Espritmodel.com Heli Air
Old Jun 14, 2007, 08:44 AM
Resistive User
Jacques Flambeau's Avatar
Backwoods Alabama
Joined May 2000
Strip planking or insert planking?
Here is the Guillow's conversion PBY airframe I'm getting ready to plank, and I can't decide whether to do strip planking or insert planking. Especially up near the nose and where the tail joins the main body there are mucho compoundish curves. Which method would be better in this case?
--Bill
Jacques Flambeau is offline Find More Posts by Jacques Flambeau
Old Jun 14, 2007, 08:54 AM
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
I don't think it makes a deal of difference frankly.
But the opportunity to use largish pieces of balsa in sheet form in places would tempt me to sheet over it really.
I have found that any gaps between bits are easily filled with wedges of balsa CA'ed and jammed in the cracks - they soon sand down.
And a coat of lightweight spackle, before tissuing, makes all neat enough.
Old Jun 14, 2007, 09:16 AM
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
1/16" strips are the easiest. I end up sanding off most of the wood anyway during sealing and finishing. If you don't sand all the way through it at some location, then you aren't sanding enough Use spackle like Vint suggests and weight gain will be minimal.
charlie
portablevcb is offline Find More Posts by portablevcb
Old Jun 14, 2007, 09:36 AM
Light and floaty does it
Work in Progress's Avatar
Cambridge, Great Britain (UK)
Joined Sep 2004
Since you've already put the stringers on, insert planking would seem to be the way forward. If you try to sheet over the stringers it will all end in tears.
Normally if you're strip planking you just go straight over the formers, no stringers involved.
Work in Progress is offline Find More Posts by Work in Progress
Old Jun 14, 2007, 09:48 AM
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Inlay
Inlaying is best in that it doesn't enlarge dimensions, it's a PITA and it adds weight due to amount of glue needed. Suggest you use sandable glue and balsa filler then cover with silkspan and coats of clear dope then colored dope to waterproof your seaplane.
On second thought, maybe you could dremel out the edges of formers/bulkheads so that you could use long strips between stringers, where practical.
E-Challenged is online now Find More Posts by E-Challenged
Old Jun 14, 2007, 04:09 PM
Resistive User
Backwoods Alabama
Joined May 2000
Thanks, now I have a better idea on when to use which type of planking.
--Bill
Discussion decking or "planking" pmdevlin Scale Boats 6 Apr 30, 2007 08:12 PM
Discussion Help with insert planking craab Scale Electric Planes 5 Jan 05, 2007 02:04 PM
Discussion Wing joiner glass strip - straight or on bias? arneansper Hand Launch 1 Apr 24, 2006 04:29 AM
Strip planking - options Capt_Christo Dock Talk 3 Apr 10, 2005 06:16 PM
