Winnipeg, MB, Canada
Joined Dec 2004
Jetset44 175% SU-37 build!
I would like to build a 175% version of Steve's very nice SU-37 but being my first large electric I may need some help along the way.
I will be open to any advice or help I can get. Looks like it will have a span of 52.5" and length of 63.5". Some of the stuff I was looking at for it are....-Motors http://www.bphobbies.com/view.asp?id...84&pid=W815796 9x7.5 props, 72A total, about 6lb thrust, 1060W total and pitch speed of 78mph. -TV servos http://www.bphobbies.com/view.asp?id...90&pid=S629352 -Other servos http://www.bphobbies.com/view.asp?id...83&pid=S544494 -ESC's http://www.bphobbies.com/view.asp?id...2&pid=B0558275 -8000mah 4S-2P packs If I can build it with an AUW of 5lb it would be 200W/lb (don't think I can). 6.5lb AUW would give me about 150W/lb (might be able to do). Here are some weights I have so far..... -Airframe = ??? -2 Motors = 320g -2 ESC (I wonder if I should use 1 ESC and skip the yaw?) = 60g -TV servos = 115g -6 main servos at most = 162g -8000mah 4S-2P = 704g -RX = 20g -RX pack = 105g 1486g, 52.32oz..... 3.27lb so far without the airfrme -What does everyone thing of the item selection so far? I wonder if 200% would be better? -Will those TV servo be strong enough? By the way, I will be building it from 1/2" blue foam... hope I can find it here! I know I can get 1" and 2". |
Good you did start a new thread
I think your going to be about 6 lbs, so build light If you can get standard 1/4" blue-cor, you can glue two pcs together. (But that glue adds weight too) Lowes carries 1/2" sheets of Blue-Cor that are 4ft. X 8ft. Part# 15348 I'd love to build a edf version, but I have at least 3 planes to do first So blaze that trail I'll add this thread to Steve's Parkjets SU-37 page. Tom - Milwaukee You can download all of the Plans for the SU-37 at www.Parkjets.com |
After building the 42" ws F4 and 15-% Shumate F-18, I would expect your AUW to be in the range of 6-7 lbs, most probably closer to 7 lb but that's depending on the finish.
A good rule of thumb is airframe =1/2 weight of the plane, equipment the other half. Amazing how often it turns out to be true. But these big airframes will handle the weight and fly very nice on 100 watts/lb. J |
Latest blog entry: F7F Tigercat from Palmer Plans
| Thread Tools | |
| Greenairdesigns su-27 build thread....... | Se5a-flyer | Electric Ducted Fan Jet Talk | 52 | Nov 11, 2008 02:40 PM |
| Build Log Profile SU-37 Design/Build Thread | Kai_Shiden | Pusher Prop Jet Models | 377 | Nov 14, 2007 02:26 AM |
| NESail (Northeast Sailplanes) Pelikan SU-37 Su-27 | karakoram | Foamies (Kits) | 39 | Nov 11, 2005 06:06 AM |
| SU-37 "SHOCKY STYLE" QUESTIONS | JAM | Pusher Prop Jet Models | 33 | Aug 24, 2005 02:12 PM |
| Video: SU-37 does 3D! | Pjotrrr | 3D Flying | 0 | May 22, 2005 03:15 AM |
