC F-22 kit.
I'm new to RC airplanes so i want something that isn't too hard to fly and can fly slow easily.
I am going to get a 6 channel radio. How is this ???????????????
http://www.hobbyhobby.com/store/prod...oducts_id=2243
Now for the F-22.
I want to put the extra channels to good use. So i want these in my F-22:
-Retractable landing gear
-Retractable weapon bays (for dropping things like foam missiles)
Can the RBC F-22 be modified for these 2 things ?????
And most importantly, is it possible to fly the F-22 slow ?????
To give you an idea, lets say that i can fly the aerobird challenger and the parkzone P-51.
WarpTrooper is offline Find More Posts by WarpTrooper
Old Jun 14, 2007, 11:13 PM
Rampage is online now
Find More Posts by Rampage
DFS#000178
Rampage's Avatar
United States, CA, Twentynine Palms
Joined Aug 2005
An F-22 by default is almost all lifting surface anyway..so it could probably get slow..But if you're still relatively new to the hobby, I wouldn't even approach an EDF jet. Let alone something "full option". You're looking at a lot of expense..And it's a kit, which means you basically get a box of wood. It also has to be bungie-launched, which means it probably likes to go fast.
Don't want to discourage you from your dreams, just a heads up. : )
Rampage is online now Find More Posts by Rampage
Old Jun 15, 2007, 12:12 AM
Joined May 2007
Normally, how fast do EDF jets go at half throttle ?
Old Jun 15, 2007, 12:23 AM
AceMigKiller is online now
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Thats an extremely vague question... Each different model will have different speeds and flying characteristics at 1/2 throttle...
Its not so much that you cant throttle back and slow the F-22 down, but in the hands of a low-time pilot, especially a rookie to EDF's, you could be in way over your head.
If you're really interested in starting out on EDF's, I have a suggestion!
You could go ahead and buy one (or two) fans and motors that the RBC F-22 kit calls for, get yourself a Stryker airframe (F-27 made by Parkzone) for about $19.99 at your LHS, and learn to fly on that first.
This way, you'll have the gear you need for your F-22 and you'll gain VALUABLE experience in flying EDF's on the Stryker.
You gotta take things one step at a time man. If you're new, and have relatively low-time on R/C aircraft the RBC F-22 is going to be more than a handful and will probably end up.... *re-kitted* on the maiden...
But good luck w/ whatever you decide to do.
AceMigKiller is online now Find More Posts by AceMigKiller
Old Jun 15, 2007, 12:52 AM
kriptonic is offline
Find More Posts by kriptonic
kriptonic's Avatar
Los Angeles
Joined Aug 2004
Try the EDF Foamy section.
Gene
kriptonic is offline Find More Posts by kriptonic
Wattage F-22 with ducted fan The Blue Max Electric Ducted Fan Jet Talk 11 May 10, 2003 01:13 PM
Corona with Voyager E landing gear Raydee Electric Heli Talk 1 Apr 06, 2003 02:35 PM
Corona with Voyager E landing gear (yet again!) Wright Flyer Electric Heli Talk 5 Feb 22, 2003 04:19 AM
f-22 with jeti brushless ivorz Foamies (Kits) 14 Oct 01, 2002 08:39 PM
Need help with chooseing retractable landing gear. KOMET 44 Power Systems 1 Jan 06, 2002 09:37 AM
