Old Nov 01, 2002, 08:25 PM
frankenfoamy is offline
Find More Posts by frankenfoamy
Strange Plane Central
frankenfoamy's Avatar
Poway (near San Diego), CA US
Joined Dec 2000
Would this work?
Same vacuume setup
lay the cold zepron over the model and pinned down.
Then use a heat gun.
frankenfoamy is offline Find More Posts by frankenfoamy
Old Nov 01, 2002, 08:41 PM
KnifeEdge51 is offline
Find More Posts by KnifeEdge51
central AZ
Joined May 2002
An average penny weighs 2.5-2.6 grams
An average nickel weighs 4.0-5.0 grams
An average dime weighs 2.2-2.3 grams
Thanks fill!
Nick R.
KnifeEdge51 is offline Find More Posts by KnifeEdge51
Old Nov 01, 2002, 08:58 PM
aerogel is offline
Find More Posts by aerogel
Thanks for the Fish!
aerogel's Avatar
Land of cajuns
Joined Dec 2001
frankenfoamy
I dont think so.....There is no Vacume......The vacum sucks the hot foam...down....you can even get detail..
aerogel is offline Find More Posts by aerogel
Old Nov 01, 2002, 09:01 PM
Hippo is offline
Find More Posts by Hippo
The effect is sadly temporary
Hippo's Avatar
Ann Arbor, Michigan
Joined Oct 2001
Now, This is getting interesting.
Hey,
Let's work together. I'm really interested in what you've been accomplishing. I've been experimenting with the BlueCor, but because of its thickness (I think) it needs to be heated evenly before it can be formed.
This stuff cools too quickly to make it from the oven to the mold. That's why until now, I've been doing the entire process inside the oven. That's a bit of a problem, since I need parts that are larger than the oven is. The other problem is the mold material. I've been trying wood as a mold, but it doesn't hold up to the heat very well. The Frisbee mold is starting to warp from the repeated heating and cooling. I'm working on it though.
I'll keep you all posted. Thanks for getting me moving again. Let's get this to work.
-Dan
Hippo is offline Find More Posts by Hippo
Old Nov 01, 2002, 09:04 PM
aerogel is offline
aerogel's Avatar
Land of cajuns
Joined Dec 2001
Thanks Jgardner Ill take that one as a Complement
even Though vacum forming has be around for years..
The model are the Killer part.......Im going through my kits and
Drewling.........: )
Ill wait a while a post another development....: )
Aerogel
Old Nov 01, 2002, 09:17 PM
Jgardner is offline
Find More Posts by Jgardner
Fanfold abuser
Jgardner's Avatar
Rochester Monroe Cty, New York, United States
Joined Aug 2002
Convergence
What I am particularly jazzed about is the convergence of my experiments in slicing F3 and this very simple and inexpensive vacuum forming apparatus. I always thought of this process as requiring much more sophisticated equipment and as being more limited in the materials which could be formed.
Beyond using existing models, this could allow for building quick airframes with small variations.
Great stuff. Looks the home center gets a visit tomorrow.
Jgardner is offline Find More Posts by Jgardner
Old Nov 01, 2002, 09:20 PM
aerogel is offline
aerogel's Avatar
Land of cajuns
Joined Dec 2001
I have Several box's made......12by12 12by24....The Sheet's I get
only come in 12by24 Plus most oven's are not over 24 inches
For you guys that do not have the cash to build the rig....
all most ever on has a home vacume cleaner
Use one of your mom's/wife's....3 inch deep Cooking pan's
cut a hole in it.....For the vacume hose......Get some plywood That will cover the pan drill hole's every 1/2inch.....and all you will need to buy is the angle Aluminum and weather stiping.....and Clips and your set.....
aerogel
Old Nov 01, 2002, 11:14 PM
bearship-1 is offline
Find More Posts by bearship-1
Joined Aug 2002
Guys, you might want to try polyurethane foam for your molds. This is commonly known as sign foam. It comes from 1/2in to 12in by 48''X96'' sheet, that I have used. You can coat this foam with just about anything,primers of all sort polyester resin, etc., m.e.k. doesn't even bother it! This foam sands like basswood without the grain.
