Old Jun 05, 2007, 04:56 PM
superscott is offline
Find More Posts by superscott
superscott's Avatar
Joined Apr 2005
Build Log
Sea Vixen Build Guide
Megajets Sea Vixen
If you need to see larger pics, go to the websight for this build guide here:
http://www.rcgroups.com/forums/
showthread.php?t=695716#post7577634
Parts needed to complete
- up to 5oz motor
- speed control
- 3 micro servos (hitec 55-ish)
- a micro receiver
- a .21 dia carbon fiber tube
- foam safe glue or hot glue
- epoxy
- packaging tape
- sandpaper
- 1/32 or little thinner music wire
- micro control horns
- velcro
- battery
- Y servo connector
The first step is the fuselage. You want to peel the laminate from the side of the foam you are putting glue on, so it doesn't peel up later. You can peel the laminate off the other side too if you want, but I think that adds some strength. So if you are a good pilot and want to save some weight, peel it.
Glue the fuse sides to the fuse bottom piece. Start in the rear, work to the front.
superscott is offline Find More Posts by superscott
Old Jun 05, 2007, 05:05 PM
superscott's Avatar
Joined Apr 2005
Next up, the main wing, Glue and tape the wing halves together. Sand the leading edges to a point, and reinforce the leading edge with packaging tape. Also reinforce the aileron attachment point with tape so the laminate wont peel up under the hinge and cause flappy ailerons.
Cut a channel for the carbon tube. Tape one side first, then drop in a bunch of glue, then put the spar in, then tape over so its all smooth. If you are planning on going fast with this jet, consider putting more carbon tubing in the wing about an inch back from the leading edge of the wing to reduce wing flutter. If you do get wing flutter, make sure your control rods are tight with no play in the ailerons.
Old Jun 05, 2007, 05:11 PM
superscott's Avatar
Joined Apr 2005
ailerons and elevator.
Sand a 45 degree angle on the ailerons and elevator at the hinge point.
Wrap the ailerons, elevator and horizontal stabilizer in packaging tape(so the laminate doesnt peel up. I would recommend leaving the laminate on these pieces, because tape for the hinge doesn't stick to the bare foam very well, unless you glue the tape to the foam)
Feel free to sand the leading edge of the horizontal stab and trailing edges.
Tape/hinge elevator to horizontal stab.
Tape/hinge the ailerons to the wing
Old Jun 05, 2007, 05:14 PM
superscott's Avatar
Joined Apr 2005
Tape/hinge ailerons to main wing
Old Jun 05, 2007, 05:16 PM
superscott's Avatar
Joined Apr 2005
Slide the wing into the slot in the fuselage, center it and only glue the bottom. Do not glue the top yet.
Old Jun 05, 2007, 05:22 PM
superscott's Avatar
Joined Apr 2005
Aileron servo installation.
If you plan to go fast, you don't want a long control rod. Mount the servo as close to the aileron as you can, in the center of the aileron. Just trace the servo on the wing, cut it out, and glued and taped the servo in. The good thing about hot glue is it peels right off the servos for next time and it holds good.
Old Jun 05, 2007, 05:27 PM
superscott's Avatar
Joined Apr 2005
Engine Pods
Run the servo wires into the fuse, tape the wires down.
Glue down the pods, lining up the back and front respectivly to the wing. Glue the top fuse sides to the pods and then glue the top of the fuse sides to the wing.
Old Jun 05, 2007, 05:31 PM
superscott's Avatar
Joined Apr 2005
MOTOR MOUNTING
You can use a stick mount for your motor, just glue the stick to the wing. You can use a flat plate mount, just mount your motor to a piece of thin ply, then glue the ply to the back. Make the thrust angle straight. I went a little fancy on this mount.
Also, glue on the 2 tail booms exactly on the lines on the wing.
You kit includes 2 carbon rods. These are to reinforce the tail booms where the tail boom meets the wing. The weak spot is right where the tail boom meets the wing. Cut a slit in the tail boom that spans across this area, and glue the carbon rod in the tail boom.
Old Jun 05, 2007, 05:35 PM
superscott's Avatar
Joined Apr 2005
Elevator
Elevator servo can be mounted in the tail boom on the side to hide the servo better. This works. I dont like things lopsided though, so I opt to mount the elevator servo in the horizontal stab itself, in the middle. Same as the ailerons, nice and close, glued and taped tight.
When you glue the elevator to the booms, make sure things are squared up.
Old Jun 05, 2007, 05:42 PM
superscott's Avatar
Joined Apr 2005
Make all your connections, tests and do balancing now, before you put the top on.
Peel and laminate together the 4 canopy pieces.
Glue the top on to the 2 sides. Practice putting it in first before you put glue on it, so you know what you're in for. Pre bend it. Glue a little bit at a time.
Sand and glue on the canopy.
You can make a battery access hatch however you want. I suggest cutting around like the top of a pumpkin, big enough. Use a rubber band to hold it in flight.
30" Sea Vixen CG is 5.5 inches back from the leading edge of the wing at the root.
18" Sea Vixen CG is 3.25" inches back from the leading edge of the wing at the root.
16" Sea Vixen CG is 3.0" inches back from the leading edge of the wing at the root.
Good Flights!!!!!
Old Jun 15, 2007, 09:24 PM
knighttwister is offline
Find More Posts by knighttwister
end user
knighttwister's Avatar
USA, WI, Neenah
Joined Feb 2006
what kind of glue are you using?
where are you measuring the cg from? from the leading edge where it meets the fuselage?
thanks
knighttwister is offline Find More Posts by knighttwister
Old Jun 25, 2007, 07:41 PM
superscott's Avatar
Joined Apr 2005
yep measure from where the wing and fuse meet. I use hot melt glue
Old Oct 18, 2008, 06:22 AM
lvarmadillo is offline
Find More Posts by lvarmadillo
Joined Oct 2008
What paint do you use, if any?
Do you paint this jet and what kind of paint should be used? Most paint I have used melts the foam.
lvarmadillo is offline Find More Posts by lvarmadillo
Old Oct 20, 2008, 03:44 PM
superscott's Avatar
Joined Apr 2005
Testors spray cans work and Krylon "short cuts" spray paint works and is what I use. Colors are limited, but thats about all there is for spray paint safe for foam
Old Nov 11, 2008, 03:15 AM
Slowjohn is offline
Find More Posts by Slowjohn
United States, TX, Palacios
Joined Aug 2006
Okay I've decided to try this Sea Vixen kit but I'm wondering if anyone has tried using a GWS 40 or 50 mm EDF unit on it yet using either a brushed or brushless motor?
Thanks In Advance &
Standing By,
SJ
Slowjohn is offline Find More Posts by Slowjohn
Yippee! RWDRC Hawker Sea Fury Build Thread iflyprops Scale Kit/Scratch Built 414 Sep 09, 2008 11:09 AM
Slow Stick Build Guide - Need Comments TeddyV Beginner Training Area (Aircraft-Electric) 20 Dec 26, 2004 08:16 PM
Question ARF F18 Hornet build guide ? jester is corrup Electric Ducted Fan Jet Talk 6 Aug 16, 2004 12:01 AM
de Havilland Sea Vixen FAW.2 drawings. bipeflyer Electric Ducted Fan Jet Talk 8 Sep 02, 2003 04:56 AM
Sea Vixen or vampire BruceWilkerson Electric Ducted Fan Jet Talk 15 Jun 12, 2003 04:40 PM
