Old Nov 01, 2002, 10:39 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Tell me how you like MAXX 1000mAh NiMH cells
I've searched but found little hard data..
I don't need opinions (I've read a few of those), but experience using these cells - particularly max current draw.
I'll be using mine in my Slow Stick (at first)
Thanks!
..a
Old Nov 03, 2002, 08:07 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Thanks for all the feedback!
Well, they charge on auto mode in my I2 at 3.5A (max) - that pretty much speaks for itself. Using a 6-cell pack, my Slow stick (300 setup) flies 30 minutes on a charge. Power was more than adequate - almost vertical when needed, but running at 1/3-1/2 throttle in real slow flight. Boring as heck, of course, doing 100+ laps of an indoor soccer arena, but I wanted to see what duration I'd get. Voltage drop is minimal, power is lost suddenly with little indication that it's dropping. Good and bad, I guess.
..a
Old Nov 04, 2002, 01:24 PM
NewNCEGuy is offline
Find More Posts by NewNCEGuy
Not so New Anymore....
NewNCEGuy's Avatar
Triad NC
Joined Aug 2002
Hi Andy,
I started a thread a few days ago asking about comparisons between the Maxx 1000 and HeCell 1100, but I didn't get any replies (either)!
I'd like to get some more facts/specs on the Maxx cell if you run across any.
FYI I got some HeCells the other day and made up an 8-cell pack, the pack weighs exactly the same (6 oz even) as the 8-cell Maxx 1000 pack. Running the two packs hard in my slowstick (well, as hard as you can in a Slowstick) I can tell absolutely no difference in the performance. To me the Maxx cells seem at least as good.
Regards,
Ron
NewNCEGuy is offline Find More Posts by NewNCEGuy
Old Nov 08, 2002, 03:01 PM
apex is offline
Find More Posts by apex
Just a plane Junkie
Portland, Oregon
Joined May 2002
Well I don't know if this info is any help, but I did some static testing of the HE cell and Maxx 1000 cell.
10X4.7 APC SF prop, Hacker B20-15L + 4:1, room temp was 70 degrees.
9 cell HE 1000/1100
Charged at 1C took 1070mah. (has about 12 cycles on it)
12.51 volts before
12.09 volts 5 minutes after
Peak: 14.4 amps
After 5 seconds: 14.0 amps
9 cell Maxx 1000
Charged at 1C took 1081mah. (has 4 or 5 cycles on it)
12.12 volts 5 minutes after
Peak: 14.9 amps
After 5 seconds: 14.5
Both packs were ~60 degrees before and slightly warm (~70) after the test.
In flight I haven't been able to tell any differences either, but it was only my first day of actual flights on the Maxx 1000. I had a 15 minute flight (BEC never cut me off, i perceived a slight power sag and landed) with the Maxx 1000 9 cell pack on a 4:1 geared sp400 (8X6SF) Wingo on floats, just loafing around for splash and goes.
One thing that didn't work -- I had 6 leftover HE cells and wanted a 9 cell pack so I tried combining 3 Maxx 1000's and the 6 HE's (all cells were discharged and had the same voltage). The pack would never take more than an 800mah charge and wouldn't discharge more than ~700. Oh well.
apex is offline Find More Posts by apex
Old Nov 08, 2002, 04:33 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Good news indeed. Thanks!
..a
Help! Can you experts tell me how this thingy works??? ejaf DIY Electronics 33 Jan 31, 2007 06:41 PM
Tell me how you prove someone isn't somewhere? Viper Pilot Life, The Universe, and Politics 17 Jul 12, 2004 05:07 PM
Question Do You have a MSW and a MSW250? Tell me how you like'em! Helicool Foamies (Kits) 7 Feb 29, 2004 10:21 AM
Could you tell me how your using your Mega 16/15/7 ? Vindicator! Power Systems 8 Jan 03, 2004 09:34 PM
COME IN and tell me if you like this woman's voice Sloper Mario Life, The Universe, and Politics 18 Feb 04, 2002 02:06 PM
