Old Jun 13, 2007, 09:14 PM
b36roxs is online now
Find More Posts by b36roxs
Joined Sep 2006
Help!
where should my hi start go on SIG Flip
edit
b36roxs is online now Find More Posts by b36roxs
Old Jun 13, 2007, 09:22 PM
Arkasha is offline
Find More Posts by Arkasha
Joined Apr 2007
Are you asking for help?
Maybe it's just me, but I think a courteous request is more appropriate. Something like, "can someone tell me where to locate the tow hook on my plane? Thanks"
Reads a lot better than "so?!!"
Arkasha is offline Find More Posts by Arkasha
Old Jun 14, 2007, 01:26 AM
slopemeno is online now
Find More Posts by slopemeno
this space for rent
slopemeno's Avatar
Joined Jan 2003
Flip? As in the chuckie glider?
slopemeno is online now Find More Posts by slopemeno
Old Jun 14, 2007, 04:06 PM
Joined Sep 2006
edit
Old Jun 14, 2007, 10:32 PM
vfbass is offline
Find More Posts by vfbass
vfbass's Avatar
United States, IL, Bloomington
Joined May 2007
How about on the wing tip!. DLHS Discus Launch High Start!!
vfbass is offline Find More Posts by vfbass
Old Jun 15, 2007, 03:46 PM
Joined Sep 2006
edit
Old Jun 17, 2007, 02:35 AM
kimhey is offline
Find More Posts by kimhey
kimhey's Avatar
nøtterøy, NORWAY
Joined Mar 2006
Add a subfin!?
Kim
kimhey is offline Find More Posts by kimhey
Old Jun 17, 2007, 11:03 AM
Joined Sep 2006
edit
Old Jun 17, 2007, 12:19 PM
kimhey is offline
kimhey's Avatar
nøtterøy, NORWAY
Joined Mar 2006
Below the elevator (horisontal fin) you glue a mini-vertical fin, that has a size of like ...start with 50%..of the original vertical fin. This is a glue-and-adjust operation. Remember to balance the glider before testflight.
Kim
Old Jun 17, 2007, 03:58 PM
Joined Sep 2006
edit
Old Jun 17, 2007, 04:01 PM
Joined Sep 2006
edit
Old Jun 18, 2007, 09:59 AM
kimhey is offline
kimhey's Avatar
nøtterøy, NORWAY
Joined Mar 2006
Originally Posted by b36roxs
any pics? cause it's not working
Add a pic of the glider, and we'll see if it's possible. I am not familiar with your glider..
Kim
Old Jun 18, 2007, 04:19 PM
Joined Sep 2006
edit
Old Jun 18, 2007, 04:53 PM
this space for rent
slopemeno's Avatar
Joined Jan 2003
I'd suggest making a "Zip-start" out of some surgical tubing. You need to have a hook under the nose, and have about 10 feet of surgical tubing, 20 feet of kitestring, and a stake in the ground. The idea is the surgical tubing launch gets the plane going WAY harder than you can possibly throw it; you put the stake in the ground, hook the ring on the end to the tow hook under the nose, stretch it out, and let the plane go. HOPEFULLY, you dont have any bad trim, as anything that happens will happen at about warp factor seven. Properly trimmed you can really get some height this way.
Old Jun 18, 2007, 05:13 PM
Joined Sep 2006
edit
Where should my E-Streak balance ? Al P Sport Planes 9 Apr 07, 2003 03:16 PM