I work in a plastics jobshop and we make all of our patterns and plugs out of this foam. If you want to see some photos of this go to my web site.
Gary Wallace, www.wallacewireworks.com
bearship-1 is offline Find More Posts by bearship-1
Old Nov 02, 2002, 12:05 AM
kepople is offline
Find More Posts by kepople
Real Men Fly Pink Planes...
kepople's Avatar
United States, TX, Rockwall
Joined Jun 2001
Aerogel, my wife doesnt like me using the oven...other options?
You taking orders yet?
Kirby
kepople is offline Find More Posts by kepople
Old Nov 02, 2002, 02:40 AM
Andy Birkett is offline
Find More Posts by Andy Birkett
Was that my 15 minutes?
Andy Birkett's Avatar
Leicester. UK
Joined Jan 2002
Wow
Brilliiant!
And to think I was in bed for the entire duration of the thread!
Andy
Andy Birkett is offline Find More Posts by Andy Birkett
Old Nov 02, 2002, 05:40 AM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
me too, I'm sure they wait for us to go to bed before they post the best stuff
It looks great, might have to try it myself with Depron. Matt Keennon has done it with the really thin 1mm depron but in that case you need a really good oven as 1mm depron is stange stuff. His oven is industrial I think and has indirect heating and high velocity airflow around it to give even heating. It looks like this Zepron and probably 3mm/2mm Depron as well are more tolerant.
Graham
Graham Stabler is offline Find More Posts by Graham Stabler
Old Nov 02, 2002, 05:47 AM
j8m8l is offline
Find More Posts by j8m8l
Thats NOT indestructible
j8m8l's Avatar
London UK
Joined Apr 2002
HEHE...I was in bed too
My school has 2 vacuum formers, so I guess I could try using the real thing
They have heaters that you pull over the plastic/foam, and then remove when forming
I have used them for plastic forming, but i dont see why it would not work with 2/3mm depron
Josh
j8m8l is offline Find More Posts by j8m8l
Old Nov 02, 2002, 06:16 AM
aerogel is offline
aerogel's Avatar
Land of cajuns
Joined Dec 2001
Us cental time here....6am.. I chucked my 1/48 F-16
around the yard last night for about a hour.......I did't even change the foil on the wings and it glide's real well.....Im just
useing it as a test bed....
aerogel
Old Nov 02, 2002, 06:21 AM
aerogel is offline
aerogel's Avatar
Land of cajuns
Joined Dec 2001
You guys can try depron.........but I am Useing Virgin zepron....
this mean's it has never been heated up before it not flat its wavey and semi thick.....
If you brits...find virgin Depron let me Know....I think It would even be lighter then zepron......
aerogel
Old Nov 02, 2002, 06:38 AM
aerogel is offline
aerogel's Avatar
Land of cajuns
Joined Dec 2001
Kirby Well You allways could ......Buy A used oven for cheap
or Build you a Vacumfrom Oven.....Its really not that hard....
I havent had time to build mine.....but I have a the parts to do it
As for Order's.....Of what?....
All kits are Copy Righted So I dont Its a good idea to Sell Copys
of foam model kit's I dunno...
But for Sure a Bardering system would work
back In the day I did this all the time with model's kit's
I think the Tradeing should be Free....or just the cost of the Foam
and shiping......When you get 100 or so guys....Maken Kits you wont have to buy so many model's
Well That just my 2 Cents on that subject...
Aerogel
E-zipper : kicken it up a notch MikeScag Power Systems 0 Jul 08, 2004 07:46 PM
lets kick this forum up to primetime.. kayaker43 3D Flying 6 Nov 12, 2003 12:58 AM
Theraforming zepron aerogel Foamies (Kits) 3 Nov 02, 2002 09:46 AM
The snap is good,,,kick is up................. Patrick H Sport Planes 2 Jun 28, 2002 03:30 PM
