Old Feb 07, 2013, 10:30 AM
btasquared is offline
Find More Posts by btasquared
Joined Feb 2013
Standing Rigging Material
I'm new to the forum, so please excuse me if this has been covered in previous posts.
Four friends of mine and I are building Voyager II boats to race amongst ourselves. I gather from reading other psost that the line included in the kit for standing rigging is not up to the task, and most people are substituting braided Spectra 90# line. My question is, does this application really require 90# test? Seems awfully high, and that line is pretty large in diameter. I'd prefer to use something in the 30#-40# ranger, which is about 1/2 the diameter.
Any guidance would be appreciated.
btasquared is offline Find More Posts by btasquared
Old Feb 07, 2013, 12:11 PM
RodACarr is offline
Find More Posts by RodACarr
Joined Jun 2009
Standing rigging
An inexpensive and long term solution is to use 30# test STEELON plastic covered, stranded stainless steel leader wire available from several fishing supply web sites. The crimped swaging sleeves used to terminate the wire at fittings acts as a weak link in the event of a collision, and will allow the wire to pull through without jerking a fitting out of the mast or deck. Since one piece of the wire is strong enough to lift an entire 25 pound EC-12 it is more than strong enough for any boat of that size or smaller.
RodACarr is offline Find More Posts by RodACarr
Old Feb 07, 2013, 12:30 PM
Jake Bullit is offline
Find More Posts by Jake Bullit
Fly,crash,glue,repeat!
Jake Bullit's Avatar
Southport,N.W. England
Joined Nov 2007
I used the fishing wire traces for my rigging also,though she hasn't had many outings since I got into multi rotor helicopters.
Jake Bullit is offline Find More Posts by Jake Bullit
Old Feb 07, 2013, 12:46 PM
poltergeist is online now
Find More Posts by poltergeist
Kevin Gault
poltergeist's Avatar
Pomona, CA
Joined Apr 2007
I concur with Mr Carr about using SS leader wire. I think the reason for using larger diameter Spectra (if you choose that route) is because the smaller stuff can tend to slip in the bowsies that most use to tension it. Also, at least in big boats, when you get close to Spectra's max tensile strength, it tends to "creep" (permanently elongate). Not really an issue in areas where you adjust it all the time, but not good for standing rigging.
Kevin
poltergeist is online now Find More Posts by poltergeist
Old Feb 08, 2013, 08:07 AM
Joined Feb 2013
Thank you for the suggestions, guys.
If I were to go with the nylon covered SS wire, I'd need a crimping tool and the fittings, correct? Also, and maybe this isn't worth worrying about, doesn't the SS wire give you a lot more weight aloft relative to the spectra?
Old Feb 08, 2013, 12:30 PM
Joined Nov 2007
Just used pliers on my crimps.
Old Feb 08, 2013, 12:40 PM
Kevin Gault
Pomona, CA
Joined Apr 2007
I use this technique for crimping. Seems to make a nice, secure crimp with a pair of needlenose pliers. http://www.okanaganmodelsailboat.org/Step-by-StepD.html
Old Feb 10, 2013, 04:09 AM
haggly is offline
Find More Posts by haggly
Joined Feb 2013
So pissed off, took my TT ETNZ out today and ripped the top of the Jib, was only 3 knots of wind at the marina, luckily a man working on his boat saved me and retreived my ETNZ, otherwise i would have been swimming, at least she was watertight.
haggly is offline Find More Posts by haggly
Old Feb 10, 2013, 11:17 AM
Joined Nov 2007
Bummer, what happened to your jib?
Old Feb 10, 2013, 12:25 PM
Joined Feb 2013
Keel Bulb "Chip"
The kit includes a small piece of curved stamped metal that screws into the bottom of the ballast bulb. I have no clue what the purpose of this part is. Anyone? Bueller? Anyone??
Old Feb 10, 2013, 03:26 PM
jimhurley is offline
Find More Posts by jimhurley
jimhurley's Avatar
Sequim, WA
Joined Jan 2004
It is used in place of the wing if you don't want to use the wing.
jimhurley is offline Find More Posts by jimhurley
Old Feb 10, 2013, 05:17 PM
haggly is offline
Joined Feb 2013
I realised i had the jib to tight, when i sheeted in it was to much pressure and ripped out the top cleat, I have now run a forestay to the front of the jib boom, and another sheet line straight down from the mast to the back of the Job boom, also ran a line through the front of the jib itself to ensure only the wind could possibly do it damage. Rigging instructions are weak at best.
Old Feb 17, 2013, 01:03 AM
haggly is offline
Joined Feb 2013
Pictures
Added some safety to the original Chain plates to ensure if they break there's a back up.
Old Mar 06, 2013, 12:33 PM
Joined Nov 2007
Looking good
Old May 26, 2013, 10:54 PM
tarmstro is offline
Find More Posts by tarmstro
Thomas Armstrong
Chile, Santiago Metropolitan Region, Stgo
Joined Dec 2012
Complete Mods
Hi all, greetings from Chile.
Bought my TT ETNZ some 6 months ago, and decided to build it with massive rigging mods. I donīt want to duplicate all my explanations... you can take a look to pictures I took along the process here:
http://www.flickr.com/photos/thomasa...7632911255104/
All detail photos are from my own boat. Some vids and pictures also on that set. Feel free to ask for details on the comments of each picture in flickr, in this same forum, or at the build log I did here (spanish):
http://cach.cl/foroSMF/index.php?topic=26021.0
tarmstro is offline Find More Posts by tarmstro
Discussion Thunder Tiger ETNZ Building Comments Norman2 Sailboats 13 Jul 15, 2008 04:42 PM
Discussion Thunder Tiger ETNZ R/C Sailboat gospectredotcom Sailboats 11 May 31, 2007 11:46 PM
New Product Thunder Tiger ETNZ R/C Sailboat Norman2 Sailboats 15 May 29, 2007 08:17 PM
Simple 400 Building Tips? 99esq High Performance 4 Sep 10, 2001 07:07 PM
