Old Oct 31, 2002, 08:54 PM
Googleplex is offline
Find More Posts by Googleplex
It's a really big number.
Brisbane Intl, Australia
Joined Jan 2001
Best Brushless Motor and ESC for CP Hornet..
Hi all,
In order to avoid high $ shipping etc on the MS-Composit motor and ESC for the Hornet to Australia, what suggestions do you have for it?
Some brands are easy to get than others (Hacker and Shultz are easiest to get - anyone run them?)
Thanks people...
- Tim
Googleplex is offline Find More Posts by Googleplex
Old Oct 31, 2002, 11:31 PM
RMihara is offline
Find More Posts by RMihara
Aerial Shutterbug
RMihara's Avatar
San Mateo, California, United States
Joined Nov 2001
Hi Tim,
I am flying my CP Hornet with a Hacker B20-22S/Schulze 18He ESC combination and I like it very much.
Probably the best all around combination to use as quite a few other Hornet owners can attest to. CC' Phoenix is getting a software fix for the hard start issue and will be a lighter alternative to the Schulze (and cheaper).
I don't know much about the MS-motor but based on what I've read elsewhere, the motor could use a higher KV rating, although one could change the pinion size up to a 14 th.
Regards,
Roger
RMihara is offline Find More Posts by RMihara
Old Nov 01, 2002, 12:00 AM
Joined Jan 2001
Thanks Roger.
Will add that to my list of goodies
-tim
Old Nov 01, 2002, 02:07 AM
skirtz is offline
Find More Posts by skirtz
Joined Sep 2002
I would recomend Hacker 20-12L. It is stronger than 22S and runs cooler.
skirtz is offline Find More Posts by skirtz
Old Nov 01, 2002, 02:25 AM
RMihara is offline
Aerial Shutterbug
RMihara's Avatar
Joined Nov 2001
Tim,
Although I haven't flown a 12L just looking at the differences in the specs between the 22S and the 12L makes me wonder if it really makes a difference.
The 12L has a hotter wind (4650 KV) than the 22S (4091 KV) which to me means higher current draw and shorter flight times. Couple that with the fact that the 12L is 10mm longer and quite possibly 10% heavier than the 22S makes me wonder if it's worth it.
0.02
Roger
Old Nov 02, 2002, 10:06 PM
astrobob is offline
Find More Posts by astrobob
Los Angeles
Joined Oct 2002
best brushless for hornet
I do not have any experience with the hornet
but suggest that you consider our new
8 turn 010 fan motor.
specs are weight 32 grams
kv = 4150 rpm/volt
res = 120 milliohms
no load current 600 ma
price 75 dollars
see astro web site for details
astrobob
astrobob is offline Find More Posts by astrobob
Old Nov 02, 2002, 10:57 PM
docphi is offline
Find More Posts by docphi
Stupid gravity!
docphi's Avatar
Trinity, FL
Joined Jul 1999
The 8T Astro motor is a great alternative. The only problem is getting a 64P pinion for it. The smallest brass pinion you could bore is 12T. I've managed to squeak an 11T plastic pinion onto it. Flies the Hornet with authority on 3 LithPoly cells. I would prefer a 10T, but, no luck in finding one with a 3.2mm hole. The motor is 0.2 ounces lighter than the Hacker.
docphi is offline Find More Posts by docphi
Old Nov 03, 2002, 01:24 AM
ScotY is offline
Find More Posts by ScotY
ScotY's Avatar
Joined Feb 2001
Has anyone asked AstroBob if he can turn down the motor shaft to fit a standard pinion? Looks like he's looking to expand the market for his motors, so maybe he might be interested in doing a special run?
ScotY is offline Find More Posts by ScotY
Old Nov 03, 2002, 01:44 AM
RMihara is offline
Aerial Shutterbug
RMihara's Avatar
Joined Nov 2001
Docphi,
can you post a picture of your set-up? I'd love to see it!
Roger
Old Nov 03, 2002, 07:05 AM
docphi is offline
Stupid gravity!
docphi's Avatar
Trinity, FL
Joined Jul 1999
Roger,
I've swapped the Astro out of my Hornet and back into my Piccolo. The Hacker has gone into my Hornet.
Old Nov 03, 2002, 09:50 PM
RMihara is offline
Aerial Shutterbug
RMihara's Avatar
Joined Nov 2001
Oh Boo!
Old Nov 03, 2002, 10:30 PM
docphi is offline
Stupid gravity!
docphi's Avatar
Trinity, FL
Joined Jul 1999
No big whoop. Just pretend the Hacker is an Astro!
Old Nov 05, 2002, 10:54 PM
jk is offline
jk
Find More Posts by jk
jk
jk's Avatar
Huntington Beach, CA
Joined Apr 2001
i asked Bob Boucher (astroBob) to make me an astro AF010, 8 or 10 turn, over a year ago to try in my Hornets. it's nice to know that he's finally gotten around to making them. i also asked if he could turn the shaft down to 2mm. if he did, i think that he just might have a winner.
johnk
MicroHelis
jk is offline Find More Posts by jk
Old Feb 14, 2003, 06:25 PM
ozace is offline
Find More Posts by ozace
Renewed interest
ozace's Avatar
Melbourne , Australia
Joined Jun 2002
just wondering if anyone has now tried the astro in the hornet cp
that aeromicro is selling?/
adam
ozace is offline Find More Posts by ozace
Old Feb 14, 2003, 06:56 PM
astrobob is offline
Los Angeles
Joined Oct 2002
astro hornet motor
the astro hornet motor
pn 801H
is a 10 turn 010
it is supplied with both a 14 turn 64 pitch
pinion for the hornet and a 11 tooth 48 pitch
gear for the piccollo.
ready to run right out of box.
bob
What is the Best Brushless motor and ESC for my Corona? harbortime Electric Heli Talk 29 Dec 19, 2003 06:39 AM
Best brushless motor/gearbox for ModelTech Magic 3D? Jason M Sport Planes 22 May 25, 2003 07:31 PM
FS: Astro 010 Brushless Motor and ESC for MS Hornet Helicopter GoEFlight Aircraft - Electric - Airplanes (FS/W) 7 Jan 25, 2003 05:36 PM
FS: Astro 020 Brushless Motor and ESC for JR Voyager Helicopter GoEFlight Product Announcements 2 Jan 24, 2003 06:22 PM
Brushless motor/ESC for EDF Magnaflux Aircraft - Electric - Airplanes (FS/W) 2 Oct 25, 2001 07:49 PM
