Old Nov 03, 2002, 09:49 AM
putt_13 is offline
Find More Posts by putt_13
putt_13's Avatar
Minneapolis, MN
Joined Aug 2002
What Does PCM and PPM mean?
Hello,
I have read about radios that are PCM, or PPM. What does this mean? -Patrick
putt_13 is offline Find More Posts by putt_13
Old Nov 03, 2002, 09:58 AM
Wright Flyer is offline
Find More Posts by Wright Flyer
(aka Cliff Lawson)
Wright Flyer's Avatar
United Kingdom, Essex
Joined Oct 2001
Hi,
PCM = pulse code modulation
PPM = pulse position modulation
Effectively PPM is the old "analog" type of signal and PCM is the more modern "digital" type of signal.
It's not unlike the way mobile cellphones have switched from the original analog systems a few years ago to mainly digital these days.
Or the way that television transmission started out analog but in the last few years digital transmission is starting to take over.
PPM just takes the position of the stick and adjust the width of a pulse transmitted over the air accordingly. In PCM a little computer chip does an A/d (analog to digital) conversion abd converts the stick position to a number (0..255 say) and then transmits that.
As such PCM is far more reliable and less suceptible to interefence but, on the whole, the equipment is more expensive.
At the present time almost all the transmitters/receivers in use by all but the "professional" r/c pilots (and those flying large/heavy - 7Kg+) are still PPM as things like dual conversion receivers are usually enough to deliver a fairly reliable link between Tx and Rx anyway.
I don't know if there's really any resaon for us mere mortals to switch to PCM but things might go that way over time as everything seeks to benefit from the use of "digital". On the other hand there's thousands of pilots with thousands of dollars invested in PPM Tx/Rx and I kind of doubt whether everyones going to dump all that overnight.
Most "computer" Tx's are switchable between PPM and PCM anyway so, when you get rich, you can buy PCM receivers and then choose to switch the Tx (but this is yet another thing where I guess it could be easy to leave the thing switched to the "wrong" state and disaster might ensue!)
Cliff
Wright Flyer is offline Find More Posts by Wright Flyer
Old Nov 03, 2002, 10:31 AM
stuartaw is offline
Find More Posts by stuartaw
Berks, England
Joined Jun 2001
On the subject of PCM/PPM there are also new receivers, that while technically PPM offer the main advantage of PCM - glitch filtering; eg the Multiplex IPD ones and the Schulzes.
Since these cost half the price of a PCM receiver I can't really see the point of PCM, especially as some of the PCM systems have a reputation for being a bit enthusiastic with the failsafe.
Stuart
stuartaw is offline Find More Posts by stuartaw
Old Nov 03, 2002, 11:07 AM
putt_13 is offline
putt_13's Avatar
Minneapolis, MN
Joined Aug 2002
Thanx Patrick
Old Nov 17, 2014, 08:26 PM
Javieruriel is offline
Find More Posts by Javieruriel
Joined Aug 2014
Do you know i i can connect this board to my ar610 spektrum receiver?
http://abusemark.com/store/index.php...p_image&pID=45
Javieruriel is offline Find More Posts by Javieruriel
Old Nov 17, 2014, 09:41 PM
cmdl is online now
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
maybe you should ask here: http://www.rcgroups.com/radios-135/
cmdl is online now Find More Posts by cmdl
Old Jun 22, 2015, 06:04 PM
Electromagnetic is offline
Find More Posts by Electromagnetic
Joined Feb 2013
So all these years later what are todays Tx's using? PCM?
Electromagnetic is offline Find More Posts by Electromagnetic
Reply With Quote  (Disabled)
What does PAL and NTSC mean???? raythomas Aerial Photography 3 Mar 07, 2003 11:42 PM
EPS,EPP,BluCor and what does 1# density mean? Balin Foamies (Kits) 0 Apr 24, 2002 05:35 PM
What does the CE symbol mean Ben Lanterman Electric Plane Talk 2 Feb 28, 2002 05:34 PM
What does run dry mean? twinster2 Electric Ducted Fan Jet Talk 2 Feb 14, 2002 06:33 PM
what does the black dot mean breadboy Electric Plane Talk 3 Sep 13, 2001 09:28 PM
