The Atlantic is more a 'freelance' type tug.. although i suspect the roots are in either a European type tug.. possiby of the '..garth' type British tugs..
Try http://www.lekko.org/International.html for European (SMIT) type.. and http://www.tugphotos.co.uk/ for some Brit tugs |
Got her wired up temporarily to test in the tub last night. Looks like I have full forward and reverse with the Hitec Laser 4 and Hitec EZX-R ESC setup. I'm not sure if the shaft is perfectly straight as I do have a slight wobble on the prop and some vibration at the other end as well. Is that normal? She didn’t weep a drop. I also need more rudder and will mess with the transmitter volume controls first. I dropped in a 7amp 6 volt lead gel cell and will need to move some of the glued down (why did they do that?) ballast aft. I want a main power on/off switch to the battery that I can operate without having to open and close any hatches etc. I always had a slider switch for the receiver/servos with a small push/pull rod going through the fuselage on the planes I built. Any ideas on what I can do here without a big ole switch above deck? I also have a Ram bilge pump to mount aft as well. I think this little tug will be fine for what I need it for….play, rescue and fish bait hauler. Pics will come as I start the over haul. "Weevils...the breakfast of iron men sailing wooden ships!" |
Good to hear that the EZX-R is happy on 6v... hopefully it doesn't quit when the battery gets down to like 5.5v- it's spec'd for 7.2 - 8.4 v in, which suggests it has an internal voltage regulator to make 5.0 v... might be touchy at the lower voltages.
You can control power two ways. The switch on the EZX-R is a little thing on the logic side, but will cause eveything to shut down- nice. But it's built into the ESC, not on a pigtail, so it can be hard to access. I like ESC's which have such a switch, and which put them on pigtails- allows for remote mounting. The other way is to switch the battery lead, the "mains". If you do this, remember that the switch must carry full motor current- don't put some wimpy 1A switch on this circuit! I don't like doing this except on small models with very low motor current. Whichever switch, it's always fun to find a way to hide it on deck- under some easily removeable fitting for example. pm |
IIRC, Harry told me he found out it was a Russian built tug type that was used by the Chinese naval forces or merchant marine. That would explain why a Chinese company (Aquacraft/Hobbico) made a tug that looked like a tug they were used to seeing in their own waters. Yet it was Russian built.
| Thread Tools | |
| Question Atalntic harbor tug propellor | cpd32 | Dock Talk | 2 | Dec 30, 2009 10:54 PM |
| Build Log Ocean/Harbor Tug Based on Fiberglass Hull off eBay | not_in_houston | Scale Boats | 53 | Nov 12, 2007 10:27 AM |
| Discussion Aquacraft Atlantic Horbar Tug | wingnut163 | Dock Talk | 10 | Mar 31, 2006 04:31 PM |
| Alert Midwest's "The Harbor Tug" ? | helifan | Scale Boats | 17 | May 07, 2005 10:11 PM |
| Midwest "the Harbor Tug" plans for trade | helifan | Scale Boats | 1 | May 02, 2005 05:32 AM |
