Old Jul 22, 2007, 07:26 AM
endr is offline
Find More Posts by endr
Joined Jul 2007
What wire have you used for the booms? The withe or the black one? Cause i've used the white one, and it isn't the best ... What kind of wire can I use that work smooth?
tanx
endr is offline Find More Posts by endr
Old Jul 22, 2007, 08:28 AM
breakwater is offline
Find More Posts by breakwater
United States, MA, Wenham
Joined Jan 2007
The Headboard looks like a big luff, and there's no shape to the main
breakwater is offline Find More Posts by breakwater
Old Jul 22, 2007, 04:01 PM
endr is offline
Joined Jul 2007
Of what are you talking about? Can someone answer me please? What kind of wire i have to use?
Old Jul 22, 2007, 05:28 PM
Norman2 is offline
Find More Posts by Norman2
Norman2
Norman2's Avatar
Connestee Falls, Brevard, North Carolina
Joined Mar 2006
On my ETNZ all my rigging was done with 90 lb Spectra Line. Did not use what
came with the kit. You can get at any good fishing store
Norman2 is offline Find More Posts by Norman2
Old Jul 22, 2007, 07:19 PM
gospectredotcom is offline
Find More Posts by gospectredotcom
gospectredotcom's Avatar
Melbourne, Victoria, Australia!!
Joined Feb 2007
endr , do you mean the rigging string for the sheets? (we dont have ropes on boats they are called sheets?)
if s othe white one in the kit is too big to use for the sails as it wont let the jib go out in light winds. a lighter one will slice through quicker on the weird servo top hat cover they use.
try a small diameter sectra or dacron from a kite shop. the dacron is good becasue you can super (ca) glue the end to poke through the fittings, the spectra does not like to be glued.
as always , any knot you tie on a model boat that you do not want to come undone when sailing needs to be super glued!!
andrew
gospectredotcom is offline Find More Posts by gospectredotcom
Old Jul 23, 2007, 02:20 AM
endr is offline
Joined Jul 2007
Ok tanx now i search this Dacron wire!
Old Jul 23, 2007, 08:05 AM
doomracing is offline
Find More Posts by doomracing
doomracing's Avatar
United States, NY, Buffalo
Joined Mar 2002
so this boat with new sails will cost around $500? are the new sails realy needed? my bro wants a 1 meter boat to sail with my clubs USOM's. he doesn't expect to win, but just not embaras himself, or be in the way.
doomracing is offline Find More Posts by doomracing
Old Jul 23, 2007, 10:20 AM
endr is offline
Joined Jul 2007
No, the stock sails are too good! thee is no problem, i've modificate some parts, using steel wire for the mast, installing alluminium chain plates, and things like this...
Old Aug 06, 2007, 01:30 AM
now is offline
now
Find More Posts by now
now
Joined May 2007
Hi
Did anyone expoxy the mast step into the hull (meaning that you can't remove the keel at a later date)?
Does this have to be done, or does the ETNZ sail well without it being expoxy'd in (even through the mast moves around a bit)?
Thanks!
now is offline Find More Posts by now
Old Aug 06, 2007, 03:16 AM
endr is offline
Joined Jul 2007
Yes, I've glued only one step, the bigger one to the hull, the second and the mast no.
In this way the mast work perfectly, and you can remove mast and keel!
Old Aug 10, 2007, 11:08 AM
bbdave is offline
Find More Posts by bbdave
Joined Aug 2007
Just ordered my etnz kit should get it mid to late august i'm hoping i can get hold of a set of Gospectres sails to make it a truly outstanding looking yacht i also quite like the look of his 507 footy so i've sent an email and eagerly await the reply. Hi from England by the way .
bbdave is offline Find More Posts by bbdave
Old Aug 10, 2007, 08:38 PM
doomracing's Avatar
Joined Mar 2002
Originally Posted by Norman2
Close up photo of new fittings
does that side stay line turnbuckle have a hook or a loop to the chain plate. if a hook where did you get it? i want to get rid of the clevis clips on my USOM.
Old Aug 10, 2007, 09:28 PM
Norman2 is offline
Norman2
Norman2's Avatar
Joined Mar 2006
Turnbuckles
They have a hook. They are made by Cap Maquette and I obtaines them from
Mike Cherubini. He has a site but I have forgotten. Hope this helps.
Norman2 is offline
Norman2
Norman2's Avatar
Joined Mar 2006
Turnbuckles
They have a hook. They are made by Cap Maquette and I obtained them from
Old Aug 10, 2007, 10:22 PM
Dick L. is offline
Find More Posts by Dick L.
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
Doom and others -
once again a "gentle reminder" to join AMYA.
If you are going to race - or want to know how to do things, being familiar with the web site and the hard work put in by volunteers would allow you to quickly find a supplier (or a couple) for those turnbuckles with hooks. Of course, you don't have to be a member to access the website - but a few membership bucks a year help support the hardware, software and URL address that it takes to bring you ( and all others) the information you seek. There are number of viable and well respected advertisers on the AMYA website and who pay $$$ to advertise in the magazine. With their advertising dollars and your membership fees the r/c sailing information you seek is made available.
Now go do the right thing - after you patronize the advertisers, of course.
Dick L. is offline Find More Posts by Dick L.
Discussion Thunder Tiger ETNZ Building Comments Norman2 Sailboats 13 Jul 15, 2008 04:42 PM
Discussion Thunder Tiger ETNZ R/C Sailboat gospectredotcom Sailboats 11 May 31, 2007 11:46 PM
New Product Thunder Tiger ETNZ R/C Sailboat Norman2 Sailboats 15 May 29, 2007 08:17 PM
Simple 400 Building Tips? 99esq High Performance 4 Sep 10, 2001 07:07 PM
