Old Nov 01, 2002, 09:43 PM
SmoothSL is offline
Find More Posts by SmoothSL
Mega Motor Man!!
Richmond, Va
Joined Oct 2002
How do I use Whatt Meter to measure charge rate??
Do I just hook it up the regular way? Looks like it would be hooked up backwards with the charger on the load side and the battery on the source side.. But that's the only way without changing connectors.. Thanks!!
SmoothSL is offline Find More Posts by SmoothSL
Old Nov 02, 2002, 05:04 AM
Norman Adlam is online now
Find More Posts by Norman Adlam
Official Old Git!
Hampshire, UK
Joined Sep 2000
SmoothSL,
I'm not sure, but I don't think you really ought to use the Whatt Meter to measure charge rate! The reason I say this is because (depending on the charger and charge type program) the battery may get charged in all manner of stop / start pulse modes - and I'm not sure that the Whatt Meter would be able to give a 'sensible' figure i.e. the average put into the battery, or whether it would get confused.
The Whatt Meter is really there to measure a 'relatively' even discharge rate, which it counts and adds up whilst measuring time. It then does the maths to tell you what Ma / Hr etc were measured i.e the battery capacity.
If you tried to do it, then the charger would going into the input (source) connectors of the Whatt Meter (where the battery would normally go) , and the Battery would be on the ouput (replacing the motor).
Cheers,
Norman Adlam is online now Find More Posts by Norman Adlam
Old Nov 02, 2002, 06:19 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
The Whattmeter works fine used to measure charging. When I tested it, I made adapters to hook mine up "in reverse", so to speak - the charger became the source. I don't do this because my Infinity 2 gives me all the info automatically, but it works fine this way (it's even shown in the Whattmeter instructions, I believe)..
..a
Old Nov 02, 2002, 07:23 AM
mikeb33 is offline
Find More Posts by mikeb33
Tell that to George Zipp!
mikeb33's Avatar
United States, IL, Inverness
Joined Oct 2000
I use mine with a Hitec 885 charger. You need to make a pair of connectors: 1 with female battery leads on both sides and 1 with male leads on both sides. Hook the Whattmeter up backwards.
When charging is complete, you can see how many amps went it to the battery. If I leave it on all night, it will continue to trickle charge and report a higher than possible capacity.
MIKE
mikeb33 is offline Find More Posts by mikeb33
How do I use my Craftsman clamp meter #82014? papasmurf Power Systems 9 Feb 15, 2010 01:13 AM
Discussion How do I use my ICE to charge my batterys for blade CX2??? webejpn01 Electric Heli Talk 2 Jan 26, 2007 01:02 PM
Question How do I use this thing (incidence meter) Wyatt Modeling Science 6 May 03, 2004 08:28 AM
How do I use my peak charger for Qualcomm packs ? Al P Batteries and Chargers 6 Jun 21, 2002 03:29 PM
Where & How Much for a WHatt meter? erashby Power Systems 2 Sep 12, 2001 11:14 PM
