Old Nov 04, 2002, 06:38 PM
Thanks for the Fish!
aerogel's Avatar
Land of cajuns
Joined Dec 2001
Well The Cavity Could be somthing as simple as plaster....easy to
drill Lots of holes....and is not so hard to pull masters from as
long as they do not have major undercuts..Plus it can handel heat...Tommrow Im going to buy a 50 lb bag of paster and vacume form somthing simple but this mean's I have to retool the boxes I allready have...or build a new one..
aerogel
aerogel is offline Find More Posts by aerogel
Old Nov 04, 2002, 07:43 PM
Joined Aug 2002
aerogel,
You might want to try hydrastone or ultrastone. It works like plaster but, becomes many times harder, like granite! You can drill the vacuum holes with a normal drill, but it takes heat better. We use this at my job when we want to make a temporary vacuum mold. The cool part is that it cost almost the same!
Gary,
www.wallacewireworks.com
bearship-1 is offline Find More Posts by bearship-1
Old Nov 04, 2002, 08:01 PM
aerogel's Avatar
Land of cajuns
Joined Dec 2001
Gary the webpage you gave at the end..You make them?
If So Gulp.....that is unreal...I would go mad...Like a hatter Trying to do somthing like that....very kewl
aerogel
Old Nov 04, 2002, 08:02 PM
aerogel's Avatar
Land of cajuns
Joined Dec 2001
Thye make Something called hydracal....I think its kinda the same thing not for sure......
aerogel
Old Nov 04, 2002, 08:25 PM
Joined Aug 2002
aerogel,
Yes, I do make the wire models and sell them all over the U.S.
They do take some time but, I do like to make them! And yes ultracall is the same thing. Glad you like my web site!
Gary,
Old Nov 04, 2002, 09:52 PM
Real Men Fly Pink Planes...
kepople's Avatar
United States, TX, Rockwall
Joined Jun 2001
Hey Gel;
I have used Hydrocal extensively in another hobby and it is a LOT harder than Palster, and has more flexibilty on the mixing time, and will NEVER become water soluble again..
Kirby
kepople is offline Find More Posts by kepople
Old Nov 05, 2002, 04:01 AM
aerogel's Avatar
Land of cajuns
Joined Dec 2001
I have to order Hydracal this is what sucks The shiping cost more then the product....I will try plaster first then If It works to Hydracal..or somthing like that.
I all so think I will need a higher end Vacume source then what Im Useing for Concave mold's......A Air compressor with a huge
tank and reverse the Input's.
aerogel
Old Nov 05, 2002, 05:00 AM
aerogel's Avatar
Land of cajuns
Joined Dec 2001
Im going to start of with a very simple mold like this one and work up from there
? is You guys think I should Put holes on the mold flat plane or only Were the part is?
aerogel
Old Nov 05, 2002, 06:45 AM
Houston, Texas
Joined Oct 2000
I have been experimenting with a hot box, what I did was use a cardboard box lined with alum. foil, a hole in one end to fit a heat gun and a thermometer to watch the temp, it works well enough that I am building a better box. My idea for a vacuum former is the vac table and a frame to hold the foam with a skirt all around it and a foam seal on the vac table, heating and vacuuming at the same time, it's nearly finished I will post some pictures if it works.
flailing is offline Find More Posts by flailing
Old Nov 05, 2002, 10:27 AM
Idaho
Joined May 2002
cavity mold vacuum
aerogel,
There will have to be a hole(s) of some kind in the cavity area to pull the softened foam down against the mold. As to how many holes, their placement, the necessary softness of the foam, the correct amount of vacuum needed to fully form the part is probably only going to be learned by experimentation. I still think that this process is going to be more an art than a science. As you go through this, try to design in simple checks. -ie- thermometer, timer, vacuum gage. Knowing the temperature and the amount of time neccessary to soften the foam is knowledge that can be used over and over. Same thing with a vacuum gage that reads either inches/water or inches/mercury. In the event that you do something right, you'll want to be able to repeat all the steps that led to success. Plus, you'll be able to tell the rest of us so we won't have to do all the hard work!
JT
DEPENDS is offline Find More Posts by DEPENDS
Old Nov 05, 2002, 11:27 AM
Vermont
Joined Mar 2002
With the cavity design your foam pieces will have the dimples on them.
fdisk is offline Find More Posts by fdisk
Old Nov 05, 2002, 01:31 PM
aerogel's Avatar
Land of cajuns
Joined Dec 2001
Yes it will have Dimple's going to have to sand them off I guess
I just want to see if this process with pick up all the Detail...
aerogel
Old Nov 05, 2002, 01:41 PM
Idaho
Joined May 2002
dimples and details
Just have to remember to put the dimples in non-detail areas. The amount of detail will depend on the type of foam used and getting the right temperature and vacuum pressure. Hope it is easier than it looks!
JT
Old Nov 05, 2002, 01:53 PM
ParkScaleModels
zbrubaker's Avatar
United States, PA, Loganville
Joined Feb 2002
If you want details, I think you may want to consider making both a male and female mold. First, make the male mold (plug) pull the foam over it. Take your time and carefully make all the detail marks you want on it (keep the foam on the plug during the whole operation). Once that is done, give it a light coat of paint, sand with 400 grit paper, paint lightly again, sand again, until you have a nice smooth surface. Then wax the foam carefully, and pour the female mold over top of it.
Now you can pull the foam over the plug, then press it into the female mold to give it the surface detail.
zbrubaker is offline Find More Posts by zbrubaker
Old Nov 05, 2002, 02:24 PM
Permanently banned
Mario's Avatar
Mesa, Arizona, USA
Joined Jul 2000
http://www.rcgroups.com/forums/showt...hreadid=70430h
Futher techniques for forming foam described through above link. I've Been doing this for a while now with great results I use color close cell foam sheets, the material is a bit flimsy for large and long fuselages, but works great for canopies and compact fuselage models.
Foam comes in a variety of densities and compositions if you can get some commercial "rubbery close-cell" type foam with a certain amount of stiffness, this works best for detail and rigidity. Some of this stuff is like Depron, which is more like beaded foam (not close-cell)that you find in electronic product boxes but with a bit of rubber added to it, models made from this particular category are ones like the Airhogs airplanes/helicopter shells, they don't have a lot of fine detail but close enough for an appealing model.
Mario I. Arguello
www.micro-flight.com
Mario is offline Find More Posts by Mario
E-zipper : kicken it up a notch MikeScag Power Systems 0 Jul 08, 2004 07:46 PM
lets kick this forum up to primetime.. kayaker43 3D Flying 6 Nov 12, 2003 12:58 AM
Theraforming zepron aerogel Foamies (Kits) 3 Nov 02, 2002 09:46 AM
The snap is good,,,kick is up................. Patrick H Sport Planes 2 Jun 28, 2002 03:30 PM
